VCC-GND STM32F407VET6 dev board
mcauser
Re: VCC-GND STM32F407VET6 dev board
Post by mcauser » Thu Mar 09, 2017 1:00 am
Board definition moved here:
https://github.com/mcauser/VCC_GND_F407
Using @dhylands approach, with separate git repos per board, and clone them into stmhal/boards when needed
https://github.com/dhylands/wiki/wiki/M ... oard-files
Javid
Post by Javid » Mon Apr 03, 2017 5:33 am
Hi. Need some advice. I bought one of this boards and confused with led light.
I used code from vcc-gnd.taobao.com for led it works. But what if i want to use cubemx?
Used Cubemx and then used simple code but it doesnt work.
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_9);
HAL_Delay(500);
Does this board work with Hal drivers? May be you can add example with hal driver?
Post by dhylands » Mon Apr 03, 2017 8:23 pm
The board works with the HAL, since micropython uses the HAL.
Did you also configure the pin as an output? and enable the clock for Port B?
Do you have a complete code example?
I have a small repository here: https://github.com/dhylands/stm32-test and if you check that out and do:
make BOARD=VCC-GND-F407
then that builds a small app that flashes the BLUE Led on the board (and uses the HAL)
mhwang1973
Post by mhwang1973 » Fri Jul 14, 2017 5:46 am
I set the board to DFU mode , and download the flash using:
$make BOARD=VCC_GND_F407 deploy
It worked in MACos, but met a driver trouble in Win7 X64. It can be read as a mass strorage, but the VCP cannot work.
What is the problem?
Turbinenreiter
Post by Turbinenreiter » Wed Aug 02, 2017 9:17 am
I just ordered one. And I feel a bit dirty.
Can we have a way to throw money at the project other than buying Pyboards? A donate-button would be cool, but also something that can be billed - companies need billing.
deshipu
Post by deshipu » Wed Aug 02, 2017 11:58 am
Turbinenreiter wrote: Can we have a way to throw money at the project other than buying Pyboards? A donate-button would be cool, but also something that can be billed - companies need billing.
IIRC you can buy stickers to support the project.
Turbinenreiter
Post by Turbinenreiter » Wed Aug 02, 2017 5:43 pm
From Adafruit, shipping them from New York to Munich :lol:
Great option to add to my next Adafruit order.
KevinA
Post by KevinA » Sat Feb 24, 2018 11:07 pm
[quote=loboris post_id=17496 time=1485367486 user_id=923]
There are even better boards with [b]STM32F407ZET6[/b] for ~13-17 US$ with optional external [b]SDRAM[/b] (1 MByte IS62WV51216BLL, ~2-5 US$)
http://www.ebay.com/sch/i.html?_from=R4 ... T6&_sop=15
https://www.aliexpress.com/w/wholesale- ... 0125100625
https://www.aliexpress.com/w/wholesale- ... 0125100822
I'm not shure if MicroPython suppports external SDRAM :?: , but it would be fantastic to run MicroPython with more than 1MB of free RAM on 15-20 US$ board :D
Links to documentation for many of those boards can be found in this forum:
http://www.stm32duino.com/viewtopic.php?t=1369
Most interesting:
http://www.dragonwake.com/download/down ... T6_sch.pdf (STM32F407[b]ZET[/b]6 schematic)
https://translate.google.com/translate? ... &sandbox=1
http://loboris.eu/STM32/STM32F407VET6_schematics.jpg (STM32F407[b]VET[/b]6 schematic)
[/quote]
Thank you for the schematics! The STM32F407ZET6 just replace the Arduino DUE and with the STM32F407ZET6 LCD it screams!
uCTRL
Post by uCTRL » Sun Mar 10, 2019 9:49 am
Deleted
Sorted out
mcauser
Post by mcauser » Sun Mar 10, 2019 1:49 pm
Renamed to: https://github.com/mcauser/VCC_GND_F407VE
To make room for: https://github.com/mcauser/VCC_GND_F407ZG
GitHub should have added redirects though...
