Parallel Output of a Byte
John Hasler
Post by John Hasler » Wed Apr 08, 2020 4:06 pm
I need to write a byte to a GPIO port in a single operation. I can use any set of pins and any port. I've searched the documentation and can see no way to do it other than eight seperate pin() operations or using assembler or C.
Re: Parallel Output of a Byte
Post by Roberthh » Wed Apr 08, 2020 6:23 pm
You can use viper code to write directly to a port register, and you can use uctypes.bytearray_at(addr, size) to read & write to a phsical memory location. For viper code, you find a documentation here: http://docs.micropython.org/en/latest/r ... de-emitter
I used that a lot in a SSD1963 driver for direct 8 bit wide port access. The sample driver is here:https://github.com/robert-hh/SSD1963-TF ... /TFT_io.py
John Hasler
Post by John Hasler » Wed Apr 08, 2020 6:41 pm
Viper was the hint I needed. Thank you. Don't know why that was so hard to find.
Post by jimmo » Thu Apr 09, 2020 12:33 am
You can do this without Viper
On the STM32 port there's a 'stm' module which gives you constants for most registers. Combined with machine.mem32 you can pretty much do anything.
import stm
machine.mem32[stm.GPIOA] = ...
Post by Roberthh » Thu Apr 09, 2020 5:15 am
machine.memxx calls are slow. If you need fast actions, viper works better.
