But wait there's more!
WDT does exist for ESP8266. How do I know? By looking at the C-code (and by the fact that when you attempted to use it, you were able to get SOME response).
I also looked at the the file machine_wdt.c and I do not see how you can set a timeout at all.
The only argument allowed to the constructor is 0 (which is also the default if you leave it blank).
There are two functions: feed, deinit
but I don't see how to set the timeout.
It ?appears? the watchdog is meant for the system's use and not your own use but there should be some way to set the timeout.
#include <string.h>
#include "py/runtime.h"
#include "user_interface.h"
#include "etshal.h"
#include "ets_alt_task.h"
const mp_obj_type_t esp_wdt_type;
typedef struct _machine_wdt_obj_t {
mp_obj_base_t base;
} machine_wdt_obj_t;
STATIC machine_wdt_obj_t wdt_default = {{&esp_wdt_type}};
STATIC mp_obj_t machine_wdt_make_new(const mp_obj_type_t *type_in, size_t n_args, size_t n_kw, const mp_obj_t *args) {
mp_arg_check_num(n_args, n_kw, 0, 1, false);
mp_int_t id = 0;
if (n_args > 0) {
id = mp_obj_get_int(args[0]);
switch (id) {
case 0:
ets_loop_dont_feed_sw_wdt = 1;
system_soft_wdt_feed();
return &wdt_default;
default:
mp_raise_ValueError(NULL);
STATIC mp_obj_t machine_wdt_feed(mp_obj_t self_in) {
(void)self_in;
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_1(machine_wdt_feed_obj, machine_wdt_feed);
STATIC mp_obj_t machine_wdt_deinit(mp_obj_t self_in) {
(void)self_in;
ets_wdt_disable();
STATIC MP_DEFINE_CONST_FUN_OBJ_1(machine_wdt_deinit_obj, machine_wdt_deinit);
STATIC const mp_rom_map_elem_t machine_wdt_locals_dict_table[] = {
{ MP_ROM_QSTR(MP_QSTR_feed), MP_ROM_PTR(&machine_wdt_feed_obj) },
{ MP_ROM_QSTR(MP_QSTR_deinit), MP_ROM_PTR(&machine_wdt_deinit_obj) },
STATIC MP_DEFINE_CONST_DICT(machine_wdt_locals_dict, machine_wdt_locals_dict_table);
const mp_obj_type_t esp_wdt_type = {
{ &mp_type_type },
.name = MP_QSTR_WDT,
.make_new = machine_wdt_make_new,
.locals_dict = (mp_obj_dict_t*)&machine_wdt_locals_dict,
