22 tests failed for v1.7-45-g44ab5c3. This was my first build on full Debian in a VM (previously I was using only Raspberry Pi), and tests run from both Debian and Raspberry Pi. Build is from scratch, so everything should be current. Flash appeared to be successful, no errors reported.
Startup:
�ò�ì�pìl�xcl`��do�xsläd�÷ioctl(1, 0)
ioctl(5, 0)
readblocks(0, 3ffeeda0(4096))
readblocks(2, 3ffeedf0(4096))
could not open file 'boot.py' for reading
could not open file 'main.py' for reading
#4 ets_task(4010029c, 3, 3fff4668, 4)
MicroPython v1.7-45-g44ab5c3 on 2016-04-13; ESP module with ESP8266
I fetched all the latest code like this (see post for my full build process:
http://forum.micropython.org/viewtopic.php?f=16&t=1720):
git submodule update --init
git fetch origin
git pull
# the next git commmands are suggested on https://github.com/pfalcon/esp-open-sdk
git submodule sync
Both the old test script, then fresh git fetch test script resulted in errors.
Here is the full output:
pi@rp-machine ~/workspace/micropython/tests $ ./run-tests --target esp8266 --device /dev/ttyUSB0
pass basics/0prelim.py
pass basics/andor.py
pass basics/array1.py
pass basics/array_add.py
pass basics/array_construct.py
pass basics/array_construct2.py
pass basics/array_construct_endian.py
File "basics/array_q.py", line 5, in <module>
print(array('q'))
ValueError: bad typecode (must be b, B, u, h, H, i, I, l, L, f or d)
FAIL basics/array_q.py
pass basics/assign1.py
pass basics/async_await.py
pass basics/async_await2.py
pass basics/async_for.py
pass basics/async_for2.py
pass basics/async_with.py
pass basics/async_with2.py
File "basics/attrtuple1.py", line 5, in <module>
t = sys.implementation
AttributeError: 'module' object has no attribute 'implementation'
FAIL basics/attrtuple1.py
pass basics/bool1.py
pass basics/boundmeth1.py
pass basics/break.py
pass basics/builtin_abs.py
pass basics/builtin_allany.py
pass basics/builtin_bin.py
pass basics/builtin_callable.py
pass basics/builtin_chr.py
skip basics/builtin_compile.py
pass basics/builtin_dir.py
pass basics/builtin_divmod.py
pass basics/builtin_ellipsis.py
pass basics/builtin_eval.py
pass basics/builtin_eval_error.py
pass basics/builtin_hash.py
pass basics/builtin_hex.py
pass basics/builtin_id.py
pass basics/builtin_issubclass.py
pass basics/builtin_len1.py
File "basics/builtin_minmax.py", line 34, in <module>
print(min([1, 2, 3, 4, 5], default=-1))
TypeError: min() got an unexpected keyword argument
FAIL basics/builtin_minmax.py
pass basics/builtin_oct.py
pass basics/builtin_ord.py
pass basics/builtin_override.py
pass basics/builtin_pow.py
pass basics/builtin_property.py
File "basics/builtin_range.py", line 38, in <module>
print(range(1, 2, 3).start)
AttributeError: 'range' object has no attribute 'start'
FAIL basics/builtin_range.py
pass basics/builtin_reversed.py
pass basics/builtin_round.py
pass basics/builtin_slice.py
pass basics/builtin_sorted.py
pass basics/builtin_sum.py
pass basics/builtin_type.py
pass basics/bytearray1.py
pass basics/bytearray_add.py
pass basics/bytearray_append.py
pass basics/bytearray_construct.py
pass basics/bytearray_construct_endian.py
pass basics/bytearray_longint.py
pass basics/bytearray_slice_assign.py
File "basics/bytes.py", line 4
print(rb'123')
SyntaxError: invalid syntax
FAIL basics/bytes.py
pass basics/bytes_add.py
pass basics/bytes_add_endian.py
pass basics/bytes_compare.py
pass basics/bytes_compare2.py
pass basics/bytes_construct.py
pass basics/bytes_construct_endian.py
