Speed calculation
Philosophix
Speed calculation
Post by Philosophix » Fri Jan 04, 2019 8:00 pm
I was thinking of calculating vehicle speed in a timer callback-function set to be called at 1 hz, but am unsure what I'm allowed to do inside the callback. Can I declare and use local variables, call other functions, ...? Or is there a better way to implement speed calculation when I know how many pulses the inductive sensor gives per distance unit?
jickster
Re: Speed calculation
Post by jickster » Fri Jan 04, 2019 8:33 pm
There are rules about ISRs:
https://docs.micropython.org/en/latest/ ... rules.html
Unless you have a time-sensitive action to take, you should consider using micropython.schedule
https://docs.micropython.org/en/latest/ ... n.schedule
With this, you can schedule a callback-function to be executed “as soon as possible” and it will be NOT in ISR context so there’s no restrictions like memory allocation.
Philosophix
Post by Philosophix » Fri Jan 04, 2019 8:59 pm
So I schedule a callback-function in the timer callback-function?
What do I do with the arg-argument of the schedule-function if I'm scheduling a function with no args?
Thanx!
jickster
Post by jickster » Fri Jan 04, 2019 10:05 pm
Philosophix wrote:So I schedule a callback-function in the timer callback-function?
Thanx!
Pass in 0 like the timer example here
https://docs.micropython.org/en/latest/ ... #isr-rules
