I have now managed to get Jupyter Notebook running a MicroPython-USB kernel on my laptop (Windows). However, when I submit the command
%serialconnect to --port=/dev/tty.SLAB_USBtoUART --baud=115200
I get the following answer:
Connecting to --port=/dev/tty.SLAB_USBtoUART --baud=115200
Try one of these ports as --port=
COM3
COM4
COM6
Next, I try %serialconnect to --port=COM6 --baud=115200, only getting this answer:
Connecting to --port=COM6 --baud=115200
[Timed out waiting for recognizable response]
Disconnecting [paste mode not working]
(You may need to reset the device)
What is the exact syntax for connecting to COM6?
How to connect to COM port from Jupyter Notebook
Re: How to connect to COM port from Jupyter Notebook
You've got the right syntax; if you have a MicroPython-enabled device on COM6 that should work.
If you're not sure which COM (you're obviously on Windows) port your device is connected to open Device Manager and plug your MicroPython device into a USB port. The device - and the COM port that it enumerates to - should appear under 'Serial devices' or something similar.
When the Jupyter Notebook MicroPython kernel is suggesting COM3, 4, 6 it's just listing the available serial devices, they're not all necessarily MicroPython devices that will respond to the connection.
Still, I can't make it work. I don't get a Ready signal.
When I try
print ('hello esp8266')
my computer responds with
No serial connected
%serialconnect to connect
%esptool to flash the device
%lsmagic to list commands
My esp8266 works with Putty via COM6.
When I try
No serial connected
I just discovered that if I submit
from my computer and press reset on the esp8266 a couple of seconds later I in fact get a response from the esp8266, namely the following:
b'sd\x00$\xdc\x9f<\x00\x84l\xe0<\x03\x0c'
b'\x0c\x8c'b'l\xe4\x0cc|\x8f\x82\x03\xec\x13\x9br\x9b#\x84'b"c\x84\xfb'o\x9fdo'\x9c\xe2\xe4"b'c\x1cp\xc4\xc7dsdrd8\xfbg\xe0\x10\x03\x0c'b'\x82'lb"\x0c\x0cb\x0c'\xe3|\x03\xe4ld\x0c\x0c"b"c\x84\xfb'o\xee\x00d\x8c\xc7$`\x03\x98\x13\x1bgn\x0c\xc7\x07l\x07\x03os\x8e\x9b\x93n\x0c"b'c\x0cd`\x03p\xfbg\xe0\x10\x02'b's\x84\x9c\x9c\xe3\xe0\x0c'b'c\x0cn\xe2|\x03ll'b"c\x8c\xfbg'\xe7\x00"b'\x8fl`\x03\x98\x13\x1bgn\x0cd`\x02\x07\x03gs\x8e\xdb\x93n\x0c'b'\xc3l\x9c\x0edp\xfbg\xe0\x10\x02'b'\x0cs\xc4\x9c\x9c\xe3\xe0'b'\x8fr\xc0'cb'o\xe2<\x03\xec\x84\xc4\xc7'b'c\x84\xfbgn\xe7\x00'b'l`\x03\x90\x12\x1bog'b"\x87\x0fl\x07\x03o;\xc7\x9b\xdb'"ld`{ۓob'\x03d$`\x03\x07\xfc\x80'b'l\xdc\x9f<\xff\x83\x1bs{gb\x87\x84'b'l\x1b\xec\x03'b'c\xe4l'b'c\xec\x84\x9c\x9c\xe3\xe3l\xe4\x87'b"c\x0c\x8fl{l\x07d\x0cl\x9c\x9f|\xfe\xc3\x13{;'c\x87\x84ll\x9cl"b'\x0cc\xe4\x8c'b'c\xec\x84\x9c\xdc\xe3\x03b\x9b\x03\x0cb\xec'b'\x8fl;l\x07\x84'b'l\x9c\x9f|\xff\x83\x12s;gb\x87\x84$\x0c\x9c\xec\x83'b'c\x84\x0c\x0cb\xec\x84\x9c\xdc\xe3\x03\x1b\x0c\x8f\x0c#\xeclb\x07d\x8c\xe3\x03\xe4\x1b\x83o\xec\x9b;\x83\xfbg|\xec'lb'ld$`\x03\x1c#\x93\x1b\x02'b'\x9f|\x03{\xdb\x03$\x9cn\xe0'b'\x83o\xe2\x00'b'l`\x03\x8c\xe2s\x92l\x84l\x1b\xc4\x0c'b'\x0cl`\x03\x84\xe3{\x9bd\xecd\x12\x8c'b'\x0c\x0c$`\x03\x8c\xe3s\xdbl'b'\x8f\x9e\x00\x84\x0c\x0c'b'l \x03{$\x8f\xc3sl\x8c\x9f\xe3\x84c'b'\x8c\x84c\x1c<'b"l#\x9c\xe2\xdc\x03c|\x90\xc4\x8c\x84\x0cl$c\xe4\xfbg\xe7\x80\x1b'o\xe2\x18\x03\x0c\x03\xc4d'\x9f\x0c\xe4\x0c\x84"b'l\xe4\x87l$\x8c'b'\x87\x8c'b'\x0cd`\x03\xc0\x03o\xfc\x00\xc4\x9f\xe3\x8c#\x0cdl\xe4\xc4\xc7\x1b\x0c#'b'\x02\x03\x8c\xdf\xe3\x8cb'b'$\x0c\x84c\x1crl;l{\xf3o\x9c\xe3\x00\xc4\x0c\xe4\xc3\x13\x03c'b'\x87\x1e\x1c{\x8cd\x9cp\xe4\x84\x87\x9c\x1f\xe3\xec\x84l\xc7\xe0c\x0c\xe4c\xec\xfbg\x9c\x9f\x80\xc0\x03c\x84\x8f\x1f\x1c{\x8cl\x9c8\xe4\x84\x8f\xdc\x1f\xe3\xec\x84$\x87\xe0cl`\x03\x0f\xec'b'l\xdc\x9f<\xff\x83\x1bs{oc\x8f\x8c'b'\x8c\xdc\x8f\x87\x8ec\x8c'b'\x0c#\xe4\x8c\x9c\x9c\xdc|\x93\xec\x8e'b"cd\x0cdc\x0ed\x03\xc3\x83\x03l'\x9cl`\x03\x03\x83\x83\x02do\xdcxsd\x0e\x0c\xc7d\x9c\x9e|\xff\x83\x1b;\xff#5 ets_task(40100130, 3, 3fff83ec, 4)\r\n"WebREPL daemon started on ws://192.168.4.1:8266
WebREPL daemon started on ws://0.0.0.0:8266
Started webrepl in normal mode
The following makes it work!!!
%websocketconnect --password mypassword
