I made a Fritzing part for the pyboard, if anyone is interested.
https://github.com/mcauser/Fritzing-Par ... on-pyboard
Fritzing part
Re: Fritzing part
That does look very good. Would be great in my fritzing projects!
Re: Fritzing part
Hi mcauser,
please could you tell me exactly in which folder I've to copy your files?
I've stored heach file into the Fritzing directory where I've find similar files extentions for other components , but when I start Fritzing , I don't see your board. Where I'm wrong?
Thanks.
Thanks.
Thanks. Roberto
Re: Fritzing part
It's a while since I did it but I think this is the procedure. With the Parts pane visible on the right, select My Parts (below Contrib). Click on the menu button to the right of the "My Parts" label and a menu will appear. Select Import and point it at the file. The part remains stored even if you later remove the file (I think in ~/.config/Fritzing/parts/svg/user/schematic). If you submit an fzz file to Fritzing the part is automagically included.
I hope this helps.
I hope this helps.
Re: Fritzing part
Looks great! I don't want to sound nit-picky, but isn't it 'MicroPython' and not 'Micro Python'? Either way, thanks for putting this together.
