Install original windows driver
erikblue
Post by erikblue » Tue Sep 03, 2019 11:48 pm
In trying to learn more how to access the pyboard from my windows machine, I used zadig to change the driver for the pyboard so I could access using pyusb module on the PC. However, now when I plug in the pyboard, I no longer get a flash drive to pop up. Any idea how I can go back and reinstall the old driver? Whoops..
Thank you,
Erik
erikblue
Re: Install original windows driver
Post by erikblue » Thu Sep 05, 2019 5:40 pm
Device still works as a COM port and I can get to REPL. Just no mass storage device shows up... Darn, how do I fix this?
starter111
Post by starter111 » Fri Sep 06, 2019 9:34 pm
why you need pyusb? pyserial doesn't work?
to reinstall you can update driver or if still not working just uninstall driver and delete driver software for this device.
Thank you,
Erik
Post by dhylands » Fri Sep 06, 2019 10:26 pm
One thing to check is your boot.py file on the board.
If it has a call to pyb.usb_mode which doesn't include MSC in the string then the pyboard won't show up as a drive.
Post by dhylands » Fri Sep 06, 2019 10:28 pm
pyusb is needed to DFU flash the pyboard (at least if pydfu.py is being used).
Post by jimmo » Sat Sep 07, 2019 12:59 am
If you used Zadig so you can access the DFU, then that's a different VID:PID to "regular" mode, so it shouldn't affect the MSC access. (But maybe you were using pyusb for something other than DFU mode?)
erikblue
Post by erikblue » Mon Sep 09, 2019 3:31 pm
Thanks for all the responses. I tried uninstalling/reinstalling drivers to no avail. I did a Windows 10 system restore to 1 week earlier and that seemed to fix it.
The only thing I did with pyusb was to list usb devices. I didn't read/write any devices, so I'm pretty sure I did something to the registry using zadig that wasn't easy to back out.
Post by jimmo » Thu Sep 12, 2019 11:42 am
Just saw this post on Scott Hanselman's blog, might be useful -- https://www.hanselman.com/blog/HowToFix ... ndows.aspx
