Hi @dhylands, thanks a lot. That works, but I noticed a change. With the previous version, I could use rshell or ampy. With this one, ampy times out and rshell has some issues.
rshell is version 0.0.6, freshly cloned from your git site. I open rshell with
rshell> ls /pyboard/sd
File "/usr/local/bin/rshell", line 11, in <module>
sys.exit(main())
File "/usr/local/lib/python3.4/dist-packages/rshell/command_line.py", line 4, in main
rshell.main.main()
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 2386, in main
real_main()
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 2369, in real_main
shell.cmdloop(cmd_line)
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 1390, in cmdloop
cmd.Cmd.cmdloop(self)
File "/usr/lib/python3.4/cmd.py", line 138, in cmdloop
stop = self.onecmd(line)
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 1420, in onecmd
self.onecmd_exec("".join(group))
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 1431, in onecmd_exec
return cmd.Cmd.onecmd(self, line)
File "/usr/lib/python3.4/cmd.py", line 217, in onecmd
return func(arg)
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 1957, in do_ls
for filename, stat in sorted(auto(listdir_stat, filename),
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 444, in auto
return dev.remote_eval(func, dev_filename, *args, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 1198, in remote_eval
return eval(self.remote(func, *args, **kwargs))
File "<string>", line 1
(('allstars', (32768, 0, 0, 0, 0, 0, 11701, 1446673538, 1446673538, 1446673538)), ('analogread.py', (32768, 0, 0, 0, 0, 0, 602, 1443870640, 1443870640, 1443870640)), ('boot.py', (32768, 0, 0, 0, 0, 0, 244, 321926400, 321926400, 321926400)), ('vttest.py', (32768, 0, 0, 0, 0, 0, 2578, 1453229372, 1453229372, 1453229372)), ('font7mono.py', (32768, 0, 0, 0, 0, 0, 6020, 1462433996, 1462433996, 1462433996)), ('vt100.py', (32768, 0, 0, 0, 0, 0, 15638, 1462433836, 1462433836, 1462433836)), ('data_7', (32768, 0, 0, 0, 0, 0, 59930, 946686238, 946686238, 946686238)), ('eatmem.py', (32768, 0, 0, 0, 0, 0, 392, 1388534996, 1388534996, 1388534996)), ('getfile.py', (32768, 0, 0, 0, 0, 0, 362, 1446673532, 1446673532, 1446673532)), ('font10.py', (32768, 0, 0, 0, 0, 0, 7940, 1462013212, 1462013212, 1462013212)), ('main.py', (32768, 0, 0, 0, 0, 0, 65, 321926400, 321926400, 321926400)), ('test_isr.py', (32768, 0, 0, 0, 0, 0, 1510, 1478623238, 1478623238, 1478623238)), ('readch.py', (32768, 0, 0, 0, 0, 0, 844, 1420070432, 1420070432, 1420070432)), ('ranger.py', (32768, 0, 0, 0, 0, 0, 504, 1466228400, 1466228400, 1466228400)), ('reload.py', (32768, 0, 0, 0, 0, 0, 511, 946684800, 946684800, 946684800)), ('logo50.raw', (32768, 0, 0, 0, 0, 0, 5000, 1456332344, 1456332344, 1456332344)), ('foto.data', (32768, 0, 0, 0, 0, 0, 391680, 1456586368, 1456586368, 1456586368)), ('F0010.jpg', (32768, 0, 0, 0, 0, 