How do I make a port of MicroPython for Casio calculators?
Zezombye
Re: How do I make a port of MicroPython for Casio calculators?
Post by Zezombye » Mon Sep 03, 2018 10:59 am
There you go: https://youtu.be/X9MSxI2BVK0
If you want to try it yourself, you can always use the emulator:
- Download the emulator at https://edu.casio.com/freetrial/fr/free ... LANGUAGE=1
- Download the program (.g1a) at https://www.planet-casio.com/Fr/program ... howid=3603
- Install the emulator, open the shortcut on desktop
- Go to memory menu, press F3 (SD)
- Select the g1a you downloaded, and when prompted press 2 for storage memory
- Go at the bottom of the main menu and select the python icon.
Zezombye
Post by Zezombye » Mon Sep 03, 2018 5:41 pm
I managed to make the import statement work how I want to ("import test" imports from the file test.py), however I found that it doesn't close the file if an error happens (syntax error, or out of memory error for example).
I just overrode the close, read and open functions in reader.c with the Casio ones (which are very similar in function, if not the exact same).
How do I make sure MPy closes the file? I can't put the file handle in global and close it myself, because multiple file handles might be opened.
jickster
Post by jickster » Mon Sep 03, 2018 7:53 pm
When you call the sequence of functions to compile and execute
                mp_lexer_t * lex = mp_lexer_new_from_str_len(0, ptr_code, (size_t)code_length, (size_t)0);
		mp_parse_tree_t parse_tree = mp_parse(lex, parse_type);
		mp_obj_t module_func = mp_compile(&parse_tree, lex->source_name, MP_EMIT_OPT_NONE, repl);
		mp_call_function_0(module_func);
mp_parse calls mp_lexer_free()
    // we also free the lexer on behalf of the caller
    mp_lexer_free(lex);
Which calls a function pointer to close the file
void mp_lexer_free(mp_lexer_t *lex) {
    if (lex) {
        lex->reader.close(lex->reader.data);
        vstr_clear(&lex->vstr);
        m_del(uint16_t, lex->indent_level, lex->alloc_indent_level);
        m_del_obj(mp_lexer_t, lex);
Which should've been set in
void mp_reader_new_file_from_fd(mp_reader_t *reader, int fd, bool close_fd) {
    mp_reader_posix_t *rp = m_new_obj(mp_reader_posix_t);
    rp->close_fd = close_fd;
    rp->fd = fd;
    int n = read(rp->fd, rp->buf, sizeof(rp->buf));
    if (n == -1) {
        if (close_fd) {
            close(fd);
        mp_raise_OSError(errno);
    rp->len = n;
    rp->pos = 0;
    reader->data = rp;
    reader->readbyte = mp_reader_posix_readbyte;
    reader->close = mp_reader_posix_close;
Called in
mp_lexer_t *mp_lexer_new_from_fd(qstr filename, int fd, bool close_fd) {
    mp_reader_t reader;
    mp_reader_new_file_from_fd(&reader, fd, close_fd);
    return mp_lexer_new(filename, reader);
Conceptually this should make sense to you that the file is closed at the end of mp_parse().
Once the text of a .py has been digested, by the parsing stage, into a tree of data-structures for the compiler to consume, there's no need for the file to be open.
Obviously replace the relevant function pointers with your own `Bfile*()` functions
jickster
Post by jickster » Mon Sep 03, 2018 8:05 pm
Ok I realize I didn't answer your question with my last post.
jickster
Post by jickster » Mon Sep 03, 2018 8:29 pm
I think you've found a bug.
When a syntax error happens, following lines from mp_parse() execute:
   syntax_error:;
        mp_obj_t exc;
        if (lex->tok_kind == MP_TOKEN_INDENT) {
            exc = mp_obj_new_exception_msg(&mp_type_IndentationError,
                "unexpected indent");
        } else if (lex->tok_kind == MP_TOKEN_DEDENT_MISMATCH) {
                "unindent does not match any outer indentation level");
        } else {
            exc = mp_obj_new_exception_msg(&mp_type_SyntaxError,
                "invalid syntax");
        // add traceback to give info about file name and location
        // we don't have a 'block' name, so just pass the NULL qstr to indicate this
        mp_obj_exception_add_traceback(exc, lex->source_name, lex->tok_line, MP_QSTR_NULL);
        nlr_raise(exc);
The information stored in the exception does NOT contain the "fd" stored in reader->data necessary to close the file.
    rp->fd = fd;
    if (n == -1) {
        if (close_fd) {
            close(fd);
    rp->len = n;
    rp->pos = 0;
    reader->data = rp;
Issue is https://github.com/micropython/micropython/issues/4095
Zezombye
Post by Zezombye » Fri Sep 07, 2018 5:24 pm
I am perplexed by this bit of code:
typedef struct _mp_reader_posix_t {
    bool close_fd;
    int fd;
    size_t len;
    size_t pos;
    byte buf[25];
} mp_reader_posix_t;
STATIC mp_uint_t mp_reader_posix_readbyte(void *data) {
    mp_reader_posix_t *reader = (mp_reader_posix_t*)data;
    if (reader->pos >= reader->len) {
        if (reader->len == 0) {
            return MP_READER_EOF;
        } else {
            //int n = read(reader->fd, reader->buf, sizeof(reader->buf));
			int n = Bfile_ReadFile(reader->fd, reader->buf, sizeof(reader->buf), reader->pos);
            if (n <= 0) {
                reader->len = 0;
            reader->len = n;
            reader->pos = 0;
    return reader->buf[reader->pos++];
Basically the buffer causes errors for files bigger than it (it was originally 20, but I increased it to 25 to be sure it was the buffer).
