I'm working on a port of this PS gamepad lib, written for Arduino/PIC:
https://github.com/madsci1016/Arduino-PS2X
I'm testing my code with a DualShock 2 Sony controller.
I'm using the SPI class to send/receive datas, and I encounter a strange behaviour.
Most of the code seems to work, but while reading buttons/sticks positions, I get some strange values. For example, sticks neutral values are 0x7b instead of 0x7f.
But the main issue is the send_recv() SPI method sometimes return an empty string. Is that possible? I though that I should always get something, whith SPI, as the MISO line should be evaluated at the same time the MOSI is set, at each clock edge... Am I wrong?
Here is my code so far; if someone see somehting strange, let me know. I tried to read all bytes in only 1 send_recv() call, instead of using a loop (line 241-245), but it does not help, as some values are shifted up... I'm puzzled.
Thanks for your help.
PS: for example, I always get an empty string when hitting the X button. But I can see that the corresponding analog value (pressure) is set!
# -*- coding: utf-8 -*-
""" PS2 gamepad python support for Micropython (pyboard)
- PyS2x http://www.github.com/ is Copyright:
- (C) 2015 Frederic Mantegazza
- (C) 2011-1013 Bill Porter
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
or see:
http://www.gnu.org/licenses/gpl.html
See https:# github.com/madsci1016/Arduino-PyS2x for original Arduino code
import logging
CTRL_BYTE_DELAY = 4
MAX_DELAY = 1500
# Button constants
PSB_SELECT = 0x0001
PSB_L3 = 0x0002
PSB_R3 = 0x0004
PSB_START = 0x0008
PSB_PAD_UP = 0x0010
PSB_PAD_RIGHT = 0x0020
PSB_PAD_DOWN = 0x0040
PSB_PAD_LEFT = 0x0080
PSB_L2 = 0x0100
PSB_R2 = 0x0200
PSB_L1 = 0x0400
PSB_R1 = 0x0800
PSB_GREEN = 0x1000
PSB_RED = 0x2000
PSB_BLUE = 0x4000
PSB_PINK = 0x8000
PSB_TRIANGLE = 0x1000
PSB_CIRCLE = 0x2000
PSB_CROSS = 0x4000
PSB_SQUARE = 0x8000
# Guitar Hero buttons constants
GREEN_FRET = 0x0200
RED_FRET = 0x2000
YELLOW_FRET = 0x1000
BLUE_FRET = 0x4000
ORANGE_FRET = 0x8000
STAR_POWER = 0x0100
UP_STRUM = 0x0010
DOWN_STRUM = 0x0040
WHAMMY_BAR = 8
# Sticks values
PSS_RX = 5
PSS_RY = 6
PSS_LX = 7
PSS_LY = 8
# Analog buttons
PSAB_PAD_RIGHT = 9
PSAB_PAD_UP = 11
PSAB_PAD_DOWN = 12
PSAB_PAD_LEFT = 10
PSAB_L2 = 19
PSAB_R2 = 20
PSAB_L1 = 17
PSAB_R1 = 18
PSAB_GREEN = 13
PSAB_RED = 14
PSAB_BLUE = 15
PSAB_PINK = 16
PSAB_TRIANGLE = 13
PSAB_CIRCLE = 14
PSAB_CROSS = 15
PSAB_SQUARE = 16
# Controllers
DUALSHOCK = 0x03
GUITAR_HERO = 0x01
WIRELESS_DUALSHOCK = 0x0c
#ENTER_CONFIG = bytearray((0x01, 0x43, 0x00, 0x01, 0x00)) # does not work
ENTER_CONFIG = bytearray((0x01, 0x43, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00))
SET_MODE = bytearray((0x01, 0x44, 0x00, 0x01, 0x03, 0x00, 0x00, 0x00, 0x00))
SET_BYTES_LARGE = bytearray((0x01, 0x4F, 0x00, 0xFF, 0xFF, 0x03, 0x00, 0x00, 0x00))
EXIT_CONFIG = bytearray((0x01, 0x43, 0x00, 0x00, 0x5A, 0x5A, 0x5A, 0x5A, 0x5A))
ENABLE_RUMBLE = bytearray((0x01, 0x4D, 0x00, 0x00, 0x01))
TYPE_READ = bytearray((0x01, 0x45, 0x00, 0x5A, 0x5A, 0x5A, 0x5A, 0x5A, 0x5A))
LOGGING_LEVEL = logging.DEBUG
class PyS2xError(Exception):
class PyS2x(object):
def __init__(self):
super(PyS2x, self).__init__()
self._buttons = 0xffff
self._buttonsPrev = self._buttons
self._lastRead = 0
