I use a lipo battery on vbat pins...
I ask to myself what's happen when battery is full and pyboard powered by usb. Is there an automatic switch for stop charging bat or have I to check level battery for save it at these times?
Otherway, there isn't indication about level battery.
Is there a procedure for known level battery on pyboard or I have to use the same procedure that Roberthh kindly indicated to me on this post viewtopic.php?f=2&t=8820?
Thanks.
Vbat use
Re: Vbat use
Yop,
Ok, I understood that there isn't a way to charge a battery on pyboard (with fet diode).
No way. I have to use a specific charger like the powerboost 1000c from adafruit for doing that.
I have seen that it looks possible with the pyb-D and wbus28...
