uart.StreamReader and asyncio no data
kurt
Post by kurt » Wed Jul 04, 2018 10:01 am
run MicroPython v1.9.4-241-g14ab81e on my ESP8266 nodemcu board.
load
import uasyncio as asyncio
uart = UART(0, 115200)
async def sender():
    swriter = asyncio.StreamWriter(uart, {})
        await swriter.awrite('Hello uart\n')
        await asyncio.sleep(2)
async def receiver():
    sreader = asyncio.StreamReader(uart)
        res = await sreader.readline()
        print('Recieved', res)
loop.create_task(sender())
loop.create_task(receiver())
loop.run_forever()
which I copied from https://github.com/peterhinch/micropyth ... -mechanism
and got the following output
Hello uart
Hello uart
Hello uart
File "main.py", line 20, in <module>
File "uasyncio/core.py", line 77, in run_forever
File "uasyncio/__init__.py", line 69, in wait
KeyboardInterrupt:
MicroPython v1.9.4-241-g14ab81e on 2018-07-04; ESP module with ESP8266
>>> asdf
NameError: name 'asdf' is not defined
I expected to get the typed input printed out: Recieved asdf
As I understand the typed input is passed to stdin and not to sreader.readline().
Any help is welcome.
Regards
Kurt
Re: uart.StreamReader and asyncio no data
Post by pythoncoder » Thu Jul 05, 2018 7:50 am
That code is intended to be run on a Pyboard or similar, using a UART which is not used for the REPL. A wire link between the UART's Txd and Rxd provides a "loopback" for the test.
Running it on the ESP8266 is problematic because the chip has only one UART which is used for the REPL. Further, when you interrupt the script with ctrl-C it stops running. In Python you are either running a script or interacting with Python at the REPL. (There are special cases in MicroPython where scripts can run in the background, but this simple script isn't one of them).
The fact that the ESP8266 has only one UART is problematic: if you want to work with UARTs the ESP32 (or Pyboard if you don't need WiFi) are better platforms.
It might be best if you explained what you're trying to do, then maybe someone will come up with suggestions.
kurt
Post by kurt » Thu Jul 05, 2018 9:33 am
Hi Peter,
sorry, you are absolutly right.
My application uses a 3 by 4 keypad matrix and an RFID reader connected via UART to the ESP8266 (at a second solution a RFC522 is connected via SPI, instead. This runs fine). With the asyncio functionalty of micropython, I'm able to run tasks for check keypad matrix, check uart if rfid card is presented by the user, check two buttons connected to ADC, get ntp time, check network, write syslog. Using asyncio makes me my programmer life much easier. At the end, two relayes are driven to open and close two doors.
The problem is getting the seriell data via UART which are not passed to my application. It seems micropython virtual machine catch the data and pass it to stdin. Now, I could use sys.stdin, but I don't know how to timeout sys.stdin to give the other tasks a chance to run. Therefore I thougth "asyncio.StreamReader(uart)" could help me.
As I used micropython 1.9.3 UART data are passed through my application, but not with 1.9.4. Unfortunately, it's not easy for me to go back to 1.9.3 because the application doesn't fit in the ram. I need to build it all by compile the source from github.
The above coding was an attempt to show the problem in a general manner.
Here the part of the code, which should read in UART data:
        uart = UART(0, 9600)                         # init with given baudrate
        uart.init(9600, bits=8, parity=None, stop=1) # init with given config
            if uart.any():
                c = uart.read()
                num = c[0:10]
Hope my long story is understandable.
Kurt
Post by pythoncoder » Fri Jul 06, 2018 6:49 am
That way of reading a UART will block. If you're expecting exactly 10 chars from the UART you need to do something like
    while uart.any() < 10:
        await asyncio.sleep(0)
    c = uart.read(10)
Or use a StreamReader:
        c = await sreader.read(10)
If data arrives in lines it's best to use the StreamReader.readline() method.
kurt
Post by kurt » Fri Jul 06, 2018 7:57 am
Hi Peter,
I used
loop.run_forever()
load it as main.py, pressed reset, and enter via PuTTY from my PC random characters, like "asdf".
