Uasyncio Queue data dirty
skylin008
Post by skylin008 » Mon Dec 14, 2020 10:19 am
Hello, shows my code as follow, this code is reading the CAN bus and forwared to UART.Can1Receiver():If the Can data is not Null, and put them to Queue. Uart4Sender(): reading the Queue data, and send to Uart4 port. There are any issue as show:
In uart4Sender function, get the data from q1.get(), the data[0] is Can Id, data[4] is Can bus data. If recieve two Frame, for example :first ID is: 0x18ff0719, the data is: 0x30 ,0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38.The second Id is: 0x18ff0720, the data is: 0x40, 0x41, 0x42, 0x43, 0x44, 0x45,0x46, 0x47. when received first frame, print('uid:', index),is right. print("udata:",da), is 18ff0719's data.But when run to second print, the string content is second fram's data, is: 0x40, 0x41, 0x42, 0x43, 0x44, 0x45,0x46, 0x47, it belongs to second frame data.what happend, how slove this issue.Thanks!
@micropython.native
def encode(self, data):
index = int(data[0])
da = data[4]
if index == 0x18ff0719:
print('uid:',index) #first print
print('udata:',da)
string = str(index) + ',' + str(len(da)) + ','
temp =','.join([str(i) for i in (list(da))])
string = string + temp
string = '<' + string[0: ] + '>' + '\n'
string = 'can' + string
print(string)
#second print
return string
import gc                                          # garbage collect
import micropython
from pyb import Pin, UART, ADC, ADCAll
import utime
from p import queue         # queue  class
from p import switch        # switch class
from p import delay_ms
import uasyncio
from uasyncio import Lock
def timed_function(f, *args, **kwargs):
    myname = str(f).split(' ')[1]
    def new_func(*args, **kwargs):
        t = utime.ticks_us()
        result = f(*args, **kwargs)
        delta = utime.ticks_diff(utime.ticks_us(), t)
        print('Function {} Time = {:6.3f}ms'.format(myname, delta/1000))
        return result
    return new_func
class device:
    """ IO define for PMU """
    def __init__(self,  debug = False, Initvalue = 0):
        self.debug     = debug
        self.pmicenable         = Pin('B1', Pin.OUT_PP)
        self.pmicpoweron        = Pin('C2', Pin.OUT_PP)
        self.externaldevice     = Pin('B0', Pin.OUT_PP)
        self.stby               = Pin('C5', Pin.OUT_PP)
        self.ahdfunction        = Pin('A8', Pin.OUT_PP)
        self.pmicenable.value(Initvalue)
        self.pmicpoweron.value(Initvalue)
        self.externaldevice.value(Initvalue)
        self.stby.value(Initvalue)
        self.ahdfunction(Initvalue)
    async def io_on(self, val, timeout):
        self.pmicenable.value(val)                      # PB1 Port
        await uasyncio.sleep_ms(100)
        self.externaldevice.value(val)                  # PB0
        await uasyncio.sleep_ms(50)
        self.stby.value(val)                            # PC5
        await uasyncio.sleep_ms(timeout)
        self.pmicpoweron.value(val)                     # PC2 Port
        self.ahdfunction.value(val)                     # PA8
        self.debug and print("Io On ok!\r\n")
    async def io_off(self, val, timeout):
        """ Power Off Sequence """
        self.debug and print("Io Off ok!\r\n")
class adc:
    Read the DC voltage to power on Android.
    when the adc voltage more than 0.87v(DC value is 9v) and
    less than 2.80(DC value is 32v) power up the Android pmu.
    def __init__(self, pin = ADC('C0'), filtercount = 10, debug = False):
        self.adcall = ADCAll(12, 0x70000) # 12 bit resolution, internal channel
        self.vref  = self.adcall.read_core_vref( )      # vref voltage
        self.temp  = self.adcall.read_core_temp( )      # core temp
        self.pin   = pin
        self.filtercount = filtercount                        # filter count
        self.debug = debug
        self.value = self.pin.read()
        self.samples = []                                      # store adc value
        self.mean = 0
    async def read(self):
        '''read adc value '''
        self.v = self.value
        samples = []
        for _ in range(self.filtercount):
            samples.append(self.value)
            await uasyncio.sleep_ms(10)
        samples = sorted(samples)
        self.mean = (samples[int(len(samples)/2)]) * 3.24 / 4095.00         # filter median_mean
        self.debug and print("adc value is:%f", self.mean)
        return self.mean
class canbus:
    """ can bus driver """
    def __init__(self, id = 0x01, channel = 0x01, bitrate = 250, verbose =False):
        from pyb import CAN
        self.verbose = verbose
        self._channel = channel
        self.fifo = channel - 1
        self.can = CAN(self._channel, extframe=True, mode=CAN.NORMAL, prescaler=(2000 // bitrate), sjw=1, bs1=14, bs2=6)
        self.can.setfilter(0, CAN.MASK16, self.fifo, (0, 0, 0, 0))
        self._evt = uasyncio.Event()
        self.buf = bytearray(8)
        self._null_sink =[0, 0, 0, memoryview(self.buf), self.buf]
        self._rx_buf    =[0, 0, 0, memoryview(self.buf), self.buf]
        self.can.rxcallback(self.fifo, self._rxcallback)  # call back
    def _rxcallback(self, bus, reason):
        while self.can.any(self.fifo):
            bus.recv(self.fifo, self._rx_buf)
            self.verbose and print(self._rx_buf)
            self._evt.set()
    def cb_sched(self):
        self._evt.set()
    def flush_fifo(self):
            self.can.recv(self.fifo, list=self._null_sink)
    def read(self):              # read can data from buffer
