today, i got a fresh clone of micropython, but the make failed ?? (ubuntu 14.04)
make BOARD=PYBV10
mkdir -p build-PYBV10/genhdr
Create build-PYBV10/genhdr/pins.h
CPP ../py/qstrdefs.h
cc1: error: unrecognized command line option "-Wdouble-promotion"
make: *** [build-PYBV10/genhdr/qstrdefs.generated.h] Error 1
In file included from ../py/qstrdefs.h:27:
../py/mpconfig.h:620: error: #error endianness not defined and cannot detect it
so i just downloaded the latest dfu, but i'd like to get make working again.
i was hoping the new firmware would fix the RTC ppm problem--looks like there were patches to rtc.c, but with the 3/20/15 firmware i still see 175 ppm on the RTC --