pass basics/bytes_count.py
pass basics/bytes_find.py
pass basics/bytes_format_modulo.py
pass basics/bytes_gen.py
pass basics/bytes_large.py
pass basics/bytes_mult.py
pass basics/bytes_partition.py
pass basics/bytes_replace.py
pass basics/bytes_split.py
pass basics/bytes_strip.py
pass basics/bytes_subscr.py
pass basics/class1.py
pass basics/class2.py
pass basics/class3.py
pass basics/class_bind_self.py
pass basics/class_binop.py
pass basics/class_call.py
pass basics/class_contains.py
skip basics/class_descriptor.py
pass basics/class_emptybases.py
pass basics/class_getattr.py
pass basics/class_inherit1.py
pass basics/class_inherit_mul.py
pass basics/class_instance_override.py
pass basics/class_item.py
pass basics/class_new.py
pass basics/class_number.py
pass basics/class_staticclassmethod.py
pass basics/class_store.py
pass basics/class_store_class.py
pass basics/class_str.py
pass basics/class_super.py
pass basics/class_super_object.py
pass basics/class_use_other.py
pass basics/closure1.py
pass basics/closure2.py
pass basics/closure_defargs.py
pass basics/closure_manyvars.py
pass basics/closure_namedarg.py
pass basics/compare_multi.py
pass basics/comprehension1.py
pass basics/containment.py
pass basics/continue.py
pass basics/decorator.py
pass basics/del_attr.py
pass basics/del_deref.py
pass basics/del_global.py
pass basics/del_local.py
pass basics/del_name.py
pass basics/del_subscr.py
pass basics/dict1.py
pass basics/dict2.py
pass basics/dict_clear.py
pass basics/dict_construct.py
pass basics/dict_copy.py
^[[B^[[B^[[Bpass basics/dict_del.py
pass basics/dict_from_iter.py
pass basics/dict_fromkeys.py
pass basics/dict_get.py
pass basics/dict_intern.py
pass basics/dict_iterator.py
pass basics/dict_pop.py
pass basics/dict_popitem.py
pass basics/dict_setdefault.py
pass basics/dict_specialmeth.py
pass basics/dict_update.py
pass basics/dict_views.py
pass basics/enumerate.py
pass basics/equal.py
pass basics/equal_class.py
pass basics/except_match_tuple.py
File "basics/exception1.py", line 13, in <module>
print(s.value)
AttributeError: 'StopIteration' object has no attribute 'value'
FAIL basics/exception1.py
skip basics/exception_chain.py
pass basics/exceptpoly.py
pass basics/exceptpoly2.py
pass basics/exec1.py
pass basics/filter.py
pass basics/floordivide.py
pass basics/for1.py
pass basics/for2.py
pass basics/for3.py
pass basics/for_break.py
pass basics/for_range.py
pass basics/for_return.py
pass basics/frozenset1.py
pass basics/frozenset_add.py
pass basics/frozenset_binop.py
pass basics/frozenset_copy.py
pass basics/frozenset_difference.py
pass basics/frozenset_set.py
pass basics/fun1.py
pass basics/fun2.py
pass basics/fun3.py
pass basics/fun_annotations.py
pass basics/fun_calldblstar.py
pass basics/fun_callstar.py
pass basics/fun_callstardblstar.py
pass basics/fun_defargs.py
pass basics/fun_defargs2.py
pass basics/fun_error.py
pass basics/fun_kwargs.py
pass basics/fun_kwonly.py
pass basics/fun_kwonlydef.py
pass basics/fun_kwvarargs.py
pass basics/fun_largestate.py
skip basics/fun_name.py
pass basics/fun_str.py
pass basics/fun_varargs.py
pass basics/gc1.py
File "basics/gen_yield_from.py", line 9
print((yield from gen()))
FAIL basics/gen_yield_from.py
File "basics/gen_yield_from_close.py", line 9
FAIL basics/gen_yield_from_close.py
File "basics/gen_yield_from_ducktype.py", line 16
yield from MyGen()
FAIL basics/gen_yield_from_ducktype.py
File "basics/gen_yield_from_exc.py", line 8
FAIL basics/gen_yield_from_exc.py
File "basics/gen_yield_from_iter.py", line 2
