Reading VCC level
Reading VCC level
ESP8266 has the ability to read the Vcc voltage using the internal ADC. Looking at the source, this is enabled in micropython by reading ADC channel 1 (instead of channel 0 for the 'real' ADC). However, this seems to require defining ESP_INIT_DATA_ENABLE_READVDD33 in user_config.h prior to compiling the firmware (source: http://nodemcu.readthedocs.io/en/dev/en ... creadvdd33 ). I've tried doing this and flashing the re-compiled firmware, but the firmware files are identical to not having set this, and reading ADC(1) always gives 65535. Any ideas?
Re: Reading VCC level
I came across this topic when playing with LUA and NodeMCU.
There was a discussion in the Espressif BBS http://bbs.espressif.com/viewtopic.php? ... dd33#p2922.
Perhaps this is helpful.
In that referenced topic Espressif_Faye made an interesting addition to the dependencies to make the internal VCC reading work: "RF is enabled"
I do not want to hijack the topic, so i made up another one for my Huzzah Feather voltage monitoring issues.
