Change hostname.
kurtsik
Change hostname.
Post by kurtsik » Sat Aug 13, 2016 11:18 am
Hello.
I'm trying to change the board hostname but I can't. Please, could you tell my in which file is set?
Thanks in advance.
MODERATOR NOTE: I moved this to ESP8266 since I assume that's the board you're using?
Re: Change hostname.
Post by pythoncoder » Sun Aug 14, 2016 8:16 am
jms
Post by jms » Mon Aug 15, 2016 10:09 am
I don't understand what hostname is in this context. It is a concept more heavyweight operating systems have and the normal place to read it is through os.uname()
deshipu
Post by deshipu » Mon Aug 15, 2016 12:48 pm
It means what the esp8266 sends to the DHCP server on the local network when requesting an IP address.
jms
Post by jms » Mon Aug 15, 2016 1:31 pm
Thanks. That's exactly the kind of answer that makes me happy.
Why not have the DHCP server key on MAC address instead ? The MAC addresses ought to be unique (if not you've got big trouble anyway) and all belong to a block issued to the manufacturer.
deshipu
Post by deshipu » Mon Aug 15, 2016 1:57 pm
The DHCP server already gets the MAC address -- it's required by the protocol. The hostname is supposed to be a human-readable convenience, so that you can see on the router's side which address is which.
bguenthe
Post by bguenthe » Mon Sep 05, 2016 10:53 am
Sorry, but I'm blind. I cannot find in the documentaion from pythoncoder (http://docs.micropython.org/en/latest/e ... ckref.html?) where I can set the hostname?
deshipu
Post by deshipu » Mon Sep 05, 2016 12:18 pm
I don't think you can.
Post by pythoncoder » Tue Sep 06, 2016 8:02 am
Apologies. Looking again at the doc I referenced, there's nothing.
bguenthe
Post by bguenthe » Thu Sep 08, 2016 10:44 am
No problem! I only wat to make shure that I didnÄt miss something.
After an internet research I found this: http://www.esp8266.com/viewtopic.php?p=22608 There is an function for setting the hostname in the ESP-SDK named wifi_station_set_hostname().
I think someone has to implement a new method in the ESP- or network- or WLAN-module? But to be hornest, this is not rellay important :D