yield from (1, 2, 3)
FAIL basics/gen_yield_from_iter.py
File "basics/gen_yield_from_send.py", line 6
FAIL basics/gen_yield_from_send.py
File "basics/gen_yield_from_throw.py", line 10
FAIL basics/gen_yield_from_throw.py
File "basics/generator1.py", line 12
return None
SyntaxError: 'return' with argument inside generator
FAIL basics/generator1.py
pass basics/generator2.py
pass basics/generator_args.py
pass basics/generator_close.py
pass basics/generator_closure.py
pass basics/generator_exc.py
File "basics/generator_return.py", line 3
return 42
FAIL basics/generator_return.py
pass basics/generator_send.py
pass basics/getattr.py
pass basics/getattr1.py
pass basics/getitem.py
pass basics/globals_del.py
pass basics/hasattr1.py
pass basics/ifcond.py
pass basics/int1.py
pass basics/int2.py
pass basics/int_big_and.py
pass basics/int_big_and2.py
pass basics/int_big_and3.py
pass basics/int_big_cmp.py
pass basics/int_big_div.py
pass basics/int_big_error.py
pass basics/int_big_lshift.py
pass basics/int_big_mod.py
pass basics/int_big_mul.py
pass basics/int_big_or.py
pass basics/int_big_or2.py
pass basics/int_big_or3.py
pass basics/int_big_pow.py
pass basics/int_big_rshift.py
pass basics/int_big_unary.py
pass basics/int_big_xor.py
pass basics/int_big_xor2.py
pass basics/int_big_xor3.py
pass basics/int_big_zeroone.py
pass basics/int_bytes.py
pass basics/int_constfolding.py
pass basics/int_divmod.py
pass basics/int_divzero.py
pass basics/int_long.py
pass basics/int_mpz.py
pass basics/int_small.py
pass basics/is_isnot.py
pass basics/iter0.py
pass basics/iter1.py
pass basics/iter2.py
pass basics/iter_of_iter.py
pass basics/lambda1.py
pass basics/lambda_defargs.py
File "basics/lexer.py", line 48, in <module>
exec(r"b'\x0'")
ValueError: invalid \x escape
FAIL basics/lexer.py
pass basics/list1.py
File "basics/list_clear.py", line 3, in <module>
x.clear()
AttributeError: 'list' object has no attribute 'clear'
FAIL basics/list_clear.py
pass basics/list_compare.py
File "basics/list_copy.py", line 3, in <module>
b = a.copy()
AttributeError: 'list' object has no attribute 'copy'
FAIL basics/list_copy.py
pass basics/list_count.py
pass basics/list_extend.py
pass basics/list_index.py
pass basics/list_insert.py
pass basics/list_mult.py
pass basics/list_pop.py
pass basics/list_remove.py
pass basics/list_reverse.py
pass basics/list_slice.py
pass basics/list_slice_3arg.py
pass basics/list_slice_assign.py
pass basics/list_slice_assign_grow.py
pass basics/list_sort.py
pass basics/list_sum.py
pass basics/map.py
pass basics/memoryerror.py
File "basics/memoryview1.py", line 19, in <module>
m[0] = 1
TypeError: 'int' does not support the buffer interface
FAIL basics/memoryview1.py
File "basics/memoryview_gc.py", line 6, in <module>
m[i] = i
FAIL basics/memoryview_gc.py
pass basics/module1.py
pass basics/module2.py
pass basics/namedtuple1.py
pass basics/object1.py
pass basics/object_dict.py
pass basics/object_new.py
pass basics/op_error.py
skip basics/ordereddict1.py
skip basics/parser.py
pass basics/print.py
pass basics/python34.py
pass basics/return1.py
pass basics/scope.py
pass basics/self_type_check.py
pass basics/seq_unpack.py
pass basics/set1.py
pass basics/set_add.py
pass basics/set_binop.py
pass basics/set_clear.py
pass basics/set_copy.py
pass basics/set_difference.py
pass basics/set_discard.py
pass basics/set_intersection.py
pass basics/set_isdisjoint.py
pass basics/set_isfooset.py
pass basics/set_iter.py
pass basics/set_pop.py
pass basics/set_remove.py
