Multiple Pyboard update on MAC
Keja
Post by Keja » Sat Jan 23, 2021 11:25 am
I'm working on a project where I have 2 pyboard connected on my Macbook . The Mac only sees the latest one connected as a drive making it painful to update the code on both pyboards at the same time. I 'm able to have the REPL on both as both pyboard show up when I do
ls /dev/tty.usb*
/dev/tty.usbmodem2075319E4E532	/dev/tty.usbmodem2081319D4E532
but as mentioned before only one of the pyboard appear as a disk
diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *500.3 GB   disk0
   1:                        EFI EFI                     314.6 MB   disk0s1
   2:                 Apple_APFS Container disk1         500.0 GB   disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +500.0 GB   disk1
                                 Physical Store disk0s2
   1:                APFS Volume Macintosh HD            11.2 GB    disk1s1
   2:                APFS Volume Macintosh HD - Data     54.6 GB    disk1s2
   3:                APFS Volume Preboot                 82.9 MB    disk1s3
   4:                APFS Volume Recovery                528.9 MB   disk1s4
   5:                APFS Volume VM                      1.1 GB     disk1s5
/dev/disk2 (external, physical):
   0:     FDisk_partition_scheme                        *245.8 KB   disk2
   1:                 DOS_FAT_12 PYBFLASH                114.7 KB   disk2s1
Has anyone managed to overcome this limiation on MAC ?
Thank you for reading
Nicolas
Re: Multiple Pyboard update on MAC
Post by dhylands » Sat Jan 23, 2021 4:55 pm
Try plugging in your first MicroPython board. Then go into Finder and Right Click on PYBFLASH and choose 'Rename "PYBFLASH"' and give it a new name.
Then when you plug in the second board it won't collide.
Keja
Post by Keja » Sat Jan 23, 2021 5:35 pm
thank you , that did the trick :)
Post by jimmo » Mon Jan 25, 2021 12:13 am
In general I'd avoid using the usb storage interface and instead transfer files using either rshell, pyboard.py or mpr. It's much more reliable and less likely to lead to surprises.
Keja
Post by Keja » Mon Jan 25, 2021 7:16 pm
Is it possible to use the tools you mentioned in parrallel of picocom (this is what I use for the REPL) ? I need access the REPL on both pyboards to make my tests.
I also have some WiPys and LoPys boards for which I use Pymakr Atom plugin and it's quite handy to update new code and have access at the REPL in on place.
Post by Roberthh » Mon Jan 25, 2021 7:25 pm
All of pyboard.py or mpr us the USB interface for updating. rshell too, but can also be configured to use ftp. For Pyboard D, ESP32 or ESP8266 I prefer to use an ftp client, FileZilla, in combination with an ftp server on the target board (https://github.com/robert-hh/FTP-Server ... 2-and-PYBD), which uses teh same callback mechanism as WEBREPL to run in background.
Post by jimmo » Tue Jan 26, 2021 1:23 am
Sort of, but it depends what you mean.
My most common use case is to do:
pyboard.py --device /dev/ttyACM0 path/to/code.py
Which will run code.py on the device and print the output.
If I want to get to the REPL, then I Ctrl-C that, and then use miniterm to connect.
rshell also has a way to switch in and out of REPL and transfer modes.
With mpr, you don't need to ever leave the REPL, because you don't copy files to the device. The files are accessed remotely from your PC.
Post by dhylands » Tue Jan 26, 2021 6:50 pm
In general, you only want one program to have the serial port open at a time. Otherwise when characters are sent from the pyboard some characters will go to one program, and some characters will go to the other program.
rshell has a `repl` command which will make it behave like a terminal editor. You need to use Control-X to exit from the repl and get back into rshell to say allow copying files again.
My typical workflow in rshell is to use a command like:
cp somefile.py /flash; repl ~ import somefile
Then if I hit an error, I edit the file using my editor and back in rshell I do Control-X to exit the repl, press the up arrow to retrieve the previous command and press enter.
