[STM32F401CE] debugging a new board definition [solved]
When I compile I get these errors:
In file included from led.c:34:0:
build-PYFLEX_F401/genhdr/pins.h:26:19: error: ISO C99 requires whitespace after the macro name [-Werror]
#define pyb_pin_J1-7 pin_A5
build-PYFLEX_F401/genhdr/pins.h:27:19: error: ISO C99 requires whitespace after the macro name [-Werror]
#define pyb_pin_J1-8 pin_A4
The names in pins.csv look like this:
J1-1,VSS
J1-2,VSS
#J1-3,18V_ONBOARD
#J1-4,18V_ONBOARD
J1-5,VSS
J1-6,VSS
J1-7,PA5
J1-8,PA4
Ideas what's going wrong?
J1-1,VSS
J1-2,VSS
#J1-3,18V_ONBOARD
#J1-4,18V_ONBOARD
J1-5,VSS
J1-6,VSS
J1-7,PA5
J1-8,PA4
John Griessen blog.kitmatic.com
Re: [STM32F401CE] debugging a new board definition
You can't use a '-' in the macro name, it's a C operator. Changing them to underscore should work.
I have gone over my names in pins.csv, making it a map from datasheet pin names to my module names.
I get an error related to mpconfigboard.h now:
I also get errors for these pins before commenting them out:
// #define MICROPY_HW_SPI2_SCK (pin_B13)
// #define MICROPY_HW_SPI2_MISO (pin_B14)
// #define MICROPY_HW_SPI2_MOSI (pin_B15)
Not sure where to look next. Pins B10, B13, B14, B15 are all in the datasheet...
These were enabled:
#define MICROPY_HW_HAS_SWITCH (1)
#define MICROPY_HW_HAS_FLASH (1)
#define MICROPY_HW_ENABLE_RTC (1)
#define MICROPY_HW_ENABLE_TIMER (1)
The rest were (0).
#define MICROPY_HW_ENABLE_TIMER (1) was not included for NUCLEO_F401RE platform. Why is that?
Meanwhile, I have disabled MICROPY_HW_HAS_SWITCH and testing that way shows not normal USB port functions,
so looking into REPL on serial port as way forward. DFU worked. That says USB port physically works, and two-ways.
arm-none-eabi-gcc -I. -I../.. -Ibuild-PYFLEX_F401 -I../../lib/cmsis/inc -I../../lib/stm32lib/CMSIS/STM32F4xx/Include/ -I../../lib/stm32lib/STM32F4xx_HAL_Driver/Inc -Iusbdev/core/inc -Iusbdev/class/inc -Wall -Wpointer-arith -Werror -std=gnu99 -nostdlib -DFFCONF_H=\"lib/oofatfs/ffconf.h\" -DSTM32F401xE -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mtune=cortex-m4 -mcpu=cortex-m4 -DMCU_SERIES_F4 -Os -DNDEBUG -Iboards/PYFLEX_F401 -DSTM32_HAL_H='<stm32f4xx_hal.h>' -DMICROPY_FLOAT_IMPL=MICROPY_FLOAT_IMPL_FLOAT -fsingle-precision-constant -Wdouble-promotion -fdata-sections -ffunction-sections -DMICROPY_QSTR_EXTRA_POOL=mp_qstr_frozen_const_pool -DMICROPY_MODULE_FROZEN_MPY -c -MD -o build-PYFLEX_F401/usrsw.o usrsw.c
In file included from ./mpconfigport.h:31:0,
from ../../py/mpconfig.h:45,
from ../../py/mpstate.h:31,
from ../../py/runtime.h:29,
from usrsw.c:29:
usrsw.c: In function 'switch_init0':
boards/PYFLEX_F401/mpconfigboard.h:59:38: error: 'pin_B10' undeclared (first use in this function)
#define MICROPY_HW_USRSW_PIN (pin_B10)
These were enabled:
The rest were (0).
Since you have in your mpconfig.h file, you also need to ensure that pin B10 is in your generated build-BOARDNAME/pins_BOARDNAME.c file, which means that it needs to be in your pins.csv file.
The usual convention is to call is SW. You should similarly have B13, etc in your pins.csv file. Something like: The actual pin names (i.e. the SPI2_MOSI portion) don't really matter, but they have to be present or there won't be a pin generated.
The pins_BOARDNAME.c file only includes the pins mentioned in pins.csv and not all of the possible pins in order to reduce the amount of flash consumed.
SPI2_SCK,B13
SPI2_MISO,B14
SPI2_MOSI,B15
Oh, thanks Dave.it needs to be in your pins.csv file.
Ah so. I'll fix the pins.csv file, then try boot to serial port via my FT2232HQ connected to PA2, PA3. That will keep me busy for a while.Control-C doesn't work on a serial REPL, you'll want to make sure that you boot to the REPL. You'll also need to use the --buffer-size=32 option.
On second thought, I'm reading about frozen compilation as a way to load micropython and platform code like I seem to have done, and modules that will verify pins are defined and application code runs. then figure why the REPL over USB is not working.
