uasyncio - asyncio-like cooperative multitasking framework for uPy
Re: asyncio-like cooperative multitasking framework for uPy
I saw it, but how do I integrate into asyncio?
Frédéric
So, we just need to write a PEP for that, have it included in CPython, and we're goldendhylands wrote:There is a pyb.elapsedMillis() that takes rollovers into consideration.
http://docs.micropython.org/en/latest/l ... sed_millis
Awesome MicroPython list
Ok, I successfully subclassed EventLoop, and overrided time() and wait() methods:
Here is the previous code, to blink leds:
I'm working on a Sensirion SHT15 library, using asyncio to update measures in background; I'm testing it with the LCD board I just received; it's about to work
BTW, I found a bug in core.py:
It should be:
class MyEventLoop(asyncio.EventLoop):
def time(self):
return pyb.millis()
def wait(self, delay):
start = pyb.millis()
while pyb.elapsed_millis(start) < delay:
pyb.delay(10)
asyncio._event_loop_class = MyEventLoop
import logging
import uasyncio.core as asyncio
def time(self):
log = logging.getLogger("asyncio")
log.debug("time")
return pyb.millis()
log.debug("Sleeping for: %s", delay)
pyb.delay(10)
@asyncio.coroutine
def light(led, delayOn, delayOff):
print("%d:%s on" % (pyb.millis(), repr(led)))
led.on()
yield from asyncio.sleep(delayOn)
print("%d:%s off" % (pyb.millis(), repr(led)))
led.off()
yield from asyncio.sleep(delayOff)
def main():
logging.basicConfig(level=logging.INFO)
TABLE = (
{'led': pyb.LED(1), 'tOn': 1000, 'tOff': 2000},
{'led': pyb.LED(2), 'tOn': 1000, 'tOff': 500},
{'led': pyb.LED(3), 'tOn': 500, 'tOff': 500},
{'led': pyb.LED(4), 'tOn': 250, 'tOff': 1000}
for entry in TABLE:
loop.create_task(light(entry['led'], entry['tOn'], entry['tOff']))
loop.run_forever()
if __name__ == "__main__":
main()
def create_task(self, coro):
# CPython 3.4.2
self.call_at(0, callback)
# CPython asyncio incompatibility: we don't return Task object
# CPython 3.4.2
self.call_at(0, coro)
Frédéric
Ok, here is my code, using uasyncio. I post for feedback. It is surely not optimized for micropython; I wrote it as for CPython. Feel free to comment/suggest/criticize!
I also want to push people using asyncio, as it looks like a very easy and efficient way to build multitasking apps under micropython. I don't have the skills to improve it, for example to make the main part of uasyncio run on micropython (it only works on unix port, because of missing ffi module). Hope some will
# -*- coding: utf-8 -*-
""" Sensirion SHT1x & SHT7x family temperature and humidity sensors
Created by Markus Schatzl, November 28, 2008
Released into the public domain
Revised (v1.1) by Carl Jackson, August 4, 2010
Rewritten (v2.0) by Carl Jackson, December 10, 2010
Ported to micropython by Frederic Mantegazza, november, 2014
import math
import gc
import logging
import mpr121
# Clock pulse timing (us)
# Lengthening these may assist communication over long wires
PULSE_LONG = 3
PULSE_SHORT = 1
# Status register bit definitions
SR_LOW_RES = 0x01 # 12-bit Temp / 8-bit RH (vs. 14 / 12)
SR_NORELOAD = 0x02 # No reload of calibrarion data
SR_HEAT_ON = 0x04 # Built-in heater on
SR_BATT_LOW = 0x40 # VDD < 2.47V
# SHT15 command definitions:
# adr command r/w
CMD_MEAS_TEMP = 0x03 # 000 0001 1
CMD_MEAS_HUMI = 0x05 # 000 0010 1
CMD_STAT_REG_W = 0x06 # 000 0011 0
CMD_STAT_REG_R = 0x07 # 000 0011 1
CMD_SOFT_RESET = 0x1e # 000 1111 0
# Status register writable bits
SR_MASK = 0x07
# Temperature & humidity equation constants
D1 = -40.1 # for deg C @ 5V
D2h = 0.01 # for deg C, 14-bit precision
D2l = 0.04 # for deg C, 12-bit precision
C1 = -2.0468 # for V4 sensors
C2h = 0.0367 # for V4 sensors, 12-bit precision
C3h = -1.5955E-6 # for V4 sensors, 12-bit precision
C2l = 0.5872 # for V4 sensors, 8-bit precision
C3l = -4.0845E-4 # for V4 sensors, 8-bit precision
T1 = 0.01 # for V3 and V4 sensors
T2h = 0.00008 # for V3 and V4 sensors, 12-bit precision
T2l = 0.00128 # for V3 and V4 sensors, 8-bit precision
class SHT15Exception(Exception):
class WrongParam(SHT15Exception):
class NoAcknowledge(SHT15Exception):
class CrcError(SHT15Exception):
class Timeout(SHT15Exception):
class InvalidMeasure(SHT15Exception):
class SHT15:
""" SHT15 Sensirion management class
def __init__(self, dataPin, clockPin):
""" Init object
@param dataPin: pin for data line
@type dataPin: str or pyb.Pin.cpu.Name or pyb.Pin.board.Name
@param clockPin: pin for clock line
@type clockPin: str or pyb.Pin.cpu.Name or pyb.Pin.board.Name
All functions exit with clockPin low and dataPin in input mode
self._pinData = pyb.Pin(dataPin, pyb.Pin.OUT_PP)
self._pinClock = pyb.Pin(clockPin, pyb.Pin.OUT_PP)
self._rawDataTemp = None
self._rawDataHum = None
self._measureInitiatedAt = 0
self._measureReady = False
# Sensor status register default state
self._statusRegister = 0x00
self._initSensor()
@property
def temperature(self):
if self._rawDataTemp is None:
raise InvalidMeasure
if self._statusRegister & SR_LOW_RES:
return D1 + D2l * self._rawDataTemp
return D1 + D2h * self._rawDataTemp
@property
def humidity(self):
humidity = C1 + C2l * self._rawDataHum + C3l * self._rawDataHum ** 2
humidity += (self.temperature - 25.0) * (T1 + T2l * self._rawDataHum)
humidity = C1 + C2h * self._rawDataHum + C3h * self._rawDataHum ** 2
humidity += (self.temperature - 25.0) * (T1 + T2h * self._rawDataHum)
if humidity > 100.0:
humidity = 100.0
elif humidity < 0.1:
humidity = 0.1
return humidity
@property
def dewPoint(self):
k = math.log(self.humidity / 100) + (17.62 * self.temperature) / (243.12 + self.temperature)
return 243.12 * k / (17.62 - k)
def _initSensor(self):
""" Put sensor to default state
# Reset communication link with sensor
self._resetConnection()
# Send soft reset command
self._putByte(CMD_SOFT_RESET)
def _resetConnection(self):
"""Communication link reset
# At least 9 SCK cycles with DATA=1, followed by transmission start sequence
# ______________________________________________________ ________
# DATA: |_______|
# _ _ _ _ _ _ _ _ _ ___ ___
# SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
# Set data register high before turning on
self._pinData.high()
# output driver (avoid possible low pulse)
self._pinData.init(pyb.Pin.OUT_PP)
pyb.udelay(PULSE_LONG)
# 9 clock cycles
for i in range(0, 9):
self._pinClock.high()
self._pinClock.low()
self._startTransmission()
def _startTransmission(self):
