~$ python pyboard.py flash1.py python: can't open file 'pyboard.py': [Errno 2] No such file or directory
Posted: Sat Nov 16, 2019 3:22 am
by lclev
I am trying to migrate from Arduino to pyboard 1.1, which I bought frm adafruit with micropython already installed. I am on Ubuntu 18,04 and am using python3.6.8, which is also new to me. I need to turn on and off two leds in a progressive sequence. This requires a simple for loop with one button to start loop and another to stop it. I have been able to get similar code to work by putting it in the main.py file.
However when i attempt to use $python pyboard.py flash.py I get the following message:~$ python pyboard.py flash1.py
python: can't open file 'pyboard.py': [Errno 2] No such file or directory. I do not see how to obtain this file.
In another approach, I created flash.py and copied it to the pyboard. Using os.listdir(), I can see the file on the pyboard. In the file is a finction with 4 time parameters, e. g. flasher(w,x,y,z,). My plan is to use repyl to import the flash.py file and to use flash.flasher(w,x,y,z) to control the leds with the variable time parameters. However, after importing machine and pyb, I tried to import flash.py I got the following message: File "<stdin>", line 1SyntaxError: invalid syntax.
any help would be appreciated.
lclev
Re: ~$ python pyboard.py flash1.py python: can't open file 'pyboard.py': [Errno 2] No such file or directory
Posted: Sat Nov 16, 2019 7:15 am
by Roberthh
You can find pyboard.py here:
https://github.com/micropython/micropyt ... ster/tools
And if the file flash.py exists on your device, you can load and start that with:
import flash
Since you purchased you device from Adafruit and it came with Python loaded, it is most likely their dialect, called circuitpython. That may behave a little bit different. With Micropython, you can as well type: import flash.py.
Posted: Wed Nov 20, 2019 3:09 am
by lclev
Thank you very much for your reply. I am still stuck with importing files from the pyboard into repl. Essentially, using os.listdir('/flash') I can see the file on the pyboard. When I try to import it, the file is not found. Here is the code from my terminal.
(base) william@william-HP-Compaq-Elite-8300-USDT:~$ rshell
Connecting to /dev/ttyACM0 (buffer-size 512)...
Trying to connect to REPL . connected
Testing if sys.stdin.buffer exists ... Y
Retrieving root directories ... /flash/
Setting time ... Nov 19, 2019 20:28:05
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Welcome to rshell. Use Control-D (or the exit command) to exit rshell.
/home/william> cp vol.py '/flash/'
/home/william> repl
Entering REPL. Use Control-X to exit.
MicroPython v1.11 on 2019-05-29; PYBv1.1 with STM32F405RG
>>> import os
>>> os.listdir('/')
['flash']
['boot.py', 'main.py', 'pybcdc.inf', 'README.txt', 'myflash.py', 'myflash6.py', 'vol.py']
>>> import vol.py
ImportError: no module named 'vol.py'
>>> import machine
>>> import vol.py
vol.py contains a function definition for the volume of a sphere, which works ok in idle.
Any help on this problem would be greatly appreciated as it is critical for what we want to do, namely to control the board by passing parameters to a function using repl. Eventually, I would like to have a GUI programatically doing this.
Regarding pyboard.py, I have to learn how to download files from github. However, once I get the file, how and where do I copy the file to the pyboaard? Same as for vol.py above?
Finally, sometimes I cannot use rshell to connect to the board. The only way I have been able to fix this is to restart Ubuntu. Is this normal?
Thanks again for your help.
lclev
Posted: Wed Nov 20, 2019 5:20 am
by jimmo
In Python (MicroPython and regular Python), if you have a file named foo.py, you import it with "import foo" (no .py on the end).
So you should be able to write "import vol".
pyboard.py is like rshell, it runs on your PC (they do a similar thing). But it looks like rshell is working for you, so maybe stick with that for now.
Posted: Thu Nov 21, 2019 5:48 pm
by lclev
Thanks very much. The code is now working and I am racing forwards to the next bottleneck!
Cheers,
lclev
