How to properly increase FLASH_FS on pyboardv11?
ltmerlin
Post by ltmerlin » Fri May 22, 2020 10:17 am
Can someone point me in the right direction to increase the FLASH_FS of the pyboardv11?
If have changed the origin of the FLASH_TEXT and the corresponding LENGTHs in stm32f405.ld file:
/* Specify the memory areas */
MEMORY
    FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 1024K /* entire flash */
    FLASH_ISR (rx)  : ORIGIN = 0x08000000, LENGTH = 16K /* sector 0 */
    FLASH_FS (rx)   : ORIGIN = 0x08004000, LENGTH = 496K
    FLASH_TEXT (rx) : ORIGIN = 0x080A0000, LENGTH = 384K
    CCMRAM (xrw)    : ORIGIN = 0x10000000, LENGTH = 64K
    RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 128K
What do I have to change in the flashbdev.c file since I don't know what sector size I need to use... The original file has:
#define FLASH_MEM_SEG1_NUM_BLOCKS (224) // sectors 1,2,3,4: 16k+16k+16k+64k=112k
I changed it to:
#define FLASH_MEM_SEG1_NUM_BLOCKS (1248) // sectors 1,2,3,4,5,6,7,8: 16k+16k+16k+64k+128k+128k+128k+128k=624
and built it but the PYFLASH storage volume, as it appears when resetting the device after flash, still states the standard available pyboard size.
Re: How to properly increase FLASH_FS on pyboardv11?
Post by dhylands » Fri May 22, 2020 5:18 pm
See: viewtopic.php?f=3&t=3702&p=22627&p22627#p22627
You can't just increase the filesystem size i the flash blocks aren't the right sizes.
ltmerlin
Post by ltmerlin » Sun May 24, 2020 8:55 pm
thanks, I indeed had to look at the sector sizes.
I also had to change this in the flashbdev.c:
#define FLASH_MEM_SEG1_NUM_BLOCKS (992) // sectors 1,2,3,4,5,6,7: 16k+16k+16k+64k+128k+128k+128k=496k
I'm not sure why I had to double the value (here 496k) to 992 to get the right number of blocks...
chrismas9
Post by chrismas9 » Sun May 31, 2020 4:22 pm
You can't just keep extending the number of flash sectors on the F4 because the sectors 6 and higher are 128KB and the cache is only 64KB. There is a mechanism in flashbdev.c to use 64KB from each of sectors 6 and 7. Have a look at the F413 port which shows how to get the largest filesystem on F4. You will need to copy the memory layout in the .ld file, mpconfigboard.mk and flashbdev.c
Filesystem blocks are 512 bytes so to get the number of blocks divide the fs size by 512, eg 112K / 512 = 224.
ltmerlin
Post by ltmerlin » Mon Jun 01, 2020 4:36 pm
thanks for the explanation.
the F413 has:
MEMORY
    FLASH_FS (rx)   : ORIGIN = 0x08004000, LENGTH = 176K /* sectors 1,2,3 are 16K, 4 is 64K, 5 is 128K (64K used) for filesystem */
    FLASH_FS2 (rx)  : ORIGIN = 0x08040000, LENGTH = 128K /* sector 6 is 128K (64K used) for filesystem, Total filesystem 240K */
    FLASH_TEXT (rx) : ORIGIN = 0x08060000, LENGTH = 640K /* sectors 7,8,9,10,11  are 128K*/
    SRAM2 (xrw)     : ORIGIN = 0x10000000, LENGTH = 64K
    RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 256K
and in the flashbdev.c:
#define CACHE_MEM_START_ADDR (0x10000000) // SRAM2 data RAM, 64k
#define FLASH_SECTOR_SIZE_MAX (0x10000) // 64k max, size of SRAM2
#define FLASH_MEM_SEG1_START_ADDR (0x08004000) // sector 1
#define FLASH_MEM_SEG1_NUM_BLOCKS (352) // sectors 1,2,3,4,5: 16k+16k+16k+64k+64k(of 128k)=176k
#define FLASH_MEM_SEG2_START_ADDR (0x08040000) // sector 6
#define FLASH_MEM_SEG2_NUM_BLOCKS (128) // sector 6: 64k(of 128k). Filesystem 176K + 64K = 240K
Strangely it "seems" to work for larger values on the STM32F405 when I use:
MEMORY
    FLASH_TEXT (rx) : ORIGIN = 0x08080000, LENGTH = 512K
with flashbdev.c:
#define CACHE_MEM_START_ADDR (0x10000000) // CCM data RAM, 64k
#define FLASH_SECTOR_SIZE_MAX (0x10000) // 64k max, size of CCM
#define FLASH_MEM_SEG1_START_ADDR (0x08004000) // sector 1#define FLASH_MEM_SEG1_NUM_BLOCKS (992) // sectors 1,2,3,4,5,6,7: 16k+16k+16k+64k+128k+128k+128k=496k
Is this possible?
chrismas9
Post by chrismas9 » Tue Jun 02, 2020 4:48 pm
uPy may report the large fs size based on numblocks, but it won't work. Have you tried filling the fs with files, then editing or replacing them? When you try to change a 512 byte sector in a 128KB flash block the whole 128KB has to be backed up in cache RAM while the block is erased. Then the new sector data is written along with all the other sectors from the cache. Since there is only 64KB cache you can't erase/write a 128KB block. Due to the way uPy calculates the next sector address you can only use a half sector (64KB used or 128KB) at the end of a sequence of flash blocks - the last block of FLASH_FS and one block in FLASH_FS2.
You can't get more fs than the F413 port without extending the number of half blocks allowed, either by adding FLASH_FS3, etc or changing the way uPy calculates addresses when the cache is smaller than the block.
