PyBoard v3 compatible - aliexpress - sanmuchina.com
maerki
Post by maerki » Fri Jun 08, 2018 10:03 pm
Aliexpress sells a cheap STM32F4-board which runs micropython and turned out to be compatible to a PyBoard v3.
I documented the board here: https://github.com/hmaerki/micropython/ ... sanmuchina.
Re: PyBoard v3 - aliexpress - sanmuchina.com
Post by dhylands » Fri Jun 08, 2018 11:45 pm
It doesn't look like the PYBv3 either, since that appears to only have a single row of pins.
See: https://github.com/micropython/pyboard/ ... sembly.pdf
That's what the PYBv3 board looked like (if you believe github).
maerki
Re: PyBoard v3 compatible - aliexpress - sanmuchina.com
Post by maerki » Sat Jun 09, 2018 7:06 am
Hi Dave
Thanks for you input. The board ist just PyBoard v3 compatible (as far as I tested). I updated my blog-entry accordingly.