self._readDelay = 1
self._controllerType = None
self._pressure = False
self._rumble = False
self._rawData = 21 * [0]
self._logger = logging.getLogger("PyS2x")
self._logger.level = LOGGING_LEVEL
self._cs = pyb.Pin('Y5', pyb.Pin.OUT_PP)
self._cs.high()
self._spi = pyb.SPI(2, pyb.SPI.MASTER, firstbit=pyb.SPI.LSB, baudrate=250000, polarity=1, phase=1, crc=None)
@property
def pressure(self):
return self._pressure
@property
def rumble(self):
return self._rumble
@property
def controllerType(self):
return self._controllerType
@property
def buttonDataByte(self):
return ~self._buttons
def newButtonState(self, button=None):
if button is None:
return (self._buttonsPrev ^ self._buttons) > 0
return ((self._buttonsPrev ^ self._buttons) & button) > 0
def buttonPressed(self, button):
return self.newButtonState(button) & self.button(button)
def buttonReleased(self, button):
return self.newButtonState(button) & ((~self._buttonsPrev & button) > 0)
def button(self, button):
return (~self._buttons & button) > 0
def analog(self, button):
return self._rawData[button]
def _shiftInOut(self, byte):
ans = self._spi.send_recv(byte, timeout=10)
pyb.udelay(CTRL_BYTE_DELAY)
return ord(ans)
except TypeError:
self._logger.error("_shiftInOut()): no answer; retrying...")
return 0xff
#ans = self._spi.recv(1)
#try:
#return ord(ans)
#except TypeError:
#self._logger.error("_shiftInOut()): really no answer!")
#return 0xff
def _sendCmd(self, cmd):
self._cs.low() # low enable joystick
for i in range(len(cmd)):
self._shiftInOut(cmd[i])
self._cs.high() # high disable joystick
pyb.delay(self._readDelay)
def read(self, motor1=False, motor2=0x00):
delay = pyb.millis() - self._lastRead
# Waited to long?
if delay > MAX_DELAY:
self.reconfigure()
# Waited too short?
if delay < self._readDelay:
pyb.delay(self._readDelay - delay)
#if motor2 != 0x00:
#motor2 = map(motor2, 0, 255, 0x40, 0xFF) # nothing below 40 will make it spin
dword = bytearray((0x01, 0x42, 0x00, motor1, motor2, 0x00, 0x00, 0x00, 0x00))
dword2 = bytearray((0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00))
# Try a few times to get valid data...
for retry in range(5):
if retry:
self._logger.warning("read(): retry=%d" % retry)
# Send the command to send button and joystick data
#self._logger.debug("read(): send button/joystick data...")
for i, byte in enumerate(dword):
self._rawData[i] = self._shiftInOut(byte)
#ans = self._spi.send_recv(dword)
#for i, byte in enumerate(ans):
#self._rawData[i] = byte
# If controller is in full data return mode, get the rest of data
if self._rawData[1] == 0x79:
#self._logger.debug("read()): controller is in full data return mode. Read rest of data...")
for i, byte in enumerate(dword2):
self._rawData[i+9] = self._shiftInOut(byte)
#ans = self._spi.send_recv(dword2)
#self._rawData[i+9] = byte
# Check to see if we received valid data or not.
# We should be in analog mode for our data to be valid
if self._rawData[1] & 0xf0 == 0x70:
break
# If we got to here, we are not in analog mode, try to recover...
self.reconfigure() # try to get back into self.analog mode
# If we get here and still not in analog mode, try increasing _readDelay...
if self._rawData[1] & 0xf0 != 0x70:
if self._readDelay < 10:
self._readDelay += 1 # see if this helps out...
