Arrays in MicroPython
pandi999
Post by pandi999 » Tue Jan 28, 2020 12:13 pm
Store the value of switch presses and their delay intervals in a variable and try blinking the onboard red LED after 10 second delay according to the switch presses.
Re: Arrays in MicroPython
Post by jimmo » Tue Jan 28, 2020 12:45 pm
Are you looking for a way to do what you describe? Any additional context would be helpful :)
pandi999
Post by pandi999 » Wed Jan 29, 2020 6:42 am
I need to record the value of USR switch of Py board in an array which will run for 10 Seconds and after that read the array which contains the values of USR switch . According to the elements that are stored in array my LED needs to get lighted up.
Post by jimmo » Mon Feb 03, 2020 2:27 am
One important thing is how quickly you want to sample the switch (i.e. how many times per second do you update the array). This will affect how accurately you can measure the timing.
But something like (untested):
import pyb, time
def measure():
  samples = []
  sw = pyb.Switch()
  for i in range(100):
    samples.append(sw.value())
    time.sleep_ms(100)
  return samples
print(measure())
[code]
That will give you a list of 100 True/False values (10 per second).
