opening internal pull-up for I2C is so complex!!
XIVN1987
Post by XIVN1987 » Fri Feb 15, 2019 5:35 am
import pyb, stm, time
i2c = pyb.I2C(1, pyb.I2C.MASTER, baudrate=20000)
''' opening internal pull-up for I2C '''
PUPDR = stm.mem32[stm.GPIOB + stm.GPIO_PUPDR]
PUPDR &= ~((3 << 6*2) | (3 << 7*2))
PUPDR |= ((1 << 6*2) | (0 << 7*2))
stm.mem32[stm.GPIOB + stm.GPIO_PUPDR] = PUPDR
time.sleep(1)
PUPDR |= ((1 << 6*2) | (1 << 7*2))
while(1): i2c.scan()
note 1: init i2c first, and then open internal pull-pu. otherwise, i2c init will close internal pull-up
note 2: when open internal pull-up, you need make a I2C STOP signal. otherwise, the busy flag of I2C will set, and I2C will not work
is there an esay way to open the internal pull-up for I2C?
Not on a Pyboard 1.x
Post by pythoncoder » Fri Feb 15, 2019 2:49 pm
The Pyboard 1.x has physical 4.7KΩ resistors to 3.3V on both I2C ports so there is no need for special coding.
Re: opening internal pull-up for I2C is so complex!!
Post by dhylands » Fri Feb 15, 2019 4:58 pm
And if you did want to set the internal pullups, you could just do:
b2 = pyb.Pin('B2', pyb.Pin.IN, pull=pyb.Pin.PULL_UP)
b3 = pyb.Pin('B3', pyb.Pin.IN, pull=pyb.Pin.PULL_UP)
before initializing the i2c device.
Beware of internal pull-up for I2C.
Post by pythoncoder » Sat Feb 16, 2019 9:46 am
Quite. But the internal pullup value is probably too large for reliable I2C operation. This is relevant for anyone using soft I2C.