pass basics/set_specialmeth.py
pass basics/set_symmetric_difference.py
pass basics/set_union.py
pass basics/set_unop.py
pass basics/set_update.py
pass basics/setattr1.py
skip basics/slice_attrs.py
pass basics/slots_bool_len.py
File "basics/string1.py", line 6
print(u'abc')
FAIL basics/string1.py
pass basics/string_compare.py
pass basics/string_count.py
pass basics/string_cr_conversion.py
pass basics/string_crlf_conversion.py
pass basics/string_endswith.py
pass basics/string_escape.py
pass basics/string_find.py
pass basics/string_format.py
pass basics/string_format2.py
pass basics/string_format_error.py
pass basics/string_format_modulo.py
pass basics/string_index.py
pass basics/string_istest.py
pass basics/string_join.py
pass basics/string_large.py
pass basics/string_mult.py
pass basics/string_partition.py
pass basics/string_replace.py
pass basics/string_repr.py
pass basics/string_rfind.py
pass basics/string_rindex.py
pass basics/string_rpartition.py
pass basics/string_rsplit.py
pass basics/string_slice.py
pass basics/string_split.py
File "basics/string_splitlines.py", line 12, in <module>
print("foo\nbar".splitlines(keepends=True))
TypeError: splitlines() takes no keyword arguments
skip basics/string_splitlines.py
pass basics/string_startswith.py
pass basics/string_strip.py
pass basics/string_upperlow.py
pass basics/struct1.py
pass basics/subclass_classmethod.py
pass basics/subclass_native1.py
pass basics/subclass_native2_list.py
pass basics/subclass_native2_tuple.py
pass basics/subclass_native3.py
pass basics/subclass_native4.py
pass basics/subclass_native5.py
pass basics/subclass_native_buffer.py
pass basics/subclass_native_cmp.py
pass basics/subclass_native_specmeth.py
pass basics/syntaxerror.py
File "basics/sys1.py", line 10, in <module>
print(sys.implementation.name in ('cpython', 'micropython'))
FAIL basics/sys1.py
pass basics/true_value.py
pass basics/try1.py
pass basics/try2.py
pass basics/try3.py
pass basics/try4.py
pass basics/try_as_var.py
pass basics/try_continue.py
pass basics/try_error.py
pass basics/try_finally1.py
pass basics/try_finally_loops.py
pass basics/try_finally_return.py
pass basics/try_finally_return2.py
pass basics/try_reraise.py
pass basics/try_reraise2.py
pass basics/tuple1.py
pass basics/tuple_compare.py
pass basics/tuple_count.py
pass basics/tuple_index.py
pass basics/tuple_mult.py
pass basics/types1.py
pass basics/types2.py
pass basics/unary_op.py
pass basics/unboundlocal.py
pass basics/unpack1.py
pass basics/while1.py
pass basics/while_cond.py
pass basics/while_nest_exc.py
pass basics/with1.py
pass basics/with_break.py
pass basics/with_continue.py
pass basics/with_return.py
pass basics/zip.py
skip extmod/machine1.py
skip extmod/machine_mem.py
pass extmod/sha256.py
pass extmod/time_ms_us.py
pass extmod/ubinascii_a2b_base64.py
pass extmod/ubinascii_b2a_base64.py
pass extmod/ubinascii_hexlify.py
pass extmod/ubinascii_unhexlify.py
pass extmod/uctypes_array_assign_le.py
pass extmod/uctypes_array_assign_native_le.py
pass extmod/uctypes_bytearray.py
pass extmod/uctypes_le.py
pass extmod/uctypes_le_float.py
pass extmod/uctypes_native_float.py
pass extmod/uctypes_native_le.py
pass extmod/uctypes_ptr_le.py
pass extmod/uctypes_ptr_native_le.py
pass extmod/uctypes_sizeof.py
pass extmod/uctypes_sizeof_native.py
pass extmod/uheapq1.py
pass extmod/ujson_dumps.py
pass extmod/ujson_dumps_extra.py
pass extmod/ujson_dumps_float.py
pass extmod/ujson_loads.py
pass extmod/ujson_loads_float.py
pass extmod/urandom_basic.py
