Hello!
I'd like to learn how to use interrupts in Micropython.
Please note that I have never used interrupts at all, neither in Arduino or in other frameworks. My theoretical knowledge is based only on what I have found in the documentation online.
However, in order to understand what I'm doing I need to make some tests. I have found something here and there but the examples are focusing on the Pyboard or are out of date. I cannot therefore, use those examples on the esp8266 were classes and methods are sometimes different.
Can someone point me to resources that are focusing on interrupt handling on 8266?
Thanks a lot
Learning Interrupts handling
Re: Learning Interrupts handling
This might be a good place to start: http://docs.micropython.org/en/latest/e ... =interrupt
Please do keep in mind, that some of it might be slightly outdated or doesn't reflect the Hardware API changes. For example, the "pyb" module doesn't exist on ESP8266 port.
Thank you Platforma.platforma wrote:This might be a good place to start: http://docs.micropython.org/en/latest/e ... =interrupt
I read it but the lack of examples with up to date library makes it difficult for me.
As I said, I'm quite a beginner.
Thanks anyway!
