using lambda with timer
AlexBir
Post by AlexBir » Fri Apr 26, 2019 8:44 pm
def blink_led():
    pyb.LED(1).toggle()
tim=pyb.Timer(4)
tim.init(freq=2)
tim.callback(blink_led)
I am getting:
PYB: sync filesystems
PYB: soft reboot
MicroPython v1.9.4-85-gdf9b7e8f on 2018-05-24; PYBv1.1 with STM32F405RG
>>> uncaught exception in Timer(4) interrupt handler
TypeError:
why?
Re: using lambda with timer
Post by dhylands » Fri Apr 26, 2019 9:39 pm
Because your callback is missing a parameter.
The documentation for the timer callback is here:
http://docs.micropython.org/en/latest/l ... l.callback
Your callback must take one argument, which is the timer object.
You can also use lambda functions like this example here:
http://docs.micropython.org/en/latest/p ... -callbacks
which takes one argument (the t)
You can also get more information about the error by allocating an emergency exception buffer as described here:
http://docs.micropython.org/en/latest/r ... ion-buffer