self._logger.warning("read()): increased _readDelay to %dd" % self._readDelay)
# Store the previous buttons states
# Store as one value for multiple functions
#self._logger.debug("read()): _rawData=%s" % repr(self._rawData))
self._buttons = (self._rawData[4] << 8) + self._rawData[3]
#self._logger.debug("read(): buttons=%04x" % self._buttons)
self._lastRead = pyb.millis()
return (self._rawData[1] & 0xf0) == 0x70
def configure(self, pressure=False, rumble=False):
ans = []
# New error checking
# First, read gamepad a few times to see if it's talking
#self._logger.debug("configure()): first dummy read")
self.read()
#self._logger.debug("configure()): second dummy read")
self.read()
# See if it talked
# See if mode came back
# If still anything but 0x41, 0x73 or 0x79, then it's not talking
if self._rawData[1] != 0x41 and self._rawData[1] != 0x73 and self._rawData[1] != 0x79:
self._logger.critical("Controller mode not matched or no controller found")
self._logger.critical("Expected 0x41 or 0x73, got %s" % hex(self._rawData[1]))
self._logger.critical("Check wiring...")
raise PyS2xError
# Try setting mode, increasing pyb.delays if need be.
self._readDelay = 1
for retry in range(10):
# Start config run
self._logger.debug("configure(): send ENTER_CONFIG")
self._sendCmd(ENTER_CONFIG)
# Read type
self._logger.debug("configure(): send TYPE_READ and readback controller type")
for byte in TYPE_READ:
ans.append(self._shiftInOut(byte))
self._logger.debug("configure()): ans=%s" % repr(ans))
self._controllerType = ans[3]
self._logger.debug("configure()): _controllerType=%d" % self._controllerType)
self._logger.debug("configure(): send SET_MODE")
self._sendCmd(SET_MODE)
if rumble:
self._logger.debug("configure(): send ENABLE_RUMBLE")
self._sendCmd(ENABLE_RUMBLE)
self._rumble = True
if pressure:
self._logger.debug("configure(): send SET_BYTES_LARGE")
self._sendCmd(SET_BYTES_LARGE)
self._pressure = True
self._logger.debug("configure(): send EXIT_CONFIG")
self._sendCmd(EXIT_CONFIG)
self.read()
if pressure :
break
elif self._rawData[1] == 0x73:
self._logger.warning("Controller refusing to enter Pressures mode, may not support it")
break
break
self._readDelay += 1 # add 1ms to self._readDelay
self._logger.critical("Controller not accepting commands")
self._logger.critical("Mode still set at %s" % hex(self._rawData[1]))
raise PyS2xError
def enableRumble(self):
self._rumble = True
def enablePressures(self):
self.read()
self.read()
if self._rawData[1] != 0x79:
return False
return True
def reconfigure(self):
self._logger.debug("reconfigure(): send ENTER_CONFIG")
self._logger.debug("reconfigure(): send SET_MODE")
if self._rumble:
self._logger.debug("reconfigure(): send ENABLE_RUMBLE")
if self._pressure:
self._logger.debug("reconfigure(): send SET_BYTES_LARGE")
self._logger.debug("reconfigure(): send EXIT_CONFIG")
def main():
logger = logging.getLogger("main()")
pys2x = PyS2x()
vibrate = 0
# Add delay to give wireless ps2 module some time to startup, before configuring it
pyb.delay(300)
error = pys2x.configure(pressure=False, rumble=True)
logger.info("Found Controller, configured successful (pressure=%s, rumble=%s)" % (pys2x.pressure, pys2x.rumble))
logger.info("Try out all the buttons, X will vibrate the controller, faster as you press harder ")
logger.info("holding L1 or R1 will print out the analog stick values.")