With MicroPython v1.9.3-8-g63826ac5c on 2017-11-01; ESP module with ESP8266, I get after hit ctrl-C:
File "main.py", line 14, in <module>
KeyboardInterrupt:
With MicroPython v1.9.4-244-g106e594 on 2018-07-06; ESP module with ESP8266, I get after hit ctrl-C
File "uasyncio/core.py", line 90, in run_forever
KeyboardInterrupt:
>>> asdf
In both cases, I did not see a print with the characters, I typed in, like "asdf".
As you can see, MicroPython version 1.9.4 differs from 1.9.3 in the behaviour.
What I want: I like to get the typed character, like "asdf", read into my application. This seems not to be done, otherwise the print statement would printout the characters.
What could be wrong on my side?
Regards
Kurt
Post by pythoncoder » Sat Jul 07, 2018 8:09 am
I am not sure. The problem (I think) is that the ESP8266 has only one UART which is expected to do duty supporting the REPL. If a program takes over the UART for its own purposes then REPL output is likely to be suppressed. Which is why you never see "Received asdf". Incidentally you'd need to type asdf<Enter> for sreader.readline() to return.
In my own work with the ESP8266 I regarded the UART as unusable and performed I/O by other means. This because I needed it for printing debugging messages. The thought of trying to develop a program without access to debug print statements is not one I relish. I would use a platform with more than one UART.
I think some people have had success with the ESP8266 UART: perhaps someone will pop up, otherwise try a forum search.
kevinkk525
Post by kevinkk525 » Sat Jul 07, 2018 2:43 pm
Looks like this guy got the uart to work:
viewtopic.php?f=16&t=4924&p=28368&hilit=uart#p28368
This will disable the repl during the usage of the uart.
Kevin Köck
kurt
Post by kurt » Sat Jul 07, 2018 9:36 pm
Hi kevinkk525,
thanks for presenting the link. Unfortunately, it does not change anything.
I extend my test app to get WebREPL by start a network connection.
import uos
uos.dupterm(None, 1)
uart.init(115200, bits=8, parity=None, stop=1)
wlan_sta = network.WLAN(network.STA_IF)
wlan_sta.active(True)
wlan_sta.connect('SSID','Password')
while not wlan_sta.isconnected():
    pass
        print('before readline')
async def other_task():
        print('other_task')
        await asyncio.sleep(1)
loop.create_task(other_task())
loop.run_forever()
Do a reset, connect via WebREPL and get the following output:
other_task
before readline
other_task
other_task
other_task
other_task
other_task
other_task
other_task
other_task
other_task
File "main.py", line 33, in <module>
KeyboardInterrupt:
>>> asdf
Regardless of uos.dupterm(None) or uos.dupterm(None, 1) or without uos.dupterm always the same behaviour. Always the typed input are passed to MicroPython stdin only. As you can see readline() waits on input for ever.
May be I'm wrong, but dupterm does a duplication of terminal input to REPL or WebREPL. Means, the application should get the data anyway. Or?
Peter, you are right using UART for more than debugging is not a good idea. A change to another platform is not the way, I like to go.
Change to C with FreeRTOS would be a choice, but the effort is enormous.
I'm still looking for a solution in MicroPython.
Any idea is highly welcome.
Regards
Kurt
kurt
Post by kurt » Sun Jul 08, 2018 6:22 am
problem solved by
uos.dupterm(None) and !!! uos.dupterm(None, 1).
Means both have to be set. REPL and WebREPL are not more usable with this setup, for shure. I have to find an other way to communicate with the app, may be an own web server.
Here my test app:
import uos
from machine import UART, Pin
uos.dupterm(None)
    if uart.any():
        c = uart.read()
        if c == b'1':
            led = Pin(2, Pin.OUT)
            led.off()  # led on
            time.sleep(1)
            led.on()   # led off
Many thanks to all.
Regards
Kurt
tonyldo
Post by tonyldo » Wed Jul 25, 2018 8:38 pm
problem solved by
Here my test app:
import uos
uos.dupterm(None)
    if uart.any():
        c = uart.read()
        if c == b'1':
            led.off()  # led on
            time.sleep(1)
            led.on()   # led off
Many thanks to all.
Regards
Kurt
I wanna disable the RX pin from uart. Do you know if this possible?
import uos
uos.dupterm(None)
//Does rx Keyworld parameter can be None???
uart.init(115200, bits=8, parity=None, stop=1, rx = None)
I wanna use de RX pin (Gpio 3) from esp 01 for general input pin!