Any other ideas why DFU works, but lsusb shows no STM device, and no virtual filesystem and rshell finds no micropython to talk to on the USB?
Does your HSE_VALUE found in stm32f4xx_hal_conf.h match the value of the crystal that you're using?
If you changed the HSE_VALUE (from whatever board file you used as a template), did you also change the MICROPY_HW_CLK_PLLx constants (found in mpconfigboard.h) to give 48 MHz output for the USB clock?
I generally find another board with the same crystal and copy the 4 values from that mpconfigboard.h file. If there isn't one, then I sit down and fill in the values according to the constraints given in the RCC_PLLCFGR register.
There is a little set of formulas at the top, and each of the 4 fields in the register (PLLQ, PLLP, PLLN, PLLM) shows the contraints.
I used the cubemx tool to get the four values. My HSE 16MHz crystal is running confirmed by light loading active probe directly on the OSC_OUT_PH1 pin.
cubemx showed all the constraints satisfied: https://www.cibolo.com/docs/STM32cubemx-clocks.png
excerpt from mpconfigboard.h
// HSE is 16MHz - F401 does 84 MHz max
#define MICROPY_HW_CLK_PLLM (16)
#define MICROPY_HW_CLK_PLLN (336)
#define MICROPY_HW_CLK_PLLP (RCC_PLLP_DIV4)
#define MICROPY_HW_CLK_PLLQ (7)
From STM32F4xD/E ref manual, here are the constraints for double checking cubemx:
RCC PLL configuration register (RCC_PLLCFGR) This register is used to configure the PLL clock outputs according to the formulas:
• f (VCO clock) = f (PLL clock input) × (PLLN / PLLM) ================================> [ = 16 * 336 / 16 = 336]
• f (PLL general clock output) = f (VCO clock) / PLLP ================================> [ = 336 / 4 = 84]
• f (USB OTG FS, SDIO, RNG clock output) = f (VCO clock) / PLLQ =======================> [ = 336 / 7 = 48]
USB OTG FS clock frequency = VCO frequency / PLLQ with 2 ≤ PLLQ ≤ 15
So all constraints are satisfied in this calculation also.
The only thing not checked twice is define MICROPY_HW_CLK_PLLP (RCC_PLLP_DIV4)
Why not enter 4 instead of RCC_PLLP_DIV4 as in other platforms? Where does RCC_PLLP_DIV4 get defined?
RCC_PLLP_DIV4 comes from the HAL. It appears to be set to 4 for all of the platforms we're currently using.
Why this is used instead of just 4 is probably historical. It's possible that at some point in time it didn't have the value 4 (i.e. it may have held the bitmask used instead of the value).
What do you have MICROPY_HW_CLK_LAST_FREQ set to? Try setting it to zero. Setting it to 1 seems to cause the frequency to come from the RTC (just based on a quick perusal of system_stm32.c)
Otherwise, your values look reasonable to me.
What does pyb.freq() output?
I don't have a REPL on this new hardware.What does pyb.freq() output?
DFU seems to work, but then no USB communication.
I just redid a compile with frozen code and deploy-stlink. script below:
#!/bin/bash
# make_with_frozen_PYFLEX_F401.sh
echo Building for $BOARD
export FROZEN_DIR="/home/john/Documents/EEProjects/circuitboards/culture_shock/code_PYFLEX_F401/frozen"
if [ $BOARD ]
then
cd /home/john/micropython/ports/stm32
if [ $1 == "--clean" ]
then
make BOARD=$BOARD clean
exit
fi
if make -j 2 BOARD=$BOARD FROZEN_MPY_DIR=$FROZEN_DIR
then
sleep 1
make BOARD=$BOARD deploy-stlink
cd -
# sleep 1
# rshell
else
echo Build failure
fi
else
echo "Wrong board type."
fi
./make_with_frozen_PYFLEX_F401.sh
Building for PYFLEX_F401
./make_with_frozen_PYFLEX_F401.sh: line 11: [: ==: unary operator expected
Generating build-PYFLEX_F401/genhdr/mpversion.h
CC ../../py/modsys.c
CC ../../py/../extmod/modwebrepl.c
CC ../../lib/utils/pyexec.c
CC moduos.c
LINK build-PYFLEX_F401/firmware.elf
text data bss dec hex filename
297048 28 44000 341076 53454 build-PYFLEX_F401/firmware.elf
Create build-PYFLEX_F401/firmware.dfu
Create build-PYFLEX_F401/firmware.hex
Writing build-PYFLEX_F401/firmware0.bin to the board via ST-LINK
st-flash 1.4.0-25-ge9fe4e5
2018-04-05T10:37:32 INFO common.c: Loading device parameters....
