I try to make post requests using urequests lib to an API. When the API is not responding the request is stuck in a "loop" and after a while I receive : ssl_handshake_status: -256
Even if the API is getting alive I could not make any request if I received ssl_handshake error.
How could I implement a timeout for urequests ?
urequests - Timeout
Re: urequests - Timeout
I made a pull request : https://github.com/micropython/micropython-lib/pull/263. The code was tested by me on an esp8266 board and seems to be ok. Could someone test it on other ports ?
Doesn't work on Pycom's version of urequests. File "/flash/lib/urequests.py", line 112, in get
TypeError: function does not take keyword arguments
import usocket
class Response:
def __init__(self, f):
self.raw = f
self.encoding = "utf-8"
self._cached = None
def close(self):
if self.raw:
self.raw.close()
self.raw = None
self._cached = None
@property
def content(self):
if self._cached is None:
self._cached = self.raw.read()
finally:
self.raw.close()
self.raw = None
return self._cached
@property
def text(self):
return str(self.content, self.encoding)
def json(self):
import ujson
return ujson.loads(self.content)
def request(method, url, data=None, json=None, headers={}, stream=None):
proto, dummy, host, path = url.split("/", 3)
except ValueError:
proto, dummy, host = url.split("/", 2)
path = ""
if proto == "http:":
port = 80
elif proto == "https:":
import ussl
port = 443
raise ValueError("Unsupported protocol: " + proto)
if ":" in host:
host, port = host.split(":", 1)
port = int(port)
ai = usocket.getaddrinfo(host, port)
ai = ai[0]
s = usocket.socket(ai[0], ai[1], ai[2])
if timeout is not None:
assert hasattr(usocket.socket, 'settimeout'), 'Socket does not support timeout'
s.settimeout(timeout)
s.connect(ai[-1])
s = ussl.wrap_socket(s, server_hostname=host)
s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
if not "Host" in headers:
s.write(b"Host: %s\r\n" % host)
# Iterate over keys to avoid tuple alloc
for k in headers:
s.write(k)
s.write(b": ")
s.write(headers[k])
s.write(b"\r\n")
if json is not None:
assert data is None
import ujson
data = ujson.dumps(json)
s.write(b"Content-Type: application/json\r\n")
if data:
s.write(b"Content-Length: %d\r\n" % len(data))
s.write(b"\r\n")
if data:
s.write(data)
l = s.readline()
#print(l)
l = l.split(None, 2)
status = int(l[1])
reason = ""
if len(l) > 2:
reason = l[2].rstrip()
l = s.readline()
if not l or l == b"\r\n":
break
#print(l)
if l.startswith(b"Transfer-Encoding:"):
if b"chunked" in l:
raise ValueError("Unsupported " + l)
elif l.startswith(b"Location:") and not 200 <= status <= 299:
raise NotImplementedError("Redirects not yet supported")
except OSError:
s.close()
raise
resp = Response(s)
resp.status_code = status
resp.reason = reason
return resp
def head(url, **kw):
return request("HEAD", url, **kw)
def get(url, **kw):
return request("GET", url, **kw)
def post(url, **kw):
return request("POST", url, **kw)
def put(url, **kw):
return request("PUT", url, **kw)
def patch(url, **kw):
return request("PATCH", url, **kw)
def delete(url, **kw):
return request("DELETE", url, **kw)
import usocket
class Response:
self.raw = f
self._cached = None
def close(self):
if self.raw:
self.raw.close()
self.raw = None
self._cached = None
@property
def content(self):
finally:
self.raw.close()
self.raw = None
return self._cached
@property
def text(self):
def json(self):
import ujson
except ValueError:
path = ""
port = 80
import ussl
port = 443
if ":" in host:
port = int(port)
ai = ai[0]
s.connect(ai[-1])
for k in headers:
s.write(k)
s.write(b": ")
s.write(headers[k])
s.write(b"\r\n")
assert data is None
import ujson
if data:
s.write(b"\r\n")
if data:
s.write(data)
l = s.readline()
#print(l)
status = int(l[1])
reason = ""
if len(l) > 2:
l = s.readline()
break
#print(l)
if b"chunked" in l:
except OSError:
s.close()
raise
resp = Response(s)
return resp
def get(url, **kw):
def put(url, **kw):