        if self._evt. is_set():
            self.res = self._rx_buf
            self._evt.clear()
            self.res =''
            self._evt.clear()
        return (self.res)
    def write(self, data, index):
            self.can.send(data, index, timeout=10)
        except:
            return False
        return True
    def state(self):
        return self.can.state()
    def restart(self):
        self.can.restart()
    @micropython.native
        da = data[4]
[color=#FF0000]        if index == 0x18ff0719:
            print('uid:',index)
            print('udata:',da)[/color]
            print(string)[/color]
        return string
class App:
    def __init__(self, verbose= False):
        self.can1 = canbus(id = 0x01, channel = 0x01, bitrate = 250, verbose = False)
        self.can2 = canbus(id = 0x02, channel = 0x02, bitrate = 250, verbose = False)
        self.d     = device()
        self.v     = adc()
        self.sw   = switch_ext()
        self.q1    = queue.Queue(maxsize = 8192)
        self.q2    = queue.Queue(maxsize = 8192)
        self.q3    = queue.Queue(maxsize = 512)  # forward to uart
        self.q4    = queue.Queue(maxsize = 512)  # forward to uart
        self._rx_buff = None
        self._ev = uasyncio.Event()
        self.uart4 = UART(4, 1500000)
        self.uart5 = UART(5, 1500000)
        self.swriter4 = uasyncio.StreamWriter(self.uart4, {})
        self.sreader4 = uasyncio.StreamReader(self.uart4, {})
        self.swriter5 = uasyncio.StreamWriter(self.uart5, {})
        self.sreader5 = uasyncio.StreamReader(self.uart5, {})
    async def start(self):
        self.verbose and print('App Start!\r\n')
        uasyncio.create_task(self.can1Receiver())
        uasyncio.create_task(self.can2Receiver())
        uasyncio.create_task(self.uart4Sender())
        uasyncio.create_task(self.uart4Receiver())
        uasyncio.create_task(self.can1Sender())
        uasyncio.create_task(self.uart5Receiver())
        uasyncio.create_task(self.can2Sender())
        uasyncio.create_task(self.power())
        uasyncio.create_task(self.mem_manage())
            await uasyncio.sleep(0.1)
    async def can1Receiver(self):
        'canbus(1) data receive'
            data =self.can1.read()
            if data is not '':
                await self.q1.put(data)
    async def can1Sender(self):
        """ Canbus Sender """
            if self.can1.state() == 4:
                self.can1.restart()
                await uasyncio.sleep_ms(1)
            msg = ''
            if not self.q4.empty():
                data = await self.q4.get()
                id_ = int.from_bytes(data[:4], 'big')
                msg = (data[4:13])
                if (len(msg)) == 8:
                    self.can1.write(msg,id_)
            await uasyncio.sleep_ms(20)
    async def uart4Receiver(self):
        'Receive data from Android and transfer to Can Bus'
        'protocol1: 0xa5 + 4bytes(address1) + 8bytes(can data) + 1bytes(checksum) + 0x5a + \n'
            sum =0
            res = await self.sreader4.readline()
            if len(res) == 16: # can data forward
                if res[0] == 0xa5 and res[len(res)-2] == 0x5a:
                    for i in range(1,13):
                        sum = (sum + int(res[i]))&0xFF             # checksum one byte
                        #print(sum)
                    if sum == int(res[len(res)- 3]):
                        await self.q4.put(res[1:13])
    async def uart4Sender(self):
        'Forward canbus(1) to UART(4),before the data send,must be encode them '
        string = ''
            while not self.q1.empty():
                data = await self.q1.get()
                string = self.can1.encode(data)
                self.swriter4.write((string))
                await self.swriter4.drain()
            await uasyncio.sleep_ms(0)
    async def mem_manage(self):                                    # garbage management
        """ garbage collect """
            await uasyncio.sleep_ms(1000)                            # delay 1000ms
            gc.collect()
            gc.threshold(gc.mem_free()//4 + gc.mem_alloc())
            #self.verbose and print("mem", gc.mem_free())
app = None
async def main():
    print(__version__)
    gc.collect()
    global app
    app = App(verbose = False)
    await app.start()
def run():
        gc.collect()
        uasyncio.run(main())
    except KeyboardInterrupt:
        print('Interrupt')
    finally:
        uasyncio.new_event_loop()
        print("run again.")
run()
Re: Uasyncio Queue data dirty
Post by pythoncoder » Mon Dec 14, 2020 5:50 pm
It's a tall order for us to debug this substantial program without access to the hardware. I can't see anything obviously wrong with your code which seems use uasyncio effectively. My approach would be to put plenty of print statements in and try to figure out where it's going wrong.
skylin008
Post by skylin008 » Tue Dec 15, 2020 11:36 am
@pythoncode ,Thank you very much!
I had add the print function as follow:
@micropython.native
da = data[4]
if index == 0x18eef0f1:
print('uid:',index)
print('udata:',da)
print('id,length:', string)
print('temp:', temp)
print('sting1:', string)
print('string2', string)
return string
return ''
the return is:
uid: 418312433
udata: bytearray(b'\x00\x01\x02\x03\x04\x05\x06\x07')
id,length: 418312433,8,
temp: 255,255,255,255,255,255,0,0
sting1: 418312433,8,255,255,255,255,255,255,0,0
string2 can<418312433,8,255,255,255,255,255,255,0,0>
uid: 418312433
