Maximum possible machine.Timer period
I'm new to the forum, thanks for such a beautiful development platform!
What is the maximum period I can set for a Timer?
I set it carelessly to 6 hours — 1000 * 60 * 60 * 6 == 21600000 — and from server access logs it's seems it's not being called at all.
Here the code:
period = 21600000
timer = machine.Timer(-1)
timer.init(period=period,
callback=lambda timer:
micropython.schedule(timer_cb, timer),
mode=machine.Timer.PERIODIC)
It works with shorter intervals like 60000 (1min)
P.S.: no code formatting allowed to me? Well, luckily I can spam as many smiles as I want
Here the code:
period = 21600000
Re: Maximum possible machine.Timer period
Bump!
So no one's interested in a working Timer on spans bigger than 1 minute?
What hardware are you using?neurino wrote:Bump!
I don't know why it's failing. You are able to set up to a maximum of UINT32 so a value of 21 million should be ok.neurino wrote: ↑Wed Aug 08, 2018 8:22 amHello,
Here the code:
period = 21600000
Try setting the period to 65536. which is one bigger than a UINT16.
If that doesn't fail, keep increasing it until you reach the point it does fail.
Let me know (by quoting this post).
It's somewhere between 120000 (gets called) and 480000 (NOT called).jickster wrote: ↑Thu Aug 30, 2018 9:12 pmI don't know why it's failing. You are able to set up to a maximum of UINT32 so a value of 21 million should be ok.neurino wrote: ↑Wed Aug 08, 2018 8:22 amHello,
Here the code:
period = 21600000
I hope I can avoid trying to find the exact threshold
Here the code:
import micropython
def timer_cb(timer):
print('here', timer)
period = 480000
callback=lambda timer: micropython.schedule(timer_cb, timer),
Those numbers don't stand out to me.neurino wrote: ↑Mon Sep 03, 2018 4:15 pmIt's somewhere between 120000 (gets called) and 480000 (NOT called).jickster wrote: ↑Thu Aug 30, 2018 9:12 pmI don't know why it's failing. You are able to set up to a maximum of UINT32 so a value of 21 million should be ok.neurino wrote: ↑Wed Aug 08, 2018 8:22 amHello,
Here the code:
period = 21600000
Here the code:
import machine import micropython def timer_cb(timer): print('here', timer) period = 480000 timer = machine.Timer(-1) timer.init(period=period, callback=lambda timer: micropython.schedule(timer_cb, timer), mode=machine.Timer.PERIODIC)
I think something else is going on.
Do you have access to a C-debugger?
Sorry, no debugger,
haven't anyone out there been able to reproduce the issue?
I mean someone with an ESP8266 ruing these few lines and seeing if he gets timer_cb called or not after 6 minutes (480000ms)
import micropython
period = 480000
Why are you using .schedule?neurino wrote:Sorry, no debugger,
On my side, I started relying on a DS3231 alarm to trigger my hourly job, however getting this fixed would really help in other projects.Code: Select all
Simply because I read it here: https://docs.micropython.org/en/latest/ ... rules.html
etc* Avoid memory allocation: no appending to lists or insertion into dictionaries, no floating point.
* Consider using micropython.schedule to work around the above constraint.
