Is there a code level reason why my interrupt is not getting called?
Philosophix
Post by Philosophix » Thu Jan 03, 2019 4:52 pm
import os
import lcd160cr
from pyb import Pin, ExtInt
lcd = lcd160cr.LCD160CR('Y')
lcd.set_orient(lcd160cr.LANDSCAPE_UPSIDEDOWN)
lcd.set_font(2, scale=2)
lcd.set_text_color(lcd.rgb(0, 0, 0), lcd.rgb(255, 255, 255))
def clear_lcd():
    lcd.set_pen(1, lcd.rgb(255, 255, 255))
    lcd.erase()
axle_pulse_counter = 0
def axle_pulse_detected(line):
    axle_pulse_counter += 1
    clear_lcd()
    lcd.set_pos(2,10)
    if axle_pulse_counter % 2 == 1:
        lcd.write('Off')
        lcd.write('On')
ext = ExtInt(Pin('X19'), ExtInt.IRQ_FALLING, Pin.PULL_NONE, axle_pulse_detected)
clear_lcd()
jickster
Re: Is there a code level reason why my interrupt is not getting called?
Post by jickster » Thu Jan 03, 2019 5:35 pm
It wouldn’t hurt to call
ext.enable()
jickster
Post by jickster » Thu Jan 03, 2019 5:40 pm
I think your script just exits cause there’s nothing to keep it from exiting.
Just to test, put an infinite
while True: pass
loop at the very bottom.
Philosophix
Post by Philosophix » Thu Jan 03, 2019 6:00 pm
Tested both of your suggestions, but no luck. I think (though am not sure) that the infinite while loop at the end is not needed as the interrupt callback is already set and should fire regardless.
Post by Roberthh » Thu Jan 03, 2019 8:53 pm
It might be required to add:
global axle_pulse_counter
in the function axle_pulse_detected(line). I used that in a code, which by chance also uses X19, and that one works.
Philosophix
Post by Philosophix » Fri Jan 04, 2019 6:55 am
Adding
fixed the problem as all variables are assumed to be local in a python function. You can access a global variable without the explicit global declaration, but you can't modify it without it. You live, you learn. Thanx a million Roberthh!!
Philosophix
Post by Philosophix » Fri Jan 04, 2019 7:14 am
For future reference:
ext.enable()
and
while True: pass
were not needed to make the interrupt work.
Also the interrupt callback function axle_pulse_detected(line) will only be:
The lcd printouts were just for debugging the external interrupt.
Post by Roberthh » Fri Jan 04, 2019 7:32 am
The reason for needing to declare the global is scoping. The ISR, when called, has no context and no visibility of symbols outside it's own code. But since the source code is a usual python script and the ISR loosk like a normal python function, you would expect symbols at global level to be accessible in that function.
Post by dhylands » Fri Jan 04, 2019 8:45 pm
I would have thought that global would be required in general and has nothing to do with ISRs.
MicroPython v1.9.4-665-g7795b2e5c-dirty on 2018-10-19; linux version
>>> num = 0
>>> def incr():
...     num += 1
>>> for i in range(4):
...     print(num)
...     incr()
0
  File "<stdin>", line 3, in <module>
  File "<stdin>", line 2, in incr
NameError: local variable referenced before assignment
Errors like this in an ISR tend to get converted into MemoryErrors unless you declare an emergency exception buffer, as described here: http://docs.micropython.org/en/latest/r ... ion-buffer
Post by Roberthh » Fri Jan 04, 2019 8:53 pm
Yes and no. The example below looks different. Besides that, declaring globals is anyhow helpful for clarity.
>>> num=1
>>> def f():
...     print(num)
>>> f()
1
>>> b=bytearray(1)
>>> def y():
...     b[0] = b[0] + 1
>>> y()
>>> b
bytearray(b'\x01')
