mu editor for micropython
rob.frohne
Re: mu editor for micropython
Post by rob.frohne » Thu Dec 29, 2016 5:22 am
Hi Peter, et. al.,
I found for my setup I had to select the fourth element in the serial available_ports array in logic.py, instead of 0, because my esp8266 is at /dev/ttyUSB3. See below:
def find_upython_device():
TODO - allow option to select which serial port to use.
For now, this just returns the first serial port found
available_ports = QSerialPortInfo.availablePorts()
port = available_ports[4]
logger.info('Using port {}'.format(port.portName()))
return port.portName()
except IndexError:
return None
Flashing is not working for me. I'm wondering if that is because nobody has modified the flashing to work with the esp8266 yet, or if it is for a similar reason to the problem I fixed above. Sorry if this is a newbie question. I'm rather new to python.
Thanks,
Rob
askvictor
Post by askvictor » Sun Jan 01, 2017 11:24 am
rob.frohne wrote:Hi Peter, et. al.,
Yeah, the serial port selection is scrappy. Ideally it would try to autodetect, but that's harder than it sounds, and also, few computers have multiple (or, indeed, any) serial ports these days, so 0 is a good guess for most cases.
Flashing through mu is not yet implemented - its only there for the micro:bit at this stage.
rcolistete
Post by rcolistete » Sun Jan 01, 2017 11:53 am
Have you seen this video ?
Blockly for MicroPython in the browser and in Mu
December 8th 2016
A quick overview of work in progress concerning the use of blocks, MicroPython, the BBC micro:bit and the browser based editor and Mu
https://www.youtube.com/watch?v=XCZEKtNHx5k
Post by pythoncoder » Mon Jan 02, 2017 8:54 am
Impressive!
In a lighter vein I was struck by his statement "I've also made sure that not everything you can do with the Microbit is available in blocks. Some of the really cool more complicated features to do with the microbit you can only access using Python."
Doubtless that required a great deal of effort and attention to detail. You wouldn't want to reduce the entirety of software engineering to shifting blocks around, now would you? ;)
rcolistete
Post by rcolistete » Fri Jan 13, 2017 10:36 pm
rcolistete wrote:Have you seen this video ?
December 8th 2016
You can test a local web Python Editor for BBC Micro:bit with Blocks using the source code :
https://github.com/bbcmicrobit/PythonEditor
It is easy :
$ git clone https://github.com/bbcmicrobit/PythonEditor.git
$ cd PythonEditor
$ git submodule update --init --recursive
Then double click 'editor.html'.
rhubarbdog
Post by rhubarbdog » Sun Nov 12, 2017 12:54 am
I have produced this installation guide for ubuntu/mint/debian linux
https://ubuntuforums.org/showthread.php?t=2377314
ttmetro
Post by ttmetro » Tue Nov 14, 2017 7:59 am
Tried this on ubuntu and get the following error:
python3 run.py
  File "run.py", line 2, in <module>
    from mu.app import run
  File "/home/ee49/Downloads/mu-master/mu/app.py", line 44, in <module>
    from mu.interface import Window
  File "/home/ee49/Downloads/mu-master/mu/interface/__init__.py", line 1, in <module>
    from .main import Window
  File "/home/ee49/Downloads/mu-master/mu/interface/main.py", line 31, in <module>
    from mu.interface.panes import (DebugInspector, PythonProcessPane,
  File "/home/ee49/Downloads/mu-master/mu/interface/panes.py", line 31, in <module>
    from PyQt5.QtSerialPort import QSerialPort
ModuleNotFoundError: No module named 'PyQt5.QtSerialPort'
Notes:
  • I use the anaconda python distribution
  • I run ubuntu in a virtualbox (on top of osx)
  • apt-cache search pyqt5: ... output includes the line
    python3-pyqt5.qtserialport - Python 3 bindings for QtSerialPort module
Bernhard Boser
rhubarbdog
Post by rhubarbdog » Tue Nov 14, 2017 5:07 pm
Hi check back at the above post i had missed a few lines of code
ttmetro
Post by ttmetro » Tue Nov 14, 2017 5:33 pm
This did install more stuff, but unfortunately I still get the same error:
./run.py
  File "./run.py", line 2, in <module>
Likely is a problem with my installation of Python and has nothing to do with mu. I am completely in the fog on how Python installs libraries.
Bernhard Boser
rhubarbdog
Post by rhubarbdog » Tue Nov 14, 2017 7:00 pm
pip3 install ...
I saw this on another forum about python
pip3 install -r requirements.txt
Read requirements.txt first as comments contain shell commands to run
