I've been trying to call a function from a file, having no luck I tried the example from the page:
http://wiki.micropython.org/Importing-Modules
But even with the example this is what I get:
AttributeError: 'module' object has no attribute 'hello'
I'm using my WeMos mini and accessing it via WebREPL. I did try resetting, but same result.
[SOLVED]issue with calling functions from a file
Re: issue with calling functions from a file
The examples of the link should work Could you share the content and name of the file with the functions hello, which you aim to import?
Sorry for the late reply, had an urgent matter to attend to. I took another shot at it a few minutes ago, and now everything works fine; it must have been something stupid on my part (guessing that I didn't tab over correctly for a line of code, or something similar.) I was trying out the first example on that page where you create mod1.py, upload that to the board, and then import and run it.
