MicroPython - ESP32 - Is is possible to update files?
I'm using ESP32 to activate a scheduled GPIO on and off ( relay ).
Time schedule is defined in a file saved on ESP32.
Is it possible to change this text file while ESP32 is not connected to PC using cable (ESP32 is already installed on remote location ) ?
Guy
Guy
Re: MicroPython - ESP32 - Is is possible to update files?
If WiFI is activated, it may be possible. But that requires some agent being active on that device, like WebRepl.
Yes, Wifi is activated, but WEBRepl is available for ESP32 ?
Do u have a ftp server running on the ESP32??
Not one that I know of
You could use the loboris fork for esp32 which has a ftp-server built-in which just has to be enabled. Then you can easily modify that file.
A different approach would be to get the value you have in the file by mqtt subscription.
Kevin Köck
Thank you for your answer.
1) I look for loboris - it seems interesting. Does it mean I'll have to flash a new bin of Micropython ? BTW - it is possible to run telnet without loboris ?
2) This is another way to look at it ")
1) yes, you can download the prebuilt firmware on his repository and flash it.
1b) I have not heard of telnet outside of loboris fork
Kevin Köck
See this telnet server.
TNKU very much - very usefull!
another- installing FTP server to gain ability to update file remotely.
