microbit micropython help
kvarneb
Postby kvarneb » Mon Mar 13, 2017 2:36 pm
Hi
I am currently trying to use this code in order to create different sounds when the microbit is tilted in a different direction. However, it isnt working...can anyone help?
from micro bit import *
import music
on = False
initial = 1000
if button_a.is_pressed():
on = True
while on:
if accelerometer.get_y() >10:
initial +=100
music.pitch(initial,100)
elif accelerometer.get_y() <10:
initial -=100
if initial >4000:
initial = 4000
if initial < 100:
initial = 100
if button_b.is_pressed():
on = False
sleep(100)
deshipu
Re: microbit micropython help
Postby deshipu » Mon Mar 13, 2017 5:37 pm
What do you mean exactly by "not working"?
Postby pythoncoder » Sun Mar 19, 2017 4:49 pm
The first line looks wrong to me. Should microbit be one word?
I'm guessing the indentation should look like this:
from microbit import *
import music
on = False
initial = 1000
        on = True
    while on:
            initial +=100
            initial -=100
        if initial >4000:
            initial = 4000
        if initial < 100:
            initial = 100
            on = False
        sleep(100)
I'm unfamiliar with the micro:bit but are you sure the units of sleep() are milliseconds rather than seconds? Does your indentation match mine? Do you get an error message and if so what is it?
deshipu
Postby deshipu » Sun Mar 19, 2017 9:40 pm
You can see the original indentation of the code by viewing the page source -- just a trick.
Return to “General Discussion and Questions”
Who is online
Users browsing this forum: Yahoo [Bot] and 2 guests
