Are there any examples of how to set pins as outputs and then configure them to low or high.
I would certain pins on the STM32 to be set as outputs and set low on startup.
Any help is appreciated.
Harry
Sent from my iPhone using Tapatalk
Initialising GPIO’s in the Hal file or boot.Pty file?
Re: Initialising GPIO’s in the Hal file or boot.Pty file?
When your board resets all of the pins are configured as inputs.
You can configure them as outputs using the first example here: http://docs.micropython.org/en/latest/p ... s-and-gpio
If you need to control the value of your pin before your code gets control then you’ll need to use something like an external pull-up or pull-down resistor.
