BBC MicroBit radio send/receive - data packet is not a string?
Questions and discussion about running MicroPython on a micro:bit board.
Target audience: MicroPython users with a micro:bit.
joolsbamford
Post by joolsbamford » Mon Oct 10, 2016 11:41 pm
Evening all,
I am trying to get a seemingly simple remote control car project to work with 2 Microbits but keep getting the same error message. The controller code measures which way the controller is being tilted and sends out a f,b,l or r message to the motor board. The controller code seems to work fine.
The driver microbit always returns an error for the radio.receive() line - data packet received is not a string. This happens as soon as I tilt the controller. I have played around with the code and looked at similar examples online but cannot see where the problem is.
I use Mu which I downloaded a few weeks ago and it has worked fine. I just don't know where I am going wrong here and would like to have it ready to show the kids at this week's code club.
I have commented out the motor board outputs and am asking the driver microbit to just display images until i work this out.
Thanks in advance for any help. Let me know if you need any more info.
____Controller code____
from microbit import *
import radio
radio.on()
readingy = accelerometer.get_y()
readingx = accelerometer.get_x()
if readingy > 550:
display.show(Image.ARROW_S)
radio.send('b')
elif readingy < -550:
display.show(Image.ARROW_N)
radio.send('f')
elif readingx < -550:
display.show(Image.ARROW_W)
radio.send('l')
elif readingx > 550:
display.show(Image.ARROW_E)
radio.send('r')
display.show("-")
____Driver code____
import radio
radio.on()
msgin = radio.receive() ## error always reported on this line
if msgin == 'f':
#pin12.write_digital(1)
#pin16.write_digital(1)
elif msgin == 'b':
#pin8.write_digital(1)
#pin0.write_digital(1)
elif msgin == 'l':
elif msgin == 'r':
#pin12.write_digital(0)
#pin16.write_digital(0)
#pin8.write_digital(0)
#pin0.write_digital(0)
display.show("-")
deshipu
Re: BBC MicroBit radio send/receive - data packet is not a string?
Post by deshipu » Tue Oct 11, 2016 8:02 am
That looks like you found a bug. What happens when you send longer strings than a single character?
joolsbamford
Post by joolsbamford » Tue Oct 11, 2016 7:35 pm
Thanks for the reply. Always get the same message. I started using forward, backwards, left and right. When this didn't work I Shortened it as shown in code. Also tried numbers. Also tried Send_bytes and receive_bytes. Same error msg every time.
deshipu
Post by deshipu » Tue Oct 11, 2016 9:48 pm
I dug out the second micro:bit and tested your code, and I can reproduce your problem in 100%. It seems that the sending program is the problem, I'm investigating further.
deshipu
Post by deshipu » Tue Oct 11, 2016 9:52 pm
Seems like the problem is sending the strings very fast in the while loop without any pause.
If I add a sleep(1) after every radio.send(), the program works as intended.
joolsbamford
Post by joolsbamford » Wed Oct 12, 2016 5:59 am
Good work. Thank you.
I will try that when I get back from work tonight. I think I tried some sleep commands in the driver code but it didn't solve the problem. I didn't think to add them to the sending code as you suggest.
It will be really great to get this working for the kids on Thursday.
Thanks again!
joolsbamford
Post by joolsbamford » Thu Oct 13, 2016 5:58 am
I had a play with it and got it working just right for me by adding sleep(50) to both the controller and driver code. I found I had to add a sleep to both codes to get the desired result. :D
Thanks for all your help.
_____CONTROLLER_____
import radio
radio.on()
if readingy > 550:
radio.send('b')
sleep(50)
radio.send('f')
sleep(50)
radio.send('l')
sleep(50)
radio.send('r')
sleep(50)
display.show("-")
_____DRIVER_____
import radio
radio.on()
if msgin == 'f':
sleep(50)
elif msgin == 'b':
sleep(50)
elif msgin == 'l':
sleep(50)
elif msgin == 'r':
sleep(50)
display.show("-")
deshipu
Post by deshipu » Thu Oct 13, 2016 6:52 am
Another solution would be to just wrap the receive in a try-except and catch and ignore the exception.
titimoby
Post by titimoby » Tue Oct 18, 2016 8:23 pm
This code looks promising.
I tried it but nothing seems to be received.
Is there a way to have some debug details?
One thing I wonder is: do I need to specify the radio channel in each board?
Like adding radio.config(channel=7) in each code to be sure?
Edit: that's it
I had to precise the radio.config(channel=7) on both code.
To be able to see the change on the receiver, I had to add a sleep(100) after each display.show
Thanks a million, I have something to add for the most advanced kids in my workshop on Sunday!