skip extmod/urandom_extra.py
pass extmod/ure1.py
pass extmod/ure_error.py
pass extmod/ure_group.py
pass extmod/ure_namedclass.py
pass extmod/ure_split.py
skip extmod/vfs_fat_ramdisk.py
pass extmod/zlibd_decompress.py
pass float/array_construct.py
pass float/builtin_float_minmax.py
pass float/builtin_float_round.py
skip float/bytearray_construct.py
skip float/bytes_construct.py
skip float/cmath_fun.py
skip float/cmath_fun_special.py
skip float/complex1.py
pass float/float1.py
skip float/float2int.py
skip float/float2int_doubleprec.py
pass float/float2int_fp30.py
pass float/float_array.py
skip float/float_divmod.py
pass float/float_divmod_relaxed.py
pass float/float_struct.py
skip float/int_big_float.py
pass float/int_divzero.py
pass float/int_power.py
pass float/list_index.py
pass float/math_fun.py
pass float/math_fun_bool.py
File "float/math_fun_special.py", line 16, in <module>
('log2', log2, test_values),
NameError: name 'log2' is not defined
skip float/math_fun_special.py
skip float/string_format.py
pass float/string_format2.py
pass float/string_format_fp30.py
pass float/string_format_modulo.py
pass float/string_format_modulo2.py
skip float/true_value.py
skip float/types.py
pass micropython/const.py
pass micropython/const_error.py
pass micropython/decorator.py
pass micropython/decorator_error.py
pass micropython/heapalloc.py
skip micropython/meminfo.py
skip micropython/memstats.py
skip micropython/native_closure.py
skip micropython/native_const.py
skip micropython/native_misc.py
skip micropython/viper_addr.py
skip micropython/viper_args.py
skip micropython/viper_binop_arith.py
skip micropython/viper_binop_comp.py
skip micropython/viper_binop_comp_imm.py
skip micropython/viper_binop_multi_comp.py
skip micropython/viper_cond.py
skip micropython/viper_error.py
skip micropython/viper_misc.py
skip micropython/viper_ptr16_load.py
skip micropython/viper_ptr16_store.py
skip micropython/viper_ptr32_load.py
skip micropython/viper_ptr32_store.py
skip micropython/viper_ptr8_load.py
skip micropython/viper_ptr8_store.py
skip micropython/viper_subscr.py
pass misc/features.py
pass misc/non_compliant.py
pass misc/non_compliant_lexer.py
pass misc/print_exception.py
pass misc/recursion.py
pass misc/recursive_data.py
pass misc/recursive_iternext.py
skip misc/rge_sm.py
skip misc/sys_exc_info.py
412 tests performed (13111 individual testcases)
390 tests passed
48 tests skipped: builtin_compile class_descriptor exception_chain fun_name ordereddict1 parser slice_attrs string_splitlines machine1 machine_mem urandom_extra vfs_fat_ramdisk bytearray_construct bytes_construct cmath_fun cmath_fun_special complex1 float2int float2int_doubleprec float_divmod int_big_float math_fun_special string_format true_value types meminfo memstats native_closure native_const native_misc viper_addr viper_args viper_binop_arith viper_binop_comp viper_binop_comp_imm viper_binop_multi_comp viper_cond viper_error viper_misc viper_ptr16_load viper_ptr16_store viper_ptr32_load viper_ptr32_store viper_ptr8_load viper_ptr8_store viper_subscr rge_sm sys_exc_info
22 tests failed: array_q attrtuple1 builtin_minmax builtin_range bytes exception1 gen_yield_from gen_yield_from_close gen_yield_from_ducktype gen_yield_from_exc gen_yield_from_iter gen_yield_from_send gen_yield_from_throw generator1 generator_return lexer list_clear list_copy memoryview1 memoryview_gc string1 sys1
edit: I am using a "Geekcreit" board like this one:
http://www.banggood.com/Geekcreit-Doit- ... 85891.html
