I write in Serial Terminal:
pyb.Accel()
Answer is:
OSError: accelerometer not found
Can anyone tell me what I do wrong?
Re: OSError: accelerometer not found
My bad bought the cheep model without one.
I've got the same error, although I use a Pyboard v 1.1, and it should have one
https://store.micropython.org/product/PYBv1.1H
Any idea whats wrong? Does it needs to be switched on first or something similar?
On a Pyboard 1.1 you should be able to issue at the REPL
The last line should return something like (2, -7, 22). If you get an error please post it.
>>> import pyb
>>> a = pyb.Accel()
>>> a.filtered_xyz()
Good afternoom,
I have the same problem. I have the pyboard v1.1
this is what I get.
>>> import pyb
>>> a=pyb.Accel()
this is what I get.
>>> import pyb
>>> a=pyb.Accel()
Are you sure you have a 1.1 board? The 1.0 LITE board doesn't have an accelerometer.
What does: report for you?
What does:
import os
os.uname()
There are also clone boards out there of dubious quality.
