why does pyb.rng() provide only 30 bits of the 32-bit hardware random number generator?
hal rng.c shifts off lower 2 bits HAL_RNG_GetRandomNumber(&RNGHandle) >> 2
This app note on NIST tests of STM32Fxx random number generator doesn't report any problems?
http://www.st.com/web/en/resource/techn ... 073853.pdf
inquiring minds want to know ...
pyb.rng() why 30 bits?
Re: pyb.rng() why 30 bits?
If I had to guess I would say that it because at the time the rng code was written, MicroPython probably only supported small ints, which are 31-bit signed, or 30-bit unsigned numbers.
Now that there is multi-precision integer support, rng can probably be reworked to support the full 32-bits.
Perhaps it should stay at 30 bits to ensure it can be called from within an interrupt handler.
