[SOLVED] can't connect to REPL
Online
Re: can't connect to REPL
Post by Roberthh » Thu Aug 27, 2020 3:54 pm
Reboot as the big hammer should work.
Post by dhylands » Thu Aug 27, 2020 3:56 pm
If you get the "busy" error that means that some other process already has the port open.
You should be able to use the lsof command to determine who has the port open:
$ lsof | grep ttyACM0
vince
Post by vince » Mon Aug 31, 2020 12:46 pm
[SOLVED!]
Now I found the solution...
1. unplug the pyboard
2. type:
ls /dev/ttyACM*
3. plug the pyboard
4. type:
ls /dev/ttyACM*
5. figure out the new device, this is the pyboard (in my case: /dev/ttyACM3)
6. then, use this new device address to connect!
sudo picocom /dev/ttyACM3
For some reasons :?: I have now other devices :roll: , so the pyboard is now device number 3. :shock:
the solution was found here:
https://subscription.packtpub.com/book/ ... s-the-repl
Online
Re: [SOLVED] can't connect to REPL
Post by Roberthh » Mon Aug 31, 2020 1:07 pm
I had trouble for a while with the modem manager, which tried to capture the pyboard interface and configure it as a modem. That went away after I uninstalled the modem manager,
hitsware
Re: Can't connect to REPL
Post by hitsware » Thu Sep 10, 2020 8:21 pm
I hook up to ACM0 but do not get the prompt ....
Nor does keyboard type to screen ....
Adafruit board works O.K. on same rig ????
