yesterday I had a strange events with my PYBv1.1. First of all it started printing same weird error messages on startup about not being able to import pyb, I think due to some name being too long or something like that. But I still could import pyb and use it normal afterwards. Later I though to myself let’s try to update the firmware on my board, for which I used dfu-uti, as I also had problems using the CAN controllers for sending and receiving with two sn65hvd230 chips but this is another story. When I set it into DFU Mode the blue, yellow and red LED glow up very dimly but I could successfully update the firmware with the latest available one.
This is were everything started to go down hills, after I powered the board back up the red and green led started flashing, suggesting an error with the main.py, so I though, okay let's just delete everything in there and start fresh, but I noticed the board wouldn't show up as a USB device anymore. So the first thing I did was to downgrade to the normal 1.12 version of upy, thinking there maybe something wrong with the latest version. But still again after successfully updating the firmware I still wasn’t available and was still flashing the red and green LEDs and then statically red . Next I did some digging and found out how to set it to safe mode. But again it started flashing and after 10 seconds or so, it showed a hard fault but cycling all leds.
So as a last resort I tried resetting it to factory default, but still again after supposedly restoring, it again started to flash and cycle it's LEDs as before. Then today I tried a SD Card with some data and a boot.py file freshly downloaded from the wiki, which should enable the REPL command prompt, but again after reading the card for a few seconds it starts flashing red and green, reboots and loops again. And with the internal storage flashes red and green and then statically red.
As a last resort is there maybe some kind of ftdi link or something else I could use to possibly debug the board and find the fault or is it once and for all bricked?
Cheers
Josh