0, 64789, 1456595468, 1456595468, 1456595468)), ('data_1', (32768, 0, 0, 0, 0, 0, 30000, 1420071292, 1420071292, 1420071292)), ('alloctest.py', (32768, 0, 0, 0, 0, 0, 432, 1420071850, 1420071850, 1420071850)), ('toggle.py', (32768, 0, 0, 0, 0, 0, 1027, 1420070474, 1420070474, 1420070474)), ('F0020_8.bmp', (32768, 0, 0, 0, 0, 0, 131706, 1461869008, 1461869008, 1461869008)), ('ssimul.py', (32768, 0, 0, 0, 0, 0, 2580, 1388546970, 1388546970, 1388546970)), ('test16.py', (32768, 0, 0, 0, 0, 0, 9714, 1462896124, 1462896124, 1462896124)), ('test.py', (32768, 0, 0, 0, 0, 0, 289, 1460061424, 1460061424, 1460061424)), ('getrandom.py', (32768, 0, 0, 0, 0, 0, 173, 1420070586, 1420070586, 1420070586)), ('F0012.jpg', (32768, 0, 0, 0, 0, 0, 64789, 1456595468, 1456595468, 1456595468)), ('counter.py', (32768, 0, 0, 0, 0, 0, 650, 1454846430, 1454846430, 1454846430)), ('toggle.py', (32768, 0, 0, 0, 0, 0, 1027, 1420070474, 1420070474, 1420070474)), ('loop.py', (32768, 0, 0, 0, 0, 0, 857, 1462818616, 1462818616, 1462818616)), ('counter2.py', (32768, 0, 0, 0, 0, 0, 1783, 1454532264, 1454532264, 1454532264)), ('F0013.jpg', (32768, 0, 0, 0, 0, 0, 76261, 1456596104, 1456596104, 1456596104)), ('loop2.py', (32768, 0, 0, 0, 0, 0, 500, 1454876302, 1454876302, 1454876302)), ('loop3.py', (32768, 0, 0, 0, 0, 0, 1189, 1454931716, 1454931716, 1454931716)), ('readf.py', (32768, 0, 0, 0, 0, 0, 371, 946684800, 946684800, 946684800)), ('sample.py', (32768, 0, 0, 0, 0, 0, 170, 1455443462, 1455443462, 1455443462)), ('loop5.py', (32768, 0, 0, 0, 0, 0, 1257, 1454946844, 1454946844, 1454946844)), ('F0010.raw', (32768, 0, 0, 0, 0, 0, 259200, 1447090974, 1447090974, 1447090974)), ('tft_test.py', (32768, 0, 0, 0, 0, 0, 9997, 1475297296, 1475297296, 1475297296)), ('dsb.py', (32768, 0, 0, 0, 0, 0, 65, 1455731124, 1455731124, 1455731124)), ('foto.jpg', (32768, 0, 0, 0, 0, 0, 63358, 1456586336, 1456586336, 1456586336)), ('inspect.py', (32768, 0, 0, 0, 0, 0, 922, 1455778962, 1455778962, 1455778962)), ('burst.py', (32768, 0, 0, 0, 0, 0, 950, 1455824474, 1455824474, 1455824474)), ('P0001.raw', (32768, 0, 0, 0, 0, 0, 110976, 1447005344, 1447005344, 1447005344)), ('slides_4.py', (32768, 0, 0, 0, 0, 0, 10439, 1478020008, 1478020008, 1478020008)), ('font12.py', (32768, 0, 0, 0, 0, 0, 10760, 1460306032, 1460306032, 1460306032)), ('F0011.raw', (32768, 0, 0, 0, 0, 0, 259200, 1447090992, 1447090992, 1447090992)), ('F0012.bmp', (32768, 0, 0, 0, 0, 0, 261258, 1456941690, 1456941690, 1456941690)), ('logo50_3.raw', (32768, 0, 0, 0, 0, 0, 7500, 1456938656, 1456938656, 1456938656)), ('F0013.data', (32768, 0, 0, 0, 0, 0, 391680, 1456596748, 1456596748, 1456596748)), ('F0012.data', (32768, 0, 0, 0, 0, 0, 391680, 1456596768, 1456596768, 1456596768)), ('F0010.data', (32768, 0, 0, 0, 0, 0, 391680, 1456596780, 1456596780, 1456596780)), ('img_480x800', (16384, 0, 0, 0, 0, 0, 0, 1471790754, 1471790754, 