Page 1 of 2
How to properly increase FLASH_FS on pyboardv11?
Posted: Fri May 22, 2020 10:17 am
by ltmerlin
Can someone point me in the right direction to increase the FLASH_FS of the pyboardv11?
If have changed the origin of the FLASH_TEXT and the corresponding LENGTHs in
stm32f405.ld file:
/* Specify the memory areas */
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K /* entire flash */
FLASH_ISR (rx) : ORIGIN = 0x08000000, LENGTH = 16K /* sector 0 */
FLASH_FS (rx) : ORIGIN = 0x08004000, LENGTH = 496K
FLASH_TEXT (rx) : ORIGIN = 0x080A0000, LENGTH = 384K
CCMRAM (xrw) : ORIGIN = 0x10000000, LENGTH = 64K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
What do I have to change in the
flashbdev.c file since I don't know what sector size I need to use... The original file has:
#define FLASH_MEM_SEG1_NUM_BLOCKS (224) // sectors 1,2,3,4: 16k+16k+16k+64k=112k
I changed it to:
#define FLASH_MEM_SEG1_NUM_BLOCKS (1248) // sectors 1,2,3,4,5,6,7,8: 16k+16k+16k+64k+128k+128k+128k+128k=624
and built it but the PYFLASH storage volume, as it appears when resetting the device after flash, still states the standard available pyboard size.
Re: How to properly increase FLASH_FS on pyboardv11?
Posted: Fri May 22, 2020 5:18 pm
by dhylands
See:
viewtopic.php?f=3&t=3702&p=22627&p22627#p22627
You can't just increase the filesystem size i the flash blocks aren't the right sizes.
Posted: Sun May 24, 2020 8:55 pm
by ltmerlin
thanks, I indeed had to look at the sector sizes.
I also had to change this in the flashbdev.c:
#define FLASH_MEM_SEG1_NUM_BLOCKS (992) // sectors 1,2,3,4,5,6,7: 16k+16k+16k+64k+128k+128k+128k=496k
I'm not sure why I had to double the value (here 496k) to 992 to get the right number of blocks...
Posted: Sun May 31, 2020 4:22 pm
by chrismas9
You can't just keep extending the number of flash sectors on the F4 because the sectors 6 and higher are 128KB and the cache is only 64KB. There is a mechanism in flashbdev.c to use 64KB from each of sectors 6 and 7. Have a look at the F413 port which shows how to get the largest filesystem on F4. You will need to copy the memory layout in the .ld file, mpconfigboard.mk and flashbdev.c
Filesystem blocks are 512 bytes so to get the number of blocks divide the fs size by 512, eg 112K / 512 = 224.
Posted: Mon Jun 01, 2020 4:36 pm
by ltmerlin
thanks for the explanation.
the F413 has:
MEMORY
FLASH_FS (rx) : ORIGIN = 0x08004000, LENGTH = 176K /* sectors 1,2,3 are 16K, 4 is 64K, 5 is 128K (64K used) for filesystem */
FLASH_FS2 (rx) : ORIGIN = 0x08040000, LENGTH = 128K /* sector 6 is 128K (64K used) for filesystem, Total filesystem 240K */
FLASH_TEXT (rx) : ORIGIN = 0x08060000, LENGTH = 640K /* sectors 7,8,9,10,11 are 128K*/
SRAM2 (xrw) : ORIGIN = 0x10000000, LENGTH = 64K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 256K
and in the flashbdev.c:
#define CACHE_MEM_START_ADDR (0x10000000) // SRAM2 data RAM, 64k
#define FLASH_SECTOR_SIZE_MAX (0x10000) // 64k max, size of SRAM2
#define FLASH_MEM_SEG1_START_ADDR (0x08004000) // sector 1
#define FLASH_MEM_SEG1_NUM_BLOCKS (352) // sectors 1,2,3,4,5: 16k+16k+16k+64k+64k(of 128k)=176k
#define FLASH_MEM_SEG2_START_ADDR (0x08040000) // sector 6
#define FLASH_MEM_SEG2_NUM_BLOCKS (128) // sector 6: 64k(of 128k). Filesystem 176K + 64K = 240K
Strangely it "seems" to work for larger values on the STM32F405 when I use:
MEMORY
FLASH_TEXT (rx) : ORIGIN = 0x08080000, LENGTH = 512K
with flashbdev.c:
#define CACHE_MEM_START_ADDR (0x10000000) // CCM data RAM, 64k
#define FLASH_SECTOR_SIZE_MAX (0x10000) // 64k max, size of CCM
#define FLASH_MEM_SEG1_START_ADDR (0x08004000) // sector 1#define FLASH_MEM_SEG1_NUM_BLOCKS (992) // sectors 1,2,3,4,5,6,7: 16k+16k+16k+64k+128k+128k+128k=496k
Is this possible?
Posted: Tue Jun 02, 2020 4:48 pm
by chrismas9
uPy may report the large fs size based on numblocks, but it won't work. Have you tried filling the fs with files, then editing or replacing them? When you try to change a 512 byte sector in a 128KB flash block the whole 128KB has to be backed up in cache RAM while the block is erased. Then the new sector data is written along with all the other sectors from the cache. Since there is only 64KB cache you can't erase/write a 128KB block. Due to the way uPy calculates the next sector address you can only use a half sector (64KB used or 128KB) at the end of a sequence of flash blocks - the last block of FLASH_FS and one block in FLASH_FS2.
You can't get more fs than the F413 port without extending the number of half blocks allowed, either by adding FLASH_FS3, etc or changing the way uPy calculates addresses when the cache is smaller than the block.
Posted: Sat Jun 06, 2020 7:26 pm
by ltmerlin
Ok that makes sense!
Thanks for you reply. Your suggestions work and indeed when filling the FS with my first suggested build settings it does really strange things
Posted: Tue Sep 22, 2020 4:36 pm
by SmartTech
I'm trying to reproduce here for PYBV11 (stm32f405) base on the stm32f413, but getting my pyboard doing nothing at boot up. What is the error here?
/micropython/ports/stm32/flashbdev.c
#define FLASH_MEM_SEG1_NUM_BLOCKS (352) // sectors 1,2,3,4,5: 16k+16k+16k+64k+128k=176k
/micropython/ports/stm32/boards/stm32f405.ld
MEMORY
FLASH_FS (rx) : ORIGIN = 0x08004000, LENGTH = 176K /* sectors 1,2,3,4,5 are for filesystem */
FLASH_FS2 (rx) : ORIGIN = 0x08040000, LENGTH = 128K /* sectors 6 are for filesystem 128K/block */
FLASH_TEXT (rx) : ORIGIN = 0x08060000, LENGTH = 640K /* sectors 7,8,9,10,11 */
Posted: Wed Sep 23, 2020 12:47 am
by jimmo
SmartTech wrote: ↑Tue Sep 22, 2020 4:36 pm
What are you trying to do or expecting to happen?
Posted: Wed Sep 23, 2020 2:12 am
by SmartTech
Sorry, I should have been more specific. I'm trying to increase the memory of the flash drive as well. I based my modifications of config for the stm32f405 on the stm32f413 since the section 5 and 6 are similar. Default configuration have 112K of flash. I try to add the 128K of byte 5 and 6 if possible as well. I understand that only 64K of section 5 and 6 can be used. Not sure what happen to the other half, but I dont mind to loose it if I can increase the amount of flash drive.
