I can't access microSD cards with Pyboard 1.1
Re: I can't access microSD cards with Pyboard 1.1
It's difficult to support clone boards we don't possess because we can't replicate your test conditions.
All I can say is that on official Pyboards both built-in and external SD card adaptors work fine.
Looks like a knock-off. I'd return it, if they take returns.adumbname wrote: ↑Tue Aug 17, 2021 10:49 pmThis Pyboard was bought on Amazon ( https://www.amazon.com/Homyl-Piece-Micr ... 975&sr=8-1 ).
Best formatted with the SD Association formatter (not a Linux thing) or in a digital camera. There may even be a routine in MicroPython to format.The SD card is a 4 GB Kingston micro SD HC and has been formatted to "loop" and FAT32.
Try thonny. It's a solid IDE.Communication to the PyBoard is via Linux/Mint/Cinnamon: having better luck using screen /dev/ttyACM0 than rshell --port /dev/ttyACM0.
They're different for all the boards, so that's why there isn't one location for this info.(Though it'd be great if all of the relevant suggestion, such as which SD Card to buy, how to format it, listings of boot & main on both /flash and /sd were all in one place )
Personally, for my definition of "just workingness + SD card support", the MCUDev Black STM32F407VET6 does it. You do have to build MicroPython from source, but mcauser's MCUDev Black STM32F407VET6 makes that not too hard. Any decent µSD card should do: we're not pushing the boundaries of writing speed. I like this board because it has a battery-backed RTC and the MicroPython firmware exports the SD filesystem as USB storage. If you copy boot.py and main.py to the root of the SD card and create /lib there too, you've got a system you can develop on without relying entirely on a serial connection.
My only suggestion for datalogging: make sure you write/flush/open as append then close the logging file (pick one). write() doesn't seem to hit the SD card immediately.
Scruss: thanks for the very helpful and timely advice!
I will post a note on Amazon, so others don't blindly stumble into this time sink!
my datalogger needs to run at >= 10k sps on 4 ADC channels. Thus, the PyBoard looked like a perfect fit - but your suggestion may be better. sampling, data storage and pwm motor control x2 are all the hardware that's required. which would you choose?
Hi, I also have problem to mount a SDCard on a NUCLEO-L476RG board. I've tried to follow all the steps reported on this discussion but without results. I'm using an external SDCard Reader connected with SDMMC peripheral and without detect pin. I try to add this lines on mpconfigboard.h file:
and forcing the detect pin to 0. When I call sd.present() the result was True, but when I try to mount the sd, it don't works
#define MICROPY_HW_ENABLE_SDCARD (1)
#define MICROPY_HW_SDCARD_SDMMC (1)
// SD card detect switch
#define MICROPY_HW_SDCARD_DETECT_PIN (pin_A8)
#define MICROPY_HW_SDCARD_DETECT_PULL (GPIO_PULLUP)
#define MICROPY_HW_SDCARD_DETECT_PRESENT (GPIO_PIN_RESET)
#define MICROPY_HW_SDCARD_D0 (pin_C8)
#define MICROPY_HW_SDCARD_D1 (pin_C9)
#define MICROPY_HW_SDCARD_D2 (pin_C10)
#define MICROPY_HW_SDCARD_D3 (pin_C11)
#define MICROPY_HW_SDCARD_CK (pin_C12)
#define MICROPY_HW_SDCARD_CMD (pin_D2)
>>> os.mount(sd,'/sd')
OSError: [Errno 19] ENODEV
@vinz-uts has possibly found a solution.
I also had the problem that some SDCards work, i.e. are mounted, others (older, smaller ones) not.
It seems that by default the faster 4-bit transfer mode is used for accessing them.
Setting a #define in mpconfigboard.h changes that.
That define is missing in my sources freshly checked out for Pyboard 1.1 .
See viewtopic.php?f=12&t=11098.
I will try this option as soon as I'm home and report.
Including
in mpconfigoard.h (and compiling, uploading)
changed the situation with regard to my old 64MB SDCards only slightly.
before:
after:
Still no possibility to access these old SDCards.?
#define MICROPY_HW_SDCARD_BUS_WIDTH (1)
before:
>>> import os
>>> os.listdir('/')
['flash']
>>> sd = pyb.SDCard()
>>> sd.present()
True
>>> os.mount(sd,'/sd')
OSError: 16
>>> import os
>>> os.listdir('/')
['flash']
>>> sd = pyb.SDCard()
>>> sd.present()
True
>>> os.mount(sd,'/sd')
There is a python-only SD-Card driver in the micropython github repository under /drivers/sdcard.
Using it with soft-spi made it possible to access my older SD-Card.
Apparently the python driver has more intelligence built in. The costs are 5 KB memory.
# Starts SDCard with SoftSPI and mounts it to '/sd'.
# Should work with older SDCards on the Pyboard
# Code adapted from Peter Hinch's sdtest.py
import os, sdcard, machine
spi = machine.SoftSPI(baudrate=400000, sck=pyb.Pin('C12'), mosi=pyb.Pin('D2'), miso=pyb.Pin('C8'))
spi.init() # Ensure right baudrate
sd = sdcard.SDCard(spi, pyb.Pin('C11'))
os.mount(sd, "/sd")
