I am developing HVAC device controller board based on CC3200. Because of limited RAM resources I had to put most of the code into cross-compiled module containing one class which I instantiate in main.py and call function with main loop. Because of the fact that uploading .py files to Linux server, cross-compiling and downloading it to the MP host takes some time and also because not all error messages are displayed when errors are caused by cross-compiled code I removed main loop function from the cross-compiled module and created new class in main.py which is inherited from class from cross-compiled module and which defines the main loop function. When the main loop function will be fully developed, I will probably put it back into the class in cross-compiled module.
The question is - can I expect some issues from this approach?
Cross compiled module vs class inheritance
Re: Cross compiled module vs class inheritance
I can't give a definitive answer because I haven't done exactly what you're trying to do. However I use frozen bytecode (which is cross-compiled) on the Pyboard and routinely freeze stable code on big projects. I've subclassed frozen classes and had frozen modules import classes from regular modules and it all "just works". You could create a simple test case or use git to branch your project to try it and see if it works. I'd be surprised if it didn't.
I'm using this works-stream all the time, especially with ESP8266 and also for code embedded in flash. I have not observed that messages are not displayed. The only hiccup that happens from time to time is mpy-cross not being up-to-date. So I typically rebuild it after a repository update.
Thank you for your answers. I am working with CC3200 so unfortunately I cannot use frozen bytecode from flash. But it is good to know it works also in this case.
I am using this approach for several days and there were no issues directly related to inheriting classes from cross-compiled modules.
@pythoncoder, could you share some more info what do you mean by "big projects"? Are you developing some product based on MicroPython?
@danielm I use the term "big" relative to the capabilities of the platform. I'm long retired and my projects are entirely amateur. My largest Pyboard project is this touch GUI https://github.com/peterhinch/micropython-tft-gui.git (a collaboration with @roberthh) which requires modules to be frozen to fit available RAM.
I've used frozen bytecode on other projects including the e-paper display for the Pyboard https://github.com/peterhinch/micropython-epaper.git and intend shortly to release a (hopefully generic) way to convert fonts to Python source which can then optionally be frozen as bytecode - all done except for the docs. So I've been a heavy user of frozen bytecode which I regard as an awesome feature of MicroPython
On the ESP8266 I attempted a project to use an ESP as an interface to bring stable MQTT to the Pyboard. Owing to the limited RAM on the ESP8266 this too required modules such as the scheduler https://github.com/peterhinch/Micrasopy ... eduler.gitto be frozen. Alas this project failed to achieve acceptable reliability owing to my lack of network experience. I abandoned it after three months effort and so have not posted code. However I can say with some confidence that frozen bytecode works fine on the ESP8266 (and of course the Pyboard).
