do you know a good GPS locator chip?
Rey_rem
Postby Rey_rem » Fri Mar 17, 2017 4:00 pm
Hello!
I search a gps chip to use in a project, and I'd like to know if someone knows a good one. :?:
It must provides a 5 metre accuracy or better.
Thank you in advance for youre answear (and please forgive my terrible english ;) )
Re: do you know a good GPS locator chip?
Postby dhylands » Fri Mar 17, 2017 4:24 pm
http://sparkfun.com has a few. This one: https://www.sparkfun.com/products/12751 claims 2.5m accuracy.
Sparkfun also has a GPS buying guide that you should probably read through: https://www.sparkfun.com/pages/GPS_Guide
Rey_rem
Postby Rey_rem » Fri Mar 17, 2017 4:35 pm
Thank you very much!
Must be a absolute noob question but how do you know is a gps chip is compatible with a pyboard or not? :?:
Postby dhylands » Fri Mar 17, 2017 4:58 pm
Most GPSes that I'm familiar with have a logic level serial interface. The pyboard has 5V tolerant inputs for the UARTs so it should work with 5v or 3.3v signals.
Rey_rem
Postby Rey_rem » Fri Mar 17, 2017 5:00 pm
Thanks!
TravisT
Postby TravisT » Fri Mar 17, 2017 6:12 pm
I often look at Sparkfun and Adafruit for common products that usually offer good getting started guides.
And like Dave said GPS modules are usually 3.3 and/or 5v tolerant USARTs that are easy to interface with microcontrollers.
Rey_rem
Postby Rey_rem » Sun Mar 19, 2017 10:07 pm
Return to “Other Boards”
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
