Mouse Click
nedla2004
Mouse Click
Post by nedla2004 » Sun Sep 06, 2015 12:46 am
I recently got a PyBoard, and I am trying to use it as a mouse. I can make my cursor move, but I am trying to make it click when I press the button. Here is my code so far.
main.py
# main.py -- put your code here!
import select
switch = pyb.Switch()
accel = pyb.Accel()
    pyb.hid((0,  0 - accel.x(), 0 - accel.y(), 0))
    if switch():
        #here is where it should click
    pyb.delay(20)
boot.py
# boot.py -- run on boot-up
# can run arbitrary Python, but best to keep it minimal
#pyb.main('main.py') # main script to run after this one
#pyb.usb_mode('CDC+MSC') # act as a serial and a storage device
pyb.usb_mode('CDC+HID') # act as a serial device and a mouse
I am using Windows 8. Thanks!
Re: Mouse Click
Post by dhylands » Sun Sep 06, 2015 2:49 am
If you use pyb.hid() then the format is pyb.hid(buttons, x, y, z))
where buttons is a bit mask. 0x01 for the left mouse button, 0x02 for the right mouse button, and 0x04 for the middle mouse button.
When you call pyb.hid((1,0,0,0)) that will send a mouse down event. You probably want to follow it shortly by pyb.hid((0,0,0,0)) to do a mouse up. A mouse click is a combination of mouse down and mouse up.
You could do a drag by send mouse down, move, mouse up.
pyb.hid is deprecated, and the "proper" way to do things is to do:
hid = pyb.USB_HID()
hid.send((buton, x, y, z))
but I see that isn't actually documented.
