MQTT library and thingsboard
I am using mqtt library for micropython, and when connecting to thingsboard via mqtt, it required to supply username with authentication token and password set to "" (no password). Using no password, mqtt libray is failed to connect, while if I connect to another mqtt broker with password, it work just okay. I think it has something to do with the library. It doesn't support "" (empty) password.
Re: MQTT library and thingsboard
It should work if you don't supply a password to the constructor, or pass None. The default is None. This is different to "".
pythoncoder wrote: ↑Wed Aug 22, 2018 10:52 amIt should work if you don't supply a password to the constructor, or pass None. The default is None. This is different to "".
if I don't supply any password, it will raise exception TypeError 'NoneType' has no length at simple.py line 60
Yep, looks like a bug to me(it's actually line 68, AFAICS). Code doesn't check whether self.pswd is None or an empty string and sets the password flag in the connect flags regardless. It inccorrectly assumes that if the user is set, the password is not none.
Well spotted: in my testing neither was supplied. I suggest you raise an issue or PR. I guess you need something like:
sz += 2 + len(self.user) + 2 + (len(self.pswd) if self.pswd is not None else 0)
The broker may handle an empty password differently than no password being supplied. I think the code should rather be something like:
And below at line 95:
BTW, where does one submit PRs to micropython-lib these days? At https://github.com/micropython/micropython-lib/ or https://github.com/pfalcon/micropython-lib ? The former hasn't seen a commit since february.
if self.user is not None:
msg[6] |= 1 << 7
if self.pswd is not None:
sz += 2 + len(self.pswd)
msg[6] |= 1 << 6
self._send_str(self.user)
self._send_str(self.pswd)
My understanding is that the official library is https://github.com/micropython/micropython-lib.git - ref this post from Damien.
Since the unfortunate loss of @pfalcon as a maintainer, library PR's are not always handled in a timely fashion. This is why I (reluctantly) maintain a fork of uasyncio. I'd hope that a bugfix PR will achieve a higher priority response than my efforts at enhancements.
The official project for micropython-lib by its author is at https://github.com/pfalcon/micropython-lib . Bugreports/pull requests are welcome there.BTW, where does one submit PRs to micropython-lib these days? At https://github.com/micropython/micropython-lib/ or https://github.com/pfalcon/micropython-lib ? The former hasn't seen a commit since february.
Awesome MicroPython list
