swap (or change) uart pins on pyboard
Batman
Post by Batman » Wed Nov 04, 2020 3:29 pm
**I posted this before in the "general discussion" forum. I realized later that I should have posted this here. If there is a way of moving a thread to another part of the forum, I am happy to do so.**
Hi all
Is it possible to change or specify the pins used by the pyboard for RX and TX for a UART port? For example, x9 is used as tx and x10 as RX, per default for UART(1). But I'd like to swap this around.
It seems that the machine module in micropython might allow for this. But I could not get this to work on the pyboard 1.1. Perhaps, this is not possible on this particular board? In particular, the following code falis with the error "TypeError: extra keyword arguments given".
uart = machine.UART(1,baudrate=9600)
uart.init(baudrate=9600, bits=8, parity=None, stop=1,tx=machine.Pin('X9'), rx=machine.Pin('X10'))
Best
Re: swap (or change) uart pins on pyboard
Post by jimmo » Fri Nov 06, 2020 1:54 am
I already replied to your original post - viewtopic.php?f=2&t=9256&p=52059#p52059
