I've compiled Pyboard v1.1/Lite v1.0 firmwares with many combinations of single/double precision (float point numbers), threads, network and ulab module, look at :
Firmwares for MicroPython on Pyboard v1.1/Lite v1.0/D SF2/D SF3/D SF6.
- MicroPython v1.12 firmwares without ulab module :
* 12 firmwares with combinations of sp, dp, sp & _thread, dp & _thread, sp & network, dp & network for Pyboard v1.1/Lite v1.0;
- MicroPython v1.12 firmwares with ulab module :
* 11 firmwares with ulab and combinations of sp, dp, sp & _thread, dp & _thread, sp & network, dp & network for Pyboard v1.1/Lite v1.0.
Changed in 2020-08-07 : pointing to https://gitlab.com/rcolistete/micropython-firmwares
Pyboard v1.1/Lite v1.0 firmwares with single/double precision, threads, network and ulab module
- rcolistete
- rcolistete
Re: Pyboard v1.1/Lite v1.0 firmwares with single/double precision, threads, network and ulab module
See "MicroPython v1.12 firmwares with 'ulab' v0.54.0 module for Pyboard v1.1/Lite v1.0/D SF2/D SF3/D SF6" :
* 11 new firmwares with ulab v0.54.0 (released in July 24 2020) and combinations of sp, dp, sp & _thread, dp & _thread, sp & network, dp & network for Pyboard v1.1/Lite v1.0;
* Pyboard Lite v1.0 firmware with ulab, FP64 and network is not possible due to the small flash (512 kB) of Pyboard Lite v1.0, unless you disable ulab sub-modules, but the choice depends on each one's use.
There are also 12 new firmwares without ulab, with combinations of sp, dp, sp & _thread, dp & _thread, sp & network, dp & network for Pyboard v1.1/Lite v1.0.