1471790754)), ('font14.py', (32768, 0, 0, 0, 0, 0, 13848, 1462013212, 1462013212, 1462013212)), ('foto.bmp', (32768, 0, 0, 0, 0, 0, 261258, 1456864020, 1456864020, 1456864020)), ('F0020_4.bmp', (32768, 0, 0, 0, 0, 0, 65466, 1461869068, 1461869068, 1461869068)), ('touch.py', (32768, 0, 0, 0, 0, 0, 12018, 1462945248, 1462945248, 1462945248)), ('seek_n_read.py', (32768, 0, 0, 0, 0, 0, 126, 1456938000, 1456938000, 1456938000)), ('count.py', (32768, 0, 0, 0, 0, 0, 262, 1456937678, 1456937678, 1456937678)), ('F0020_1.bmp', (32768, 0, 0, 0, 0, 0, 16450, 1461869104, 1461869104, 1461869104)), ('data_2', (32768, 0, 0, 0, 0, 0, 30000, 1420072572, 1420072572, 1420072572)), ('slides.py', (32768, 0, 0, 0, 0, 0, 10439, 1478018860, 1478018860, 1478018860)), ('fonts.py', (32768, 0, 0, 0, 0, 0, 24297, 1459967618, 1459967618, 1459967618)), ('font20.py', (32768, 0, 0, 0, 0, 0, 25624, 1460306032, 1460306032, 1460306032)), ('calibrate.py', (32768, 0, 0, 0, 0, 0, 3279, 1460738868, 1460738868, 1460738868)), ('logo.jpg', (32768, 0, 0, 0, 0, 0, 93381, 1456328654, 1456328654, 1456328654)), ('logo.raw', (32768, 0, 0, 0, 0, 0, 223112, 1456332392, 1456332392, 1456332392)), ('logo50.jpg', (32768, 0, 0, 0, 0, 0, 8233, 1456331970, 1456331970, 1456331970)), ('font7hex.py', (32768, 0, 0, 0, 0, 0, 8093, 1460306088, 1460306088, 1460306088)), ('font6mono.py', (32768, 0, 0, 0, 0, 0, 3819, 1460306032, 1460306032, 1460306032)), ('peteensy.py', (32768, 0, 0, 0, 0, 0, 24538, 1479843422, 1479843422, 1479843422)), ('touchtest.py', (32768, 0, 0, 0, 0, 0, 4612, 1461266434, 1461266434, 1461266434)), ('terminal7hex.py', (32768, 0, 0, 0, 0, 0, 10171, 1459970540, 1459970540, 1459970540)), ('terminal7ctrl.py', (32768, 0, 0, 0, 0, 0, 10178, 1459970550, 1459970550, 1459970550)), ('font7ctrl.py', (32768, 0, 0, 0, 0, 0, 8100, 1460306084, 1460306084, 1460306084)), ('font8mono.py', (32768, 0, 0, 0, 0, 0, 6892, 1460306032, 1460306032, 1460306032)), ('tft.py', (32768, 0, 0, 0, 0, 0, 32207, 1463809802, 1463809802, 1463809802)), ('font9mono.py', (32768, 0, 0, 0, 0, 0, 6892, 1460306032, 1460306032, 1460306032)), ('font10mono.py', (32768, 0, 0, 0, 0, 0, 9204, 1460306030, 1460306030, 1460306030)), ('font24num_mono.py', (32768, 0, 0, 0, 0, 0, 3824, 1460306032, 1460306032, 1460306032)), ('font36num_mono.py', (32768, 0, 0, 0, 0, 0, 8844, 1460306068, 1460306068, 1460306068)), ('speed.py', (32768, 0, 0, 0, 0, 0, 416, 1460276684, 1460276684, 1460276684)), ('dejavu10.py', (32768, 0, 0, 0, 0, 0, 9982, 1461403008, 1461403008, 1461403liberation8mono.py', (32768, 0, 0, 0, 0, 0, 7318, 1460391878, 1460391878, 1460391878)), ('sevensegnumfont.py', (32768, 0, 0, 0, 0, 0, 9204, 1460392150, 1460392150, 1460392150)), ('liberation10mono.py', (32768, 0, 0, 0, 0, 0, 10398, 1460391878, 1460391878, 1460391878)), ('F0020.jpg', (32768, 0, 0, 0, 0, 0, 72406, 1460820810, 1460820810, 1460820810)), ('F0013.bmp', (32768, 0, 0, 0, 0, 0, 388922, 1460796310, 1460796310, 1460796310)), ('F0020.bmp', (32768, 0, 0, 0, 0, 0, 261258, 1460820848, 1460820848, 1460820848)), ('TFT_io.py', (32768, 0, 0, 0, 0, 0, 22073, 1462549502, 1462549502, 1462549502)), ('README.md', (32768, 0, 0, 0, 0, 0, 7014, 1462013212, 1462013212, 1462013212)), ('F0020_2.bmp', (32768, 0, 0, 0, 0, 0, 65418, 1461909590, 1461909590, 1461909590)), ('delay.py', (32768, 0, 0, 0, 0, 0, 1912, 1462013212, 1462013212, 1462013212)), ('hst.py', (32768, 0, 0, 0, 0, 0, 4522, 1462013212, 1462013212, 1462013212)), ('knobtest.py', (32768, 0, 0, 0, 0, 0, 1498, 1462013212, 1462013212, 1462013212)), ('ugui.py', (32768, 0, 0, 0, 0, 0, 31469, 1462013212, 1462013212, 1462013212)), ('usched.py', (32768, 0, 0, 0, 0, 0, 10951, 1462013212, 1462013212, 1462013212)), ('vst.py', (32768, 0, 0, 0, 0, 0, 4130, 1462013212, 1462013212, 1462013212)), ('get_rng.py', (32768, 0, 0, 0, 0, 0, 367, 1470229022, 1470229022, 1470229022)), ('sliderhandle.py', (32768, 0, 0, 0, 0, 0, 6611, 1462887998, 1462887998, 1462887998)), ('checkbox.py', (32768, 0, 0, 0, 0, 0, 7706, 1462888000, 1462888000, 1462888000)), ('icontest.py', (32768, 0, 0, 0, 0, 0, 1260, 1463400548, 1463400548, 1463400548)), ('radiobutton.py', (32768, 0, 0, 0, 0, 0, 5394, 1462887998, 1462887998, 1462887998)), ('switch.py', (32768, 0, 0, 0, 0, 0, 6195, 1462888000, 1462888000, 1462888000)), ('sliderpath.py', (32768, 0, 0, 0, 0, 0, 20944, 1462887996, 1462887996, 1462887996)), ('bmp_to_icon.py', (32768, 0, 0, 0, 0, 0, 10816, 1462894490, 1462894490, 1462894490)), ('test24.py', (32768, 0, 0, 0, 0, 0, 14322, 1462896132, 1462896132, 1462896132)), ('touch_python.py', (32768, 0, 0, 0, 0, 0, 11631, 1462559594, 1462559594, 1462559594)), ('Flat_UI.py', (32768, 0, 0, 0, 0, 0, 55130, 1462981918, 1462981918, 1462981918)), ('mdesign.py', (32768, 0, 0, 0, 0, 0, 5724, 1463309436, 1463309436, 1463309436)), ('blink.py', (32768, 0, 0, 0, 0, 0, 117, 1463168422, 1463168422, 1463168422)), ('media.py', (32768, 0, 0, 0, 0, 0, 6901, 1463392818, 1463392818, 1463392818)), ('__pycache__', (16384, 0, 0, 0, 0, 0, 0, 1463309962, 1463309962, 1463309962)), ('globals.py', (32768, 0, 0, 0, 0, 0, 47, 1463309846, 1463309846, 1463309846)), ('check_boxes.py', (32768, 0, 0, 0, 0, 0, 9220, 1463385434, 1463385434, 1463385434)), ('thin_arrow.py', (32768, 0, 0, 0, 0, 0, 2903, 1463385438, 1463385438, 1463385438)), ('switch_4c.py', (32768, 0, 0, 0, 0, 0, 5149, 1463400470, 1463400470, 1463400470)), ('slides_old.py', (32768, 0, 0, 0, 0, 0, 7871, 1462039456, 1462039456, 1462039456)), ('img_272x480', (16384, 0, 0, 0, 0, 0, 0, 1471790884, 1471790884, 1471790884)), ('.Trash-1000', (16384, 0, 0, 0, 0, 0, 0, 1471790898, 1471790898, 1471790898)))
SyntaxError: invalid syntax
If I run the ls command for a single file only or an sd cards with fewer files, it works. So it may be a problem of the number of files.