if pys2x.controllerType == DUALSHOCK:
logger.info("DualShock Controller found")
elif pys2x.controllerType == GUITAR_HERO:
logger.info("GuitarHero Controller found")
elif pys2x.controllerType == WIRELESS_DUALSHOCK:
logger.info("Wireless Sony DualShock Controller found")
logger.critical("Unknown Controller type found (0x%02x)" % pys2x.controllerType)
raise SystemExit
# You must Read Gamepad to get new values and set vibration values
# pys2x.read(small motor on/off, larger motor strenght from 0-255)
# if you don't enable the rumble, use pys2x.read() with no values
# You should call this at least once a second
if pys2x.controllerType == GUITAR_HERO: # Guitar Hero Controller
pys2x.read()
if pys2x.buttonPressed(GREEN_FRET):
logger.info("Green Fret Pressed")
if pys2x.buttonPressed(RED_FRET):
logger.info("Red Fret Pressed")
if pys2x.buttonPressed(YELLOW_FRET):
logger.info("Yellow Fret Pressed")
if pys2x.buttonPressed(BLUE_FRET):
logger.info("Blue Fret Pressed")
if pys2x.buttonPressed(ORANGE_FRET):
logger.info("Orange Fret Pressed")
if pys2x.buttonPressed(STAR_POWER):
logger.info("Star Power Command")
if pys2x.button(UP_STRUM): # will be TRUE as long as button is pressed
logger.info("Up Strum")
if pys2x.button(DOWN_STRUM):
logger.info("DOWN Strum")
if pys2x.button(PSB_START): # will be TRUE as long as button is pressed
logger.info("Start is being held")
if pys2x.button(PSB_SELECT):
logger.info("Select is being held")
if pys2x.button(ORANGE_FRET): # print stick value IF TRUE
logger.info("Wammy Bar Position: %d" % pys2x.analog(WHAMMY_BAR))
else: # DualShock Controller
pys2x.read(False, vibrate) # read controller and set large motor to spin at 'vibrate' speed
logger.info((len(pys2x._rawData) * "%02x ") % tuple(pys2x._rawData))
if pys2x.button(PSB_PAD_UP): # will be TRUE as long as button is pressed
logger.info("Up held this hard: %d" % pys2x.analog(PSAB_PAD_UP))
if pys2x.button(PSB_PAD_RIGHT):
logger.info("Right held this hard: %d" % pys2x.analog(PSAB_PAD_RIGHT))
if pys2x.button(PSB_PAD_LEFT):
logger.info("LEFT held this hard: %d" % pys2x.analog(PSAB_PAD_LEFT))
if pys2x.button(PSB_PAD_DOWN):
logger.info("DOWN held this hard: %d" % pys2x.analog(PSAB_PAD_DOWN))
vibrate = pys2x.analog(PSAB_CROSS) # this will set the large motor vibrate speed based on how hard you press the blue (X) button
if pys2x.newButtonState(): # will be TRUE if any button changes state (on to off, or off to on)
if pys2x.button(PSB_L3):
logger.info("L3 pressed")
if pys2x.button(PSB_R3):
logger.info("R3 pressed")
if pys2x.button(PSB_L2):
logger.info("L2 pressed")
if pys2x.button(PSB_R2):
logger.info("R2 pressed")
if pys2x.button(PSB_TRIANGLE):
logger.info("Triangle pressed")
if pys2x.buttonPressed(PSB_CIRCLE): # will be TRUE if button was JUST pressed
logger.info("Circle just pressed")
if pys2x.newButtonState(PSB_CROSS): # will be TRUE if button was JUST pressed OR released
logger.info("X just changed")
if pys2x.buttonReleased(PSB_SQUARE): # will be TRUE if button was JUST released
logger.info("Square just released")
if pys2x.button(PSB_L1) or pys2x.button(PSB_R1): # print stick values if either is TRUE
logger.info("Stick Values: %d, %d, %d, %d" % (pys2x.analog(PSS_LY), pys2x.analog(PSS_LX), pys2x.analog(PSS_RY), pys2x.analog(PSS_RX)))
pyb.delay(50)
if __name__ == "__main__":
main()