For a buffer of 25:
- Importing a file of 0-25 bytes is no problem.
- Importing a file of 26-51 bytes throws a "syntax error"
- Importing a file of 52 bytes or more throws a memory error (allocation failed).
Why is this buffer so low, and not dynamically allocated?
Also, the function Bfile_ReadFile takes the same arguments as the read() function, but with the position at the end. What I don't understand is that the reader->pos is reset to 0 at each byte read, so it should always read the first byte of the file, but it doesn't. How does it work?
jickster
Post by jickster » Fri Sep 07, 2018 7:23 pm
    bool close_fd;
    int fd;
    size_t len;
    size_t pos;
    byte buf[25];
        } else {
            if (n <= 0) {
                reader->len = 0;
            reader->len = n;
            reader->pos = 0;
For a buffer of 25:
The reason why this is not straightforward is because an optimization was made: instead of calling "read()" everytime you want to read ONE byte, this function reads in a chunk of 25 bytes at a time.
The naming of the struct members could be clearer.
reader->len
is the number of bytes obtained from "read()". This number will be sizeof(reader->buf) until you reach near the end of the file when you have less than sizeof(reader->buf) bytes left to read.
Ideally it would be named "reader->num_chars_in_buf"
reader->pos
is the position inside the reader->buf for the next character.
Ideally it would be named "reader->pos_next_char_in_buf"
For "Bfile_ReadFile" to be a drop-in replacement for "read", it has to behave exactly like "read()".
Does it? I don't have the description of it.
Does it return the actual number of bytes that were read?
https://gist.github.com/holubv/89df8019 ... 7659727d0e
* Reads data from a file, starting at the position indicated by the file pointer. After the
* read operation has been completed, the file pointer is adjusted by the number of bytes actually read.
* @param HANDLE This is the handle of the file to read. HANDLE should be the handle opened by the Bfile_OpenFile or
* Bfile_OpenMainMemory function.
* @param buf This is the pointer to the buffer that receives the data read from the file.
* @param size This is the number of bytes to be read from the file.
* @param readpos This is the starting position to read. If the readpos parameter is -1, this function reads data from the position
* indicated by the file pointer. If the readpos parameter greater than or equal to 0, this function reads data from
* the position indicated by the readpos parameter.
* @return If the function succeeds, this function returns the number of bytes actually read. It is greater than or equal to 0.
* If the function fails, the return value is an error code. It is a negative value.
* @remarks If you read the Windows file, the multi byte data is stored in Little Endian format. To use this data, you should
* convert the multi byte data into the Big Endian format.
int Bfile_ReadFile(int HANDLE, void *buf, int size, int readpos);
You have to set last argument to (-1)
Zezombye
Post by Zezombye » Sat Sep 08, 2018 9:31 am
Thanks. This is very misleading, I expected reader->pos to be the position in the file, and reader->len to be the length of the file. Also the name mp_reader_posix_readbyte() implies that it reads only one byte, it should be mp_reader_posix_readbytechunk or something that implies it reads 20 bytes by 20 bytes. (mp_reader_posix_readbytes() would be misleading too, I'd expect that this function reads all the bytes of the file)
I put -1 as the position and now it works fine, thanks :D
As for the closing bug, I put the freeing lines at the end of the syntax_error label (as the nlr_raise seems to act like a return):
syntax_error:;
        mp_obj_t exc;
        } else {
                "invalid syntax");
		// free the memory that we don't need anymore
		m_del(rule_stack_t, parser.rule_stack, parser.rule_stack_alloc);
		m_del(mp_parse_node_t, parser.result_stack, parser.result_stack_alloc);
		mp_lexer_free(lex);
        nlr_raise(exc);
It seems to work fine, however can this cause errors elsewhere? Why wasn't this done by default?
jickster
Post by jickster » Sat Sep 08, 2018 11:24 am
Micropython is a work in progress.
Zezombye
Post by Zezombye » Tue Nov 13, 2018 5:45 pm
As 2064 is very close to a power of 2, I think there is a hardcoded limit somewhere. I don't think there is a coincidence because 2 kb is quite low
I knew it, there is indeed a hardcoded limit (in main.c, hiding in plain sight):
static char heap[2048];
Changing the size of the heap works, but in my case I have only 8 kb of static RAM, so I needed to allocate on the heap:
const char* heap;
int mpy_main(char *text) {
	#if MICROPY_ENABLE_GC
	heap = malloc(16384);
	#endif