2018-04-05T10:37:32 INFO common.c: Device connected is: F4 device (Dynamic Efficency), id 0x10006433
2018-04-05T10:37:32 INFO common.c: SRAM size: 0x18000 bytes (96 KiB), Flash: 0x80000 bytes (512 KiB) in pages of 16384 bytes
2018-04-05T10:37:32 INFO common.c: Attempting to write 14868 (0x3a14) bytes to stm32 address: 134217728 (0x8000000)
Flash page at addr: 0x08000000 erased
2018-04-05T10:37:32 INFO common.c: Finished erasing 1 pages of 16384 (0x4000) bytes
2018-04-05T10:37:32 INFO common.c: Starting Flash write for F2/F4/L4
2018-04-05T10:37:32 INFO flash_loader.c: Successfully loaded flash loader in sram
enabling 32-bit flash writes
2018-04-05T10:37:33 INFO common.c: Starting verification of write complete
2018-04-05T10:37:33 INFO common.c: Flash written and verified! jolly good!
Writing build-PYFLEX_F401/firmware1.bin to the board via ST-LINK
2018-04-05T10:37:33 INFO common.c: Loading device parameters....
2018-04-05T10:37:33 INFO common.c: Device connected is: F4 device (Dynamic Efficency), id 0x10006433
2018-04-05T10:37:33 INFO common.c: SRAM size: 0x18000 bytes (96 KiB), Flash: 0x80000 bytes (512 KiB) in pages of 16384 bytes
2018-04-05T10:37:33 INFO common.c: Attempting to write 282208 (0x44e60) bytes to stm32 address: 134348800 (0x8020000)
Flash page at addr: 0x08060000 erasedEraseFlash - Sector:0x7 Size:0x20000
2018-04-05T10:37:36 INFO common.c: Finished erasing 3 pages of 131072 (0x20000) bytes
2018-04-05T10:37:36 INFO common.c: Starting Flash write for F2/F4/L4
2018-04-05T10:37:36 INFO flash_loader.c: Successfully loaded flash loader in sram
2018-04-05T10:37:40 INFO common.c: Starting verification of write complete
2018-04-05T10:37:42 INFO common.c: Flash written and verified! jolly good!
Since the first code I loaded to this STM32F401CE via openocd via stlinkV2.1 the PB8 pin has been going hi for 4 secs lo for 4 secs.
Loading the new code which should have had PB8 and PB9 flashing .25 secs out of every 1 second did not change this.
Summary: USB port does not work (no REPL over USB). SWD pins seem to work checked by openocd program via SWD pins.
Even though openocd claims verified load, behavior does not change.
My frozen directory python files are below, and no others:
frozen/boot.py
# boot.py -- run on boot-up
pyb.freq(84000000)
pyb.main('pintest.py')
from pyb import Timer
import micropython
import stm
# Use with pyb.freq(84000000) and prescaler=20 for .25 usec timer ticks.
xfmr_pulse_period = 4000000 # = (usec * 4) 700ms
xfmr_pulse_w = 900000 # = (usec * 4) 225ms
pos_pulse_total = 0
pos_pulse_burstlen = 50007
neg_pulse_total = 0
neg_pulse_burstlen = 50007
# Timer 2 to give .25 usec timer ticks counting up:
t2 = pyb.Timer(2, prescaler=20, period=xfmr_pulse_period, mode=Timer.UP)
# xfmr pulse half_cycle timing. (OC rollover callback)
# JP27 output and interrrupt. Compare generates interrupt:
t2ch3 = t2.channel(3, pyb.Timer.OC_TOGGLE, compare=xfmr_pulse_period,
polarity=pyb.Timer.HIGH, pin=pyb.Pin.board.LED_GREEN)
t2ch2 = t2.channel(2, pyb.Timer.OC_TOGGLE, compare=xfmr_pulse_period,
polarity=pyb.Timer.HIGH, pin=pyb.Pin.board.LED_YELLOW)
# Define already set up pins so they can be read with a pin reference like: pin8.value() on the fly.
pin8 = pyb.Pin.board.LED_GREEN
pin9 = pyb.Pin.board.LED_YELLOW
# Define pins so they can be set with a pin reference like: pin10.value(1) on the fly.
pinB10 = pyb.Pin('PB10', pyb.Pin.OUT_PP)
pinB13 = pyb.Pin('PB13', pyb.Pin.OUT_PP)
pinB14 = pyb.Pin('PB14', pyb.Pin.OUT_PP)
pinB15 = pyb.Pin('PB15', pyb.Pin.OUT_PP)
for i in range(30):
pinB10.value(1)
time.sleep(1.0)
pinB10.value(0)
pinB13.value(1)
time.sleep(1.0)
pinB13.value(0)
pinB14.value(1)
time.sleep(1.0)
pinB14.value(0)
pinB15.value(1)
time.sleep(1.0)
pinB15.value(0)
pinB3.value(1)
time.sleep(1.0)
pinB3.value(0)
pinB4.value(1)
time.sleep(1.0)
pinB4.value(0)
pinB5.value(1)
time.sleep(1.0)
pinB5.value(0)
pinB6.value(1)
time.sleep(1.0)
pinB6.value(0)
pinB7.value(1)
time.sleep(1.0)
pinB7.value(0)
Not sure if this is relevant or not, but you've got an error in your build script:
