vbat connection solution ?
Posted: Thu Jun 11, 2020 10:53 am
by IHOXOHI
I use my pretty pyboard with her housing and lcd160. The result is clean. I can connect properly serverals sensors on Y part without ugly wire. It's perfect. Beautiful and convenient.
But, I need to use vbat for saving time, and I have found a big problem for connect a coin cell properly.
I have tried to solder 2 connections under the board for connect a coin cell althoug the result will produce 2 ugly wires... and a "flying coin cell" like a flying sheet... But I did not succeed. The solder does not take on this points!
If somebody has a solution for a clean connection between a coin cell and the pyboard with a housing, or an other way for save time?
Thanks.
Re: vbat connection solution ?
Posted: Sat Jun 13, 2020 12:58 pm
Why not run the LCD160CR on the X side? This exposes the socket contacts for the battery so it can plug in normally.
Posted: Sun Jun 14, 2020 10:07 pm
by IHOXOHI
Hi Pyth,
I use the pyboard with her housing... So, X or Y position produce same result.
I can pass 2 littles wires by bottom of housing. But result isn't convenient... with a "flying" coin cell.
I will try to solder directly a coin cell "breakout" under the board, ... space could accept a coin cell...
I will post the result...
Posted: Sat Jun 20, 2020 5:55 pm
by IHOXOHI
I have done it.
Nothing outside the housing! Just on top, the lcd160 and one of my different "half protoskin"... Perfect.
Posted: Wed Jun 24, 2020 7:26 am
by IHOXOHI
Big problem!
The coin cell is out in less than 24 hours...
Is it the vback pinout that I have to use?
Otherwise, no way for save time!
Thanks.
Posted: Wed Jun 24, 2020 10:23 am
by chuckbook
The VBACK pin has to be used for RTC backup.
Posted: Wed Jun 24, 2020 10:49 am
Yes. On Pyboard 1.1 VBAT powers the entire Pyboard and is intended for lithium batteries. See this diagram.
Posted: Thu Jun 25, 2020 12:08 am
by IHOXOHI
Ok, thanks.
I have found a solution there : https://elfnor.com/pyboard-datalogger.html
So, coincell-gnd on the pin upper X24, and coincell-V+ on the pin upper X22.
I have tested, and for moment it's all right.
Enjoy.