"""Generate SHT15-specific transmission start sequence
# This is where SHT15 does not conform to the I2C standard and is
# the main reason why the AVR TWI hardware support can not be used.
# _____ ________
# DATA: |_______|
# ___ ___
# SCK : ___| |___| |______
pyb.udelay(PULSE_SHORT)
self._pinData.low()
self._pinData.init(pyb.Pin.IN, pull=pyb.Pin.PULL_UP)
def _putByte(self, value):
""" Write byte to sensor and check for acknowledge
@raise: NoAcknowledge
# Set data line to output mode
# Bit mask to transmit MSB first
mask = 0x80
for i in range(8, 0, -1):
self._pinData.value(value & mask)
# Generate clock pulse
# Shift mask for next data bit
mask >>= 1
# Return data line to input mode
# Clock #9 for ACK
# Verify ACK ('0') received from sensor
if self._pinData.value():
raise NoAcknowledge("SHT15 didn't acknowledge data")
# Finish with clock in low state
def _getByte(self, ack):
""" Read byte from sensor
@param ack: send acknowledge if True
@type ack: bool
@raise:
result = 0
# Shift received bits towards MSB
result <<= 1
# Merge next bit into LSB position
result |= self._pinData.value()
# Assert ACK ('0') if ack == 1
self._pinData.value(ack ^ 1)
# Clock #9 for ACK / NO_ACK
return result
def _readSR(self):
""" Read status register
self.startTransmission()
self._putByte(CMD_STAT_REG_R)
except SHT15Exception:
return 0xff
return self._getByte(ack=False)
def _writeSR(self, value):
""" Write status register
# Mask off unwritable bits
value &= SR_MASK
# Save local copy
self._statusRegister = value
self._putByte(CMD_STAT_REG_W)
self._putByte(value)
def _readData(self):
""" Get measurement result from sensor
data = self._getByte(ack=True)
data = (data << 8) | self._getByte(ack=False)
return data
@asyncio.coroutine
def loop(self, refresh=5000):
""" Measurement loop
This method continuously do measures at refresh rate. It is build as a state machine.
It uses asyncio module.
@param refresh: refresh measure rate, in ms
@type refresh: int
logger = logging.getLogger('sht15')
state = 'idle'
lastReading = 0
if state == 'idle':
if pyb.elapsed_millis(lastReading) >= refresh:
logger.debug("%d:start new measure", pyb.millis())
lastReading = pyb.millis()
state = 'read temp'
elif state == 'read temp':
logger.debug("%d:read raw temp", pyb.millis())
self.initiateMeasure('temp')
state = 'wait temp'
elif state == 'wait temp':
if self.measureReady():
logger.debug("%d:temp data ready", pyb.millis())
self._rawDataTemp = self._readData()
state = 'read hum'
elif state == 'read hum':
logger.debug("%d:read raw hum", pyb.millis())
self.initiateMeasure('hum')
state = 'wait hum'
elif state == 'wait hum':
logger.debug("%d:hum data ready", pyb.millis())
self._rawDataHum = self._readData()
logger.debug("%d:measure done in %sms", pyb.millis(), pyb.elapsed_millis(lastReading))
state = 'idle'
yield from asyncio.sleep(10)
def measure(self):
""" All-in-one (blocking)
@return: temperature, humidity, dewpoint
self.waitForMeasureReady()
self._rawDataHum = self.initiateMeasure('hum')
return self.temperature, self.humidity, self.dewPoint
def initiateMeasure(self, cmd):
""" Initiate measure
if cmd == "temp":
cmd = CMD_MEAS_TEMP
elif cmd == 'hum':
cmd = CMD_MEAS_HUMI
WrongParam("measure cmd (%s) must be in ('temp', hum')" % cmd)
self._measureInitiatedAt = pyb.millis()
self._putByte(cmd)
def measureReady(self):
""" Check if non-blocking measurement has completed
# Already done?
if self._measureReady:
return True
# Measurement ready yet?
return False
self._measureReady = True
return True
def waitForMeasureReady(self, timeout=720):
""" wait for non blocking measure to complete
raise: TimeoutError
if measureReady():
return
if pyb.elapsed_millis(self._measureInitiatedAt) >= timeout:
raise Timeout("timeout while waiting for measure")
def reset(self):
""" Reset function
Soft reset returns sensor status register to default values
self._initSensor()
def time(self):
return pyb.millis()
gc.collect()
pyb.delay(10)
@asyncio.coroutine
def backlight(lcd, autoOff=10000):
""" LCD backlight management
logger = logging.getLogger("backlight")
switch = pyb.Switch()
touch = mpr121.MPR121(pyb.I2C(1, pyb.I2C.MASTER))
backlight = False
backlightOnTime = 0
previousSwitch = False
#logger.debug("backlight")
if touch.touch_status() or switch():
if not previousSwitch:
if backlight:
logger.info("backlight off")
lcd.light(False)
backlight = False
logger.info("backlight on")
lcd.light(True)
backlight = True
backlightOnTime = pyb.millis()
previousSwitch = True
# Auto switch off screen after 10s
if backlight and pyb.elapsed_millis(backlightOnTime) >= autoOff:
logger.info("backlight auto off")
lcd.light(False)
backlight = False
@asyncio.coroutine
def display(sht15, lcd, refresh=1000):
""" Print data
logger = logging.getLogger("display")
measure = pyb.millis(), sht15.temperature, sht15.humidity, sht15.dewPoint
logger.info("%d:temperature=%.1f C, humidity=%.1f%%, dew point=%.1f C", *measure)
lcd.write("temp=%.1f C\nhumidity=%.1f%%\ndew point=%.1f C\n\n" % measure[1:])
except InvalidMeasure:
logger.warning("measure not yet available")
yield from asyncio.sleep(refresh)
@asyncio.coroutine
def info(refresh=10000):
""" Print pyb info
pyb.info()
def main():
logging.basicConfig(logging.DEBUG)
logger = logging.getLogger("asyncio")
logger.level = logging.INFO
lcd = pyb.LCD('X')
lcd.contrast(25)
sht15 = SHT15('Y11', 'Y12')
loop.create_task(sht15.loop(refresh=5000))
loop.create_task(display(sht15, lcd, refresh=1000))
loop.create_task(backlight(lcd, autoOff=10000))
loop.create_task(info(refresh=10000))
loop.run_forever()
main()
Frédéric
Mmm, looks like my code is not very stable: the pyboard crashes after a while (1.5 hour).
The last pyb.info() shows:
What can cause this crash? The above infos are pretty stable from the begining...
ID=43002800:12473234:37383239
S=168000000
H=168000000
P1=42000000
P2=84000000
_etext=8059a2c
_sidata=8059a2c
_sdata=20000000
_edata=2000018c
_sbss=2000018c
_ebss=20002784
_estack=20020000
_ram_start=20000000
_heap_start=20002784
_heap_end=2001c000
_ram_end=20020000
qstr:
n_pool=4
n_qstr=220
n_str_data_bytes=4608
n_total_bytes=5872
GC:
102144 total
44080 : 58064
1=355 2=87 m=1280
LFS free: 67584 bytes
Frédéric
Ok, it seems that crashes only occur when minicom is active on the ttyACMx line... Without launching minicom (but still powering up pyboard from usb), it does not crash.
Any idea why?
Any idea why?
Frédéric
As only uasyncio.core works under pyb, for now, how would you add support for simple non-blocking reading on a pyb serial line, for example?
The goal would be to have a coroutine monitoring a serial line used to send commands to pyboad, while it is doing some work in background...
Frédéric
Onlinedhylands
No, but I would look at the buffer fillng/emptying portion of the USB serial code.fma wrote:Ok, it seems that crashes only occur when minicom is active on the ttyACMx line... Without launching minicom (but still powering up pyboard from usb), it does not crash.
Any idea why?
With no USB connected, data destine for the serial port will fill the buffer and presumably once that happens, it will start dropping characters.
When minicom is active, then the buffer will be filling/emptying and there is probably an edge case where it doesn't do the right thing.
Ok, I see. Thanks for the suggestion.
Frédéric
Thanks, fixed/new version pushed to PyPI.BTW, I found a bug in core.py:
