Building MP under windows
pfalcon
Re: Building MP under windows
Post by pfalcon » Fri May 02, 2014 3:01 pm
> rather than read between the lines
Forgot to mention - yes, that was the culprit.
Awesome MicroPython list
stijn
Post by stijn » Fri May 02, 2014 3:46 pm
pfalcon wrote:But I still don't get how you got from backslashes to NLR failure
Me neither. On unix it 'properly' segfaults.
igorgatis
Post by igorgatis » Thu Nov 19, 2015 9:41 pm
So, the recommendation is to turnoff libffi on windows?
I believe I do have libffi installed on my cygwin environment. Still, I'm getting same error messages.
What's the main consequence of turning libffi off?
Post by Roberthh » Fri Nov 20, 2015 5:58 am
It builds under native Windows. I'm tried it with Windows 7/MinGW32. But I'm not using it a lot. Just to have it around.
stijn
Post by stijn » Fri Nov 20, 2015 8:09 am
igorgatis wrote:So, the recommendation is to turnoff libffi on windows?
What error messages exactly? The ones from the first post in this thread? And what compiler ae you using to build uPy?
igorgatis
Post by igorgatis » Fri Nov 20, 2015 5:04 pm
Yes, same error messages. I'm using cygwin's gcc 5.2.0.
stijn
Post by stijn » Fri Nov 20, 2015 8:00 pm
Hmm maybe I should update my cygwin installation then (I thought the setup.exe did it automatically?), mine is at version 4.9.3. In any case I'm having the same problem, x86 and x64 builds, yet according to setup.exe everything ffi-related is installed so I'm starting to think the cygwin ffi thing is just broken?
To answer your question: without ffi there's no uPy ffi module and parts of micropython-lib won't work as it uses ffi.
pfalcon
Post by pfalcon » Sat Nov 21, 2015 1:03 am
But micropython-lib doesn't have support for cygwin libc loading anyway (but it would be pretty easy to add, definitely much easier than for native Windows API).
